Date/Time: Wed, 27 Nov 2024 16:39:45 +0000
Hide trade account list
View Count: 706
[2021-07-16 06:28:33]
nicktrader - Posts: 712
After almost every launch of the platform, I have to check the "Hide trade account list" field.
What could be the reason that the setting is not permanent?
Many thanks
[2021-07-16 07:04:05]
Sierra_Chart Engineering - Posts: 17195
In our testing the setting is saved.
The problem could have something to do with Trade Window linking in your case:
Working With Charts: Chart Linking
[2021-07-16 14:04:42]
I was found the "error". The field "Hide trade account list" is directly related to the "twconfig" (and also the Quantity buttons).
From my point of view the relation of quantity buttons still make sense, but not the field "Hide trade account list".
Many thanks
[2023-07-19 23:35:00]
joew - Posts: 46
I have the opposite problem. I trade multiple accounts and Sierra keeps hiding them on me. Also have an issue with the scale in and scale out option. I find at times this will randomly be unchecked. There should be a global setting for this. I want it on always. I do not even need an option to uncheck it.
[2023-07-20 15:22:01]
John - SC Support - Posts: 36322
As stated above, these items are tied to the Configuration files. So if you are changing between different configurations, then you would want to update those configurations to make sure they have these items set as you want. Refer to the following:
Basic Trading and the Trade Window: Using and Changing Between Different Trade Window and Attached Orders Configurations
[2023-07-24 16:13:06]
joew - Posts: 46
I have 21 different configurations for different strategies. Every time I add a new account I have to resave this 21 times? That is what I am having to do now and that is pretty ridiculous. One global setting should cover all of that
