Date/Time: Sat, 01 Mar 2025 10:59:21 +0000
Dom making it faster or 1st
View Count: 590
[2021-07-25 14:42:50]
User220914 - Posts: 239
I was wondering how I can make the DOM of a chart faster.
1. How can I make them the 1st drawn and calculated of my charts since they seem to be treated as charts?
2. Can I use my 1st licensed use of sierra for doms? And my second licensed use for charting?
Could you explain this process please and would it make my DOM update faster?
Thank you.
3. Is making a dom difficult? Would you or could you create a custom dom?
[2021-07-26 03:59:11]
1. You need to reduce this setting:
Chart Settings: Chart Update Interval in Milliseconds (Chart >> Chart Settings >> Display >> Chart Update Interval menu)
2. Yes, yes, yes. Refer to:
Overview of Trading: Sierra Chart Configuration for Most Low Response Time Trading
You will need one Sierra Chart account for this. Not 2.
3. What specifically do you need that you are not sure how to do?
[2021-08-20 20:12:36]
Thank you for your answers. I will go through the setting again. MY DOM is like chart number 20 out of say 30 so i was thinking how would i always make the doms be the 1st number of charts so they update the soonest?
Is there a possibility of redoing the DOM or can i pay to have someone make a different dom?
Your dom works fine but i have other doms that I personally am faster with and that is the only reason.
I switch rapidly between order types on the dom with a check box click.. say
mit
lit
stop
stop limit. all are just a mouse click to change them on the dom and next to the box is the postiive and negative offset.
that is really all i am after being able to qucikly switch order types that i am plaving right on the dom.
with your dom. i need to go into setting and move to rightmouse button left mouse button above and below bid or offer.
I need to be able to do it on the fly lots of times depending on what I am trying to do in the mkts.
thank you.
Date Time Of Last Edit: 2021-08-20 20:16:11
[2021-10-02 17:26:21]
There is not a way to control this:
However, refer to:
There really is not a way to make the changes you are asking for. But we are going to be working on a new Trading interface which will be customizable through a Control Bar.
Maybe we could add control bar buttons to change the Order Type on the trade window. We will look into that. Although you can customize the order types on the Chart/Trade DOM which depend upon left or right clicks and order entry relative to the last trade price:
Global Trade Settings Windows: Chart DOM Settings
Date Time Of Last Edit: 2021-10-02 17:26:52
