Date/Time: Mon, 25 Nov 2024 22:47:30 +0000
Error Activating 'EUREX' on account #1.
View Count: 1159
[2014-03-19 11:57:40] |
User74010 - Posts: 9 |
Hi I try to activate the eurex stream but it shows "Error Activating 'EUREX' on account #1."
[2014-03-19 15:38:49] |
Sierra Chart - Max - Posts: 5731 |
The issue should be resolved for your account today. We have already contacted our data provider.
Sierra Chart Support |
[2014-03-19 18:00:15] |
Thanks, in the mean time i want to go back to the IB data services, but I can't get rid of the 'M' behind the future code. How can I get rid of the 'M'?
[2014-03-19 18:02:29] |
Disable Global Settings >> Data/Trade Service Settings >> Allow Support for Sierra Chart Data Feeds. After this reconnect to the data feed with the disconnect and connect commands on the File menu.
[2014-03-19 19:28:10] |
There is no need to deactivate and reactivate the feature on the Control Panel. As was mentioned in post #2, we can contacted the data provider and they will take care of the issue.
[2014-03-19 21:02:04] |
Your account is now good to go.
