Date/Time: Mon, 25 Nov 2024 22:39:49 +0000
PC Clock
View Count: 1028
[2014-03-19 00:40:00] |
dennismed - Posts: 62 |
How do I fix this issue Notice: Your computer's clock is off by 3598 seconds. For help with this Date-Time issue, press the Send for Analysis button. | 2014-03-18 21:16:39 Thank You |
[2014-03-19 00:49:19] |
See: http://www.sierrachart.com/index.php?l=doc/helpdetails38.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
