Date/Time: Fri, 28 Feb 2025 09:12:06 +0000
[User Discussion] - Renko alerts via email
View Count: 538
[2021-07-23 10:32:40] |
Twiggy - Posts: 5 |
Hello. Hoping you can help. If it is at all possible, can you tell me how I can receive an alert via email when a renko bar has closed and open a new brick please? Even better if it could alert me to a change in direction but that is not a necessity. Thank you in advance. |
[2021-07-26 09:35:18] |
Twiggy - Posts: 5 |
I have found where I set my email to receive alerts via global settings, I just need to know the formula or code to input to recieve an alert for a new renko bar if anyone would be so kind to help me on this. I'm not sure if i'm getting this right, would SG23=C alert me on a close of a renko bar? Thank you Date Time Of Last Edit: 2021-07-26 09:45:12
[2021-08-14 10:53:57] |
Refer to this page: Study/Chart Alerts And Scanning Also refer to: Renko Bar Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
