Date/Time: Tue, 04 Nov 2025 18:08:36 +0000
Auto-Coloring for RSI Above or Below 50 Level?
View Count: 689
[2021-07-23 06:38:12]
User344276 - Posts: 72
Is there anyway to auto-color the RSI line to change colors when it is above or below the 50 level? Thanks for your help.
[2021-07-23 13:22:34]
SC Support Tom - Posts: 450
One way to do this is to use the study called Study Subgraph - Subtract.
Study Subgraph Subtract
Apply this study to the same chart to which the RSI study is applied. In the Settings and Inputs tab for Study Subgraph - Subtract, do the following.
* Set Based On to RSI.
* Set Input Data to RSI.
* Set Amount to Subtract to 50.
Chart Studies: Settings and Inputs tab
This will draw the Subgraph for RSI - 50.
Then in the Subgraphs tab for Study Subgraph - Subtract, set Auto-Coloring to Based on +/-, and then click Apply.
Chart Studies: Subgraphs Tab
This will auto-color the RSI - 50 Subgraph one color when RSI - 50 > 0 (RSI > 50), and another color when RSI - 50 < 0 (RSI < 50).
