Date/Time: Sun, 16 Mar 2025 16:24:11 +0000
VbP from Start DateTime to currently viewed DateTime (not End Time)
View Count: 661
[2021-07-15 19:18:30]
ivory - Posts: 95
Like in the title - can I configure one VbP on the right blank fill space that shows a composite profile from a selected Start DateTime to the latest DateTime currently on screen? It would be updated as I scroll. A bit like "Visible Bars", but with a fixed start date in the past.
Right now I am using "From Start Date-Time to End", which for a historical contract is static and includes transactions that happened after the period I am reviewing.
If it's not possible on the regular chart, would it work in chart replay?
[2021-07-15 19:35:19]
John - SC Support - Posts: 38678
There is not an option for what you are looking for. We will add this to our list of work items and tag this as a Feature Request.
There is nothing different available in the Volume by Price for replays. The option you tried (From Start Date-Time to End) would be the best option, as it will update during the replay, but it works exactly the same as real-time, in that there is no way to have it adjust based on the viewing area end-time.
[2021-07-15 19:38:29]
ivory - Posts: 95
Thanks for letting me know, John.
[2022-08-19 14:08:58]
ivory - Posts: 95
Hello again,
Did you have a chance to look into it?
Kind Regards,
Ivory
[2022-08-19 18:38:16]
Tony - Posts: 554
Hi Ivory, would you consider write a custom study by yourself? This could be done by ACSIL code.
[2022-08-19 19:02:02]
ivory - Posts: 95
Hey Tony, perhaps at some point in the future I would. I'm not a C++ wiz, but ACSIL seems pretty straightforward. I was hoping SC would add it at some point, since it's now on their Feature Request list.
