Date/Time: Tue, 04 Nov 2025 18:18:14 +0000
[User Discussion] - Location on Lower Timeframes of SlopingTrendlines drawn on highe
View Count: 2295
| [2013-04-22 19:18:09] |
| PhilipJames - Posts: 34 |
Is it possible to fix a sloping trendline accurately to certain swing points on a chart on a higher time-frame, so that when i drop right down to a low timeframe the line appears in exactly the correct place? I assume if the sloping lines do not have precise points to attach to on a high timeframe then there's no reference point for them on a low timeframe - eg 2 precise points. swing highs or lows I assume would be the exact same locstion on high and low timeframes and so can they be used for this purpose? Hope that makes sense!! |
