Date/Time: Tue, 22 Sep 2026 05:16:08 +0000
[User Discussion] - Error in Message Log
View Count: 686
[2021-07-19 11:14:35]
58LesPaul - Posts: 429
I keep getting this error in my message log.
Error setting System Date-Time. Windows error code 1314: A required privilege is not held by the client. | 2021-07-19 06:07:33.017 *
I searched and it gave me and big list of things to do to correct it that is technically over my head. Is it effecting my SC in any way? I see my SC time is off by 00:00:00:193. Is that a big difference?
[2021-07-20 11:20:08]
How is this Windows error message 1314 affecting my Sierra Chart? Is it necessary to try and fix the issue?
[2021-07-20 12:15:45]
User90125 - Posts: 715
You're probably not logged in as a Administrator.
Just exit SC and start it up again as a Administrator and it should work.
Another way to sync the time on your computer is to use a third-party software such as Dimension 4.
