Date/Time: Tue, 04 Nov 2025 18:08:36 +0000
Replay control panel not coming up
View Count: 662
| [2021-07-25 16:58:04] |
| User525965 - Posts: 173 |
Hi, I'm unable to bring up the control panel to do replay today. Tried, shutting down and restarting. If I select play/pause it will ask me if I want to enter sim mode. But when I select the control panel it doesn't open.
| [2021-07-25 17:21:22] |
FYI i read how to set up the new replay, and can get it to play if I go back to a certain point on the chart, I can play it from there but I would like to be able to use the control panel to set specific times and speeds
| [2021-07-26 04:08:11] |
Refer to: Replaying Charts: Chart Replay Window Not Visible Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
