Date/Time: Tue, 22 Apr 2025 13:36:38 +0000
cursor sync across all chartbooks
View Count: 1156
[2021-07-18 06:05:17] |
User486817 - Posts: 83 |
hello, i have sierra charts running with multiple chartbooks simultaneously. each chartbook is on a separate screen. i have the hand tool combined with the crosshair tool as my cursor. how can i sync my cursor so that i can see it on all chartbooks simultaneously on every chartbook on each screen at the same time? currently, the cursor will only show for just one chartbook at a time. kindest, |
[2021-07-18 22:36:31] |
There is no support for this tool to be active across multiple Chartbooks at the same time.
[2023-12-20 17:55:15] |
lservin29 - Posts: 67 |
do you plan to make this available, or a additional "check box" feature
[2023-12-27 06:24:51] |
User644077 - Posts: 5 |
yes, i wanted to have the NQ and ES ( on two differnt chartbooks) but synchorise the crosshair based on time. Any plan to include this soon?
[2025-01-12 14:29:25] |
User681249 - Posts: 6 |
A global cursor between chartbooks would be very useful. Please?!
