Date/Time: Sat, 26 Sep 2026 23:39:06 +0000
volume bars
View Count: 1758
[2014-03-19 14:20:43]
User63439 - Posts: 83
hi there,
when i compare my 1000 volume bars delivered by tt price feed on sierra chart to those delivered by continuum on ninja trader for cl may contract, they look different.
shouldnt they look the same?
can you please post a chart of 1000 volume bars of cl may contract from the sierra chart price feed, so that i can
compare and might switch to sierra price feed for cme.
thanks in advance
image1000_volume.png / V - Attached On 2014-03-19 14:20:26 UTC - Size: 71.09 KB - 575 views
[2014-03-19 16:38:48]
TT FIX is a good data feed. Most likely you just need to set Sierra Chart to store data tick by tick:
https://www.sierrachart.com/index.php?l=doc/helpdetails47.html
[2014-03-19 16:48:59]
hi there,
i have set it to 1 tick. can you post a chart of sierra chart feed please.
image2014-03-19_1747.png / V - Attached On 2014-03-19 16:48:42 UTC - Size: 34.79 KB - 675 views
[2014-03-19 17:05:40]
You also need to re-download the data in the chart by selecting Edit >>Delete All Data and Download.
What is the Time Zone in the chart and what are the Intraday Session Times set to in Chart >> Chart Settings. This is necessary for us to know so we can post an image which would correspond to your settings.
Date Time Of Last Edit: 2014-03-19 17:06:03
[2014-03-19 17:11:38]
hi,
still same chart like posted before. intraday data storage unit has always been set to 1 tick
time zone is brussels. session times from 00.00.00 to 23:59:59.
fdax data from continuum and sierra feed match 1:1, bars look identical
thanks
Date Time Of Last Edit: 2014-03-19 17:16:19
[2014-03-20 15:18:11]
hi,
is it a problem for you to post a simple chart?
[2014-03-20 22:38:02]
We have been very busy. We will do this for you now.
[2014-03-20 22:41:20]
Here is the chart:
http://www.sierrachart.com/image.php?l=1395355195491.png
[2014-03-21 10:24:19]
thanks a lot, tt fix is good, continuum not matching sierra and tt.
[2014-03-21 10:25:40]
Yes, TT FIX is good with what you are using it for.
[2014-03-22 01:36:19]
User65915 - Posts: 4
what data feed through AMP futures is recommended? I trade the ES and use numbers bars and market profile
[2014-03-22 20:55:22]
If the question is directed to Sierra Chart support, we will only recommend our own data feed for good quality data:
https://www.sierrachart.com/index.php?l=doc/SierraChartRealTimeFuturesStockDataFeed.php
Due to various problems with broker data feeds, we will not recommend them.
