Date/Time: Mon, 14 Sep 2026 19:39:48 +0000
[Programming Help] - Data in SC not performing as expected
View Count: 685
| [2021-07-16 16:22:04] |
| John910 - Posts: 12 |
Hello, I noticed the data updates on chart are somewhat smoothed out or filtered out. I'm using SC Denali with CQG but I don't think it matters. So, basically data on the chart with Dom updates in about a second or so at Max, (Max should me about 100x more or so, at least 10x) I have feeling I receive about 3% action on the screen. I don't have a problem not receiving 100% because nobody can perceive that, but this is looking not good enough. My hardware is top level etc.. ping around 10-20, CPU 0-20%, GRAPHICS LESS THAN 10% Can you guys open up a stream a bit or suggest some settings? Thanks |
| [2021-07-16 19:19:31] |
| Sierra_Chart Engineering - Posts: 24862 |
Set Sierra Chart to a Tick by Tick Data Configuration. Follow the instructions here to do this: Tick by Tick Data Configuration Also check the Chart Update Interval: Chart Settings: Chart Update Interval in Milliseconds (Chart >> Chart Settings >> Display >> Chart Update Interval menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
