Date/Time: Mon, 25 Nov 2024 22:55:51 +0000
trouble connecting
View Count: 970
[2014-03-18 19:27:32] |
User27605 - Posts: 9 |
Since downloading the pre-release it can take an hour to connect. I followed the directions stating to change the port number etc. Any help would be greatly appreciated. Software version: 1108 | 2014-03-18 08:23:43 Usage end date: 2014-03-21 | 2014-03-18 08:23:43 Enabled for: Sierra Chart Historical Data Service. | 2014-03-18 08:23:43 Allow Support for Sierra Chart Data Feeds is enabled. | 2014-03-18 08:23:43 Active service: TransAct | 2014-03-18 08:23:43 Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2014-03-18 08:23:43 2014-03-18 08:23:43 Local computer clock time | 2014-03-18 08:23:43 2014-03-18 12:23:43 GMT time | 2014-03-18 08:23:43 2014-03-18 08:23:43 Time zone adjusted time | 2014-03-18 08:23:43 Time difference to server time: 11 seconds. | 2014-03-18 08:23:43 Program path: C:\SierraChart\SierraChartTransAct\ | 2014-03-18 08:23:43 Data Files path: C:\SierraChart\SierraChartTransAct\Data\ | 2014-03-18 08:23:43 OS Version Number: 6.0 | 2014-03-18 08:23:43 Checking for new symbol settings for ta | 2014-03-18 08:23:43 Symbol settings are up-to-date for ta | 2014-03-18 08:23:44 ! NOTICE: 3 days of full use Remaining. If you would like to continue full use the software and services, | 2014-03-18 08:23:44 please purchase more usage time by selecting Help >> Purchase on the menu. | 2014-03-18 08:23:44 TransAct - Starting server: C:\SierraChart\SierraChartTransAct\Transact\TransactToSierraBridge.exe | 2014-03-18 08:23:48 TransAct: Connecting to the server 127.0.0.1. Port 2001 | 2014-03-18 08:23:51 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-03-18 08:23:54 Socket has been shutdown and closed. | 2014-03-18 08:23:54 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-18 08:23:54 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-18 08:23:54 TransAct: Disconnected from the server. | 2014-03-18 08:23:54 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-18 08:23:54 TransAct - Starting server: C:\SierraChart\SierraChartTransAct\Transact\TransactToSierraBridge.exe | 2014-03-18 08:23:56 TransAct: Connecting to the server 127.0.0.1. Port 2001 | 2014-03-18 08:23:58 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-03-18 08:24:02 Socket has been shutdown and closed. | 2014-03-18 08:24:02 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-18 08:24:02 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-18 08:24:02 TransAct: Disconnected from the server. | 2014-03-18 08:24:02 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-18 08:24:02 TransAct - Starting server: C:\SierraChart\SierraChartTransAct\Transact\TransactToSierraBridge.exe | 2014-03-18 08:24:04 TransAct: Connecting to the server 127.0.0.1. Port 2001 | 2014-03-18 08:24:06 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-03-18 08:24:09 Socket has been shutdown and closed. | 2014-03-18 08:24:09 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-18 08:24:09 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-18 08:24:09 TransAct: Disconnected from the server. | 2014-03-18 08:24:09 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-18 08:24:09 TransAct - Starting server: C:\SierraChart\SierraChartTransAct\Transact\TransactToSierraBridge.exe | 2014-03-18 08:24:11 TransAct: Connecting to the server 127.0.0.1. Port 2001 | 2014-03-18 08:24:13 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-03-18 08:24:17 Socket has been shutdown and closed. | 2014-03-18 08:24:17 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-18 08:24:17 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-18 08:24:17 TransAct: Disconnected from the server. | 2014-03-18 08:24:17 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-18 08:24:17 Current selected Data/Trading service: TransAct | 2014-03-18 08:24:18 TransAct - Starting server: C:\SierraChart\SierraChartTransAct\Transact\TransactToSierraBridge.exe | 2014-03-18 08:24:19 TransAct: Connecting to the server 127.0.0.1. Port 5023 | 2014-03-18 08:24:21 File >> Disconnect selected. | 2014-03-18 08:24:21 Socket has been shutdown and closed. | 2014-03-18 08:24:21 TransAct: Disconnected from the server. | 2014-03-18 08:24:21 TransAct - Starting server: C:\SierraChart\SierraChartTransAct\Transact\TransactToSierraBridge.exe | 2014-03-18 08:24:24 TransAct: Connecting to the server 127.0.0.1. Port 5023 | 2014-03-18 08:24:26 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-03-18 08:24:30 Socket has been shutdown and closed. | 2014-03-18 08:24:30 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-18 08:24:30 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-18 08:24:30 TransAct: Disconnected from the server. | 2014-03-18 08:24:30 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-18 08:24:30 TransAct - Starting server: C:\SierraChart\SierraChartTransAct\Transact\TransactToSierraBridge.exe | 2014-03-18 08:24:32 TransAct: Connecting to the server 127.0.0.1. Port 5023 | 2014-03-18 08:24:34 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-03-18 08:24:38 Socket has been shutdown and closed. | 2014-03-18 08:24:38 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-18 08:24:38 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-18 08:24:38 TransAct: Disconnected from the server. | 2014-03-18 08:24:38 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-18 08:24:38 TransAct - Starting server: C:\SierraChart\SierraChartTransAct\Transact\TransactToSierraBridge.exe | 2014-03-18 08:24:40 TransAct: Connecting to the server 127.0.0.1. Port 5023 | 2014-03-18 08:24:42 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-03-18 08:24:45 Socket has been shutdown and closed. | 2014-03-18 08:24:45 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-18 08:24:45 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-18 08:24:45 TransAct: Disconnected from the server. | 2014-03-18 08:24:45 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-18 08:24:45 TransAct - Starting server: C:\SierraChart\SierraChartTransAct\Transact\TransactToSierraBridge.exe | 2014-03-18 08:24:47 TransAct: Connecting to the server 127.0.0.1. Port 5023 | 2014-03-18 08:24:49 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-03-18 08:24:53 Socket has been shutdown and closed. | 2014-03-18 08:24:53 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-18 08:24:53 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-18 08:24:53 TransAct: Disconnected from the server. | 2014-03-18 08:24:53 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-18 08:24:53 TransAct - Starting server: C:\SierraChart\SierraChartTransAct\Transact\TransactToSierraBridge.exe | 2014-03-18 08:24:55 TransAct: Connecting to the server 127.0.0.1. Port 5023 | 2014-03-18 08:24:57 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-03-18 08:25:00 Socket has been shutdown and closed. | 2014-03-18 08:25:00 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-18 08:25:00 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-18 08:25:00 TransAct: Disconnected from the server. | 2014-03-18 08:25:00 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-18 08:25:00 TransAct - Starting server: C:\SierraChart\SierraChartTransAct\Transact\TransactToSierraBridge.exe | 2014-03-18 08:25:02 TransAct: Connecting to the server 127.0.0.1. Port 5023 | 2014-03-18 08:25:04 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-03-18 08:25:08 Socket has been shutdown and closed. | 2014-03-18 08:25:08 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-18 08:25:08 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-18 08:25:08 TransAct: Disconnected from the server. | 2014-03-18 08:25:08 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-18 08:25:08 TransAct - Starting server: C:\SierraChart\SierraChartTransAct\Transact\TransactToSierraBridge.exe | 2014-03-18 08:25:10 TransAct: Connecting to the server 127.0.0.1. Port 5023 | 2014-03-18 08:25:12 The network socket is connected. | 2014-03-18 08:25:12 TransAct: Connected to server. | 2014-03-18 08:25:12 DTC Server Info - Server Name: TransactToSierraBridge. Server Version: 1.2.2.0. Provider Name: Transact Futures. | 2014-03-18 08:25:12 DTC - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2014-03-18 08:25:12 TransAct: Sending logon request message. | 2014-03-18 08:25:12 Transact Futures Server Info - Server Name: TransactToSierraBridge. Server Version: 1.2.2.0. Provider Name: Transact Futures. | 2014-03-18 08:25:14 Transact Futures - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2014-03-18 08:25:14 Transact Futures - Successfully connected. Operation Successful. | 2014-03-18 08:25:14 TransAct - Starting real-time market data updates for: YMM4 | 2014-03-18 08:25:53 HD Request # 2 - Downloading Intraday chart data for YMM4 to the file YMM4.scid. Service: ta | 2014-03-18 08:25:53 HD Request # 2 - Download start Date-Time: 2014-03-18 08:02:00.0 | 2014-03-18 08:25:53 HD Request # 2 - Using server: ds4.sierracharts.com port 10149 | 2014-03-18 08:25:53 Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-03-18 08:25:53 The network socket is connected. | 2014-03-18 08:25:53 HD Request # 2 - Sending historical data logon request message. | 2014-03-18 08:25:53 TransAct - Starting real-time market data updates for: $DOWI | 2014-03-18 08:25:54 HD Request # 3 - Downloading Historical Daily chart data for $DOWI. Starting date: 2014-03-14. Service: ta | 2014-03-18 08:25:54 HD Request # 3 - Requesting historical Daily data for $DOWI starting at 2014-03-13 | 2014-03-18 08:25:54 Symbol Error - $DOWI is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2014-03-18 08:25:54 SC Market Stats - Starting real-time market data updates for: TICK-NYSE | 2014-03-18 08:25:54 SC Market Stats: Connecting to the server ds3.sierracharts.com. Port 443 | 2014-03-18 08:25:54 Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-03-18 08:25:54 TransAct - Starting real-time market data updates for: NQM4 | 2014-03-18 08:25:54 The network socket is connected. | 2014-03-18 08:25:54 SC Market Stats: Connected to server. | 2014-03-18 08:25:54 SC Market Stats: Sending logon request message. | 2014-03-18 08:25:54 HD Request # 3 - Receiving historical Daily data for $DOWI starting at 2014-03-13 | 2014-03-18 08:25:54 Writing historical Daily data for $DOWI to the file $DOWI.dly | 2014-03-18 08:25:54 HD Request # 3 - Received 3 records from 2014-03-13 00:00:00 to 2014-03-17 00:00:00 (5.0 days) and wrote 2 records for $DOWI | 2014-03-18 08:25:54 HD Request # 3 - Daily download COMPLETE for $DOWI | 2014-03-18 08:25:54 HD Request # 2 - Requesting Intraday data. Max. days to return: 186. Start Date-Time: 2014-03-18 12:02:00. Record interval: 0 | 2014-03-18 08:25:54 HD Request # 2 - Decompressing data. | 2014-03-18 08:25:54 HD Request # 2 - Receiving Intraday data for YMM4 starting at 2014-03-18 08:02:00 | 2014-03-18 08:25:54 HD Request # 2 - Timestamp of first Intraday data file record written: 2014-03-18 08:02:00 | 2014-03-18 08:25:54 Socket has been shutdown and closed. | 2014-03-18 08:25:54 The network socket for historical data has been closed. | 2014-03-18 08:25:54 HD Request # 2 - Received 1932 records from 2014-03-18 08:02:00 to 2014-03-18 08:25:35 (23.6 minutes) and wrote 1931 records for YMM4 | 2014-03-18 08:25:54 HD Request # 2 - Intraday download COMPLETE for YMM4 | 2014-03-18 08:25:54 Real-time Intraday chart data file updates started for YMM4 | 2014-03-18 08:25:54 HD Request # 4 - Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc | 2014-03-18 08:25:54 HD Request # 4 - Download start Date-Time: 2014-03-18 08:14:54.0 | 2014-03-18 08:25:54 HD Request # 4 - Using server: ds5.sierracharts.com port 10149 | 2014-03-18 08:25:54 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-03-18 08:25:54 HD Request # 5 - Downloading Historical Daily chart data for NQM4. Starting date: 2014-03-17. Service: ta | 2014-03-18 08:25:54 HD Request # 5 - Requesting historical Daily data for NQM4 starting at 2014-03-16 | 2014-03-18 08:25:54 The network socket is connected. | 2014-03-18 08:25:54 HD Request # 4 - Sending historical data logon request message. | 2014-03-18 08:25:54 HD Request # 5 - Receiving historical Daily data for NQM4 starting at 2014-03-17 | 2014-03-18 08:25:54 Writing historical Daily data for NQM4 to the file NQM4.dly | 2014-03-18 08:25:54 HD Request # 5 - Received 2 records from 2014-03-17 00:00:00 to 2014-03-18 00:00:00 (2.0 days) and wrote 2 records for NQM4 | 2014-03-18 08:25:54 HD Request # 5 - Daily download COMPLETE for NQM4 | 2014-03-18 08:25:54 SC Market Stats Server Info - Server Name: . Server Version: . Provider Name: . | 2014-03-18 08:25:54 SC Market Stats - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2014-03-18 08:25:54 SC Market Stats - Successfully connected. | 2014-03-18 08:25:54 SC Market Stats - Restarting real-time data updates for symbol: TICK-NYSE | 2014-03-18 08:25:54 HD Request # 4 - Requesting Intraday data. Max. days to return: 186. Start Date-Time: 2014-03-18 12:14:54. Record interval: 0 | 2014-03-18 08:25:54 HD Request # 4 - Decompressing data. | 2014-03-18 08:25:54 HD Request # 4 - Receiving Intraday data for TICK-NYSE starting at 2014-03-18 08:14:54 | 2014-03-18 08:25:54 HD Request # 4 - Timestamp of first Intraday data file record written: 2014-03-18 08:14:55 | 2014-03-18 08:25:54 Socket has been shutdown and closed. | 2014-03-18 08:25:54 The network socket for historical data has been closed. | 2014-03-18 08:25:54 HD Request # 4 - Received 2170 records from 2014-03-18 08:14:54 to 2014-03-18 08:25:44 (10.8 minutes) and wrote 2169 records for TICK-NYSE | 2014-03-18 08:25:54 HD Request # 4 - Intraday download COMPLETE for TICK-NYSE | 2014-03-18 08:25:55 Real-time Intraday chart data file updates started for TICK-NYSE | 2014-03-18 08:25:55 HD Request # 6 - Downloading Intraday chart data for NQM4 to the file NQM4.scid. Service: ta | 2014-03-18 08:25:55 HD Request # 6 - Download start Date-Time: 2014-03-18 08:02:00.0 | 2014-03-18 08:25:55 HD Request # 6 - Using server: ds4.sierracharts.com port 10149 | 2014-03-18 08:25:55 Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-03-18 08:25:55 The network socket is connected. | 2014-03-18 08:25:55 HD Request # 6 - Sending historical data logon request message. | 2014-03-18 08:25:55 HD Request # 6 - Requesting Intraday data. Max. days to return: 186. Start Date-Time: 2014-03-18 12:02:00. Record interval: 0 | 2014-03-18 08:25:55 HD Request # 6 - Decompressing data. | 2014-03-18 08:25:55 HD Request # 6 - Receiving Intraday data for NQM4 starting at 2014-03-18 08:02:00 | 2014-03-18 08:25:55 HD Request # 6 - Timestamp of first Intraday data file record written: 2014-03-18 08:02:06 | 2014-03-18 08:25:55 Socket has been shutdown and closed. | 2014-03-18 08:25:55 The network socket for historical data has been closed. | 2014-03-18 08:25:55 HD Request # 6 - Received 2365 records from 2014-03-18 08:02:00 to 2014-03-18 08:25:31 (23.5 minutes) and wrote 2364 records for NQM4 | 2014-03-18 08:25:55 HD Request # 6 - Intraday download COMPLETE for NQM4 | 2014-03-18 08:25:55 Real-time Intraday chart data file updates started for NQM4 | 2014-03-18 08:25:55 The data feed was lost. There was no activity for at least 60.0 seconds. | 2014-03-18 15:16:08 Connection to the external service has been lost. | 2014-03-18 15:16:08 Socket has been shutdown and closed. | 2014-03-18 15:16:08 Transact Futures: Disconnected from the server. | 2014-03-18 15:16:08 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-18 15:16:08 NOTICE: Detected that the system has resumed from a low-power state. | 2014-03-18 15:16:09 Re-connecting to the data or trading service... | 2014-03-18 15:16:09 Transact Futures: Disconnected from the server. | 2014-03-18 15:16:09 Socket has been shutdown and closed. | 2014-03-18 15:16:12 SC Market Stats: Disconnected from the server. | 2014-03-18 15:16:12 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-18 15:16:12 TransAct - Starting server: C:\SierraChart\SierraChartTransAct\Transact\TransactToSierraBridge.exe | 2014-03-18 15:16:14 TransAct: Connecting to the server 127.0.0.1. Port 5023 | 2014-03-18 15:16:16 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-03-18 15:16:19 Socket has been shutdown and closed. | 2014-03-18 15:16:19 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-18 15:16:19 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-18 15:16:19 TransAct: Disconnected from the server. | 2014-03-18 15:16:19 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-18 15:16:19 TransAct - Starting server: C:\SierraChart\SierraChartTransAct\Transact\TransactToSierraBridge.exe | 2014-03-18 15:16:21 TransAct: Connecting to the server 127.0.0.1. Port 5023 | 2014-03-18 15:16:23 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-03-18 15:16:27 Socket has been shutdown and closed. | 2014-03-18 15:16:27 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-18 15:16:27 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-18 15:16:27 TransAct: Disconnected from the server. | 2014-03-18 15:16:27 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-18 15:16:27 TransAct - Starting server: C:\SierraChart\SierraChartTransAct\Transact\TransactToSierraBridge.exe | 2014-03-18 15:16:29 TransAct: Connecting to the server 127.0.0.1. Port 5023 | 2014-03-18 15:16:31 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-03-18 15:16:35 Socket has been shutdown and closed. | 2014-03-18 15:16:35 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-18 15:16:35 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-18 15:16:35 TransAct: Disconnected from the server. | 2014-03-18 15:16:35 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-18 15:16:35 TransAct - Starting server: C:\SierraChart\SierraChartTransAct\Transact\TransactToSierraBridge.exe | 2014-03-18 15:16:37 TransAct: Connecting to the server 127.0.0.1. Port 5023 | 2014-03-18 15:16:39 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-03-18 15:16:42 Socket has been shutdown and closed. | 2014-03-18 15:16:42 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-18 15:16:42 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-18 15:16:42 TransAct: Disconnected from the server. | 2014-03-18 15:16:42 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-18 15:16:42 TransAct - Starting server: C:\SierraChart\SierraChartTransAct\Transact\TransactToSierraBridge.exe | 2014-03-18 15:16:44 TransAct: Connecting to the server 127.0.0.1. Port 5023 | 2014-03-18 15:16:46 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-03-18 15:16:50 Socket has been shutdown and closed. | 2014-03-18 15:16:50 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-18 15:16:50 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-18 15:16:50 TransAct: Disconnected from the server. | 2014-03-18 15:16:50 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-18 15:16:50 File >> Disconnect selected. | 2014-03-18 15:16:51 TransAct: Disconnected from the server. | 2014-03-18 15:16:51 TransAct - Starting server: C:\SierraChart\SierraChartTransAct\Transact\TransactToSierraBridge.exe | 2014-03-18 15:16:54 TransAct: Connecting to the server 127.0.0.1. Port 5023 | 2014-03-18 15:16:56 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-03-18 15:17:00 Socket has been shutdown and closed. | 2014-03-18 15:17:00 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-18 15:17:00 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-18 15:17:00 TransAct: Disconnected from the server. | 2014-03-18 15:17:00 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-18 15:17:00 TransAct - Starting server: C:\SierraChart\SierraChartTransAct\Transact\TransactToSierraBridge.exe | 2014-03-18 15:17:02 TransAct: Connecting to the server 127.0.0.1. Port 5023 | 2014-03-18 15:17:04 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-03-18 15:17:07 Socket has been shutdown and closed. | 2014-03-18 15:17:07 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-18 15:17:07 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-18 15:17:07 TransAct: Disconnected from the server. | 2014-03-18 15:17:07 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-18 15:17:07 TransAct - Starting server: C:\SierraChart\SierraChartTransAct\Transact\TransactToSierraBridge.exe | 2014-03-18 15:17:09 TransAct: Connecting to the server 127.0.0.1. Port 5023 | 2014-03-18 15:17:11 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-03-18 15:17:15 Socket has been shutdown and closed. | 2014-03-18 15:17:15 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-18 15:17:15 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-18 15:17:15 TransAct: Disconnected from the server. | 2014-03-18 15:17:15 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-18 15:17:15 TransAct - Starting server: C:\SierraChart\SierraChartTransAct\Transact\TransactToSierraBridge.exe | 2014-03-18 15:17:17 TransAct: Connecting to the server 127.0.0.1. Port 5023 | 2014-03-18 15:17:19 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-03-18 15:17:22 Socket has been shutdown and closed. | 2014-03-18 15:17:22 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-18 15:17:22 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-18 15:17:22 TransAct: Disconnected from the server. | 2014-03-18 15:17:22 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-18 15:17:22 TransAct - Starting server: C:\SierraChart\SierraChartTransAct\Transact\TransactToSierraBridge.exe | 2014-03-18 15:17:24 TransAct: Connecting to the server 127.0.0.1. Port 5023 | 2014-03-18 15:17:26 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-03-18 15:17:30 Socket has been shutdown and closed. | 2014-03-18 15:17:30 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-18 15:17:30 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-18 15:17:30 TransAct: Disconnected from the server. | 2014-03-18 15:17:30 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-18 15:17:30 TransAct - Starting server: C:\SierraChart\SierraChartTransAct\Transact\TransactToSierraBridge.exe | 2014-03-18 15:17:32 TransAct: Connecting to the server 127.0.0.1. Port 5023 | 2014-03-18 15:17:34 File >> Disconnect selected. | 2014-03-18 15:17:36 Socket has been shutdown and closed. | 2014-03-18 15:17:36 TransAct: Disconnected from the server. | 2014-03-18 15:17:36 Current selected Data/Trading service: TransAct | 2014-03-18 15:17:52 TransAct - Starting server: C:\SierraChart\SierraChartTransAct\Transact\TransactToSierraBridge.exe | 2014-03-18 15:17:54 TransAct: Connecting to the server 127.0.0.1. Port 2453 | 2014-03-18 15:17:56 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-03-18 15:18:00 Socket has been shutdown and closed. | 2014-03-18 15:18:00 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-18 15:18:00 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-18 15:18:00 TransAct: Disconnected from the server. | 2014-03-18 15:18:00 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-18 15:18:00 TransAct - Starting server: C:\SierraChart\SierraChartTransAct\Transact\TransactToSierraBridge.exe | 2014-03-18 15:18:02 TransAct: Connecting to the server 127.0.0.1. Port 2453 | 2014-03-18 15:18:04 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-03-18 15:18:07 Socket has been shutdown and closed. | 2014-03-18 15:18:07 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-18 15:18:07 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-18 15:18:07 TransAct: Disconnected from the server. | 2014-03-18 15:18:07 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-18 15:18:07 TransAct - Starting server: C:\SierraChart\SierraChartTransAct\Transact\TransactToSierraBridge.exe | 2014-03-18 15:18:09 TransAct: Connecting to the server 127.0.0.1. Port 2453 | 2014-03-18 15:18:11 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-03-18 15:18:15 Socket has been shutdown and closed. | 2014-03-18 15:18:15 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-18 15:18:15 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-18 15:18:15 TransAct: Disconnected from the server. | 2014-03-18 15:18:15 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-18 15:18:15 TransAct - Starting server: C:\SierraChart\SierraChartTransAct\Transact\TransactToSierraBridge.exe | 2014-03-18 15:18:17 TransAct: Connecting to the server 127.0.0.1. Port 2453 | 2014-03-18 15:18:19 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-03-18 15:18:23 Socket has been shutdown and closed. | 2014-03-18 15:18:23 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-18 15:18:23 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-18 15:18:23 TransAct: Disconnected from the server. | 2014-03-18 15:18:23 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-18 15:18:23 TransAct - Starting server: C:\SierraChart\SierraChartTransAct\Transact\TransactToSierraBridge.exe | 2014-03-18 15:18:25 TransAct: Connecting to the server 127.0.0.1. Port 2453 | 2014-03-18 15:18:27 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-03-18 15:18:30 Socket has been shutdown and closed. | 2014-03-18 15:18:30 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-18 15:18:30 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-18 15:18:30 TransAct: Disconnected from the server. | 2014-03-18 15:18:30 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-18 15:18:30 TransAct - Starting server: C:\SierraChart\SierraChartTransAct\Transact\TransactToSierraBridge.exe | 2014-03-18 15:18:32 TransAct: Connecting to the server 127.0.0.1. Port 2453 | 2014-03-18 15:18:34 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-03-18 15:18:38 Socket has been shutdown and closed. | 2014-03-18 15:18:38 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-18 15:18:38 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-18 15:18:38 TransAct: Disconnected from the server. | 2014-03-18 15:18:38 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-18 15:18:38 TransAct - Starting server: C:\SierraChart\SierraChartTransAct\Transact\TransactToSierraBridge.exe | 2014-03-18 15:18:40 TransAct: Connecting to the server 127.0.0.1. Port 2453 | 2014-03-18 15:18:42 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-03-18 15:18:45 Socket has been shutdown and closed. | 2014-03-18 15:18:45 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-18 15:18:45 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-18 15:18:45 TransAct: Disconnected from the server. | 2014-03-18 15:18:45 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-18 15:18:45 TransAct - Starting server: C:\SierraChart\SierraChartTransAct\Transact\TransactToSierraBridge.exe | 2014-03-18 15:18:47 TransAct: Connecting to the server 127.0.0.1. Port 2453 | 2014-03-18 15:18:49 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-03-18 15:18:53 Socket has been shutdown and closed. | 2014-03-18 15:18:53 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-18 15:18:53 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-18 15:18:53 TransAct: Disconnected from the server. | 2014-03-18 15:18:53 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-18 15:18:53 TransAct - Starting server: C:\SierraChart\SierraChartTransAct\Transact\TransactToSierraBridge.exe | 2014-03-18 15:18:55 TransAct: Connecting to the server 127.0.0.1. Port 2453 | 2014-03-18 15:18:57 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-03-18 15:19:00 Socket has been shutdown and closed. | 2014-03-18 15:19:00 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-18 15:19:00 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-18 15:19:00 TransAct: Disconnected from the server. | 2014-03-18 15:19:00 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-18 15:19:00 TransAct - Starting server: C:\SierraChart\SierraChartTransAct\Transact\TransactToSierraBridge.exe | 2014-03-18 15:19:02 TransAct: Connecting to the server 127.0.0.1. Port 2453 | 2014-03-18 15:19:04 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-03-18 15:19:08 Socket has been shutdown and closed. | 2014-03-18 15:19:08 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-18 15:19:08 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-18 15:19:08 TransAct: Disconnected from the server. | 2014-03-18 15:19:08 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-18 15:19:08 TransAct - Starting server: C:\SierraChart\SierraChartTransAct\Transact\TransactToSierraBridge.exe | 2014-03-18 15:19:10 TransAct: Connecting to the server 127.0.0.1. Port 2453 | 2014-03-18 15:19:12 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-03-18 15:19:16 Socket has been shutdown and closed. | 2014-03-18 15:19:16 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-18 15:19:16 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-18 15:19:16 TransAct: Disconnected from the server. | 2014-03-18 15:19:16 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-18 15:19:16 TransAct - Starting server: C:\SierraChart\SierraChartTransAct\Transact\TransactToSierraBridge.exe | 2014-03-18 15:19:18 TransAct: Connecting to the server 127.0.0.1. Port 2453 | 2014-03-18 15:19:20 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-03-18 15:19:23 Socket has been shutdown and closed. | 2014-03-18 15:19:23 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-18 15:19:23 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-18 15:19:23 TransAct: Disconnected from the server. | 2014-03-18 15:19:23 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-18 15:19:23 TransAct - Starting server: C:\SierraChart\SierraChartTransAct\Transact\TransactToSierraBridge.exe | 2014-03-18 15:19:25 TransAct: Connecting to the server 127.0.0.1. Port 2453 | 2014-03-18 15:19:27 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-03-18 15:19:31 Socket has been shutdown and closed. | 2014-03-18 15:19:31 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-18 15:19:31 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-18 15:19:31 TransAct: Disconnected from the server. | 2014-03-18 15:19:31 Will reconnect to the server in 35.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-18 15:19:31 TransAct - Starting server: C:\SierraChart\SierraChartTransAct\Transact\TransactToSierraBridge.exe | 2014-03-18 15:20:06 TransAct: Connecting to the server 127.0.0.1. Port 2453 | 2014-03-18 15:20:08 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-03-18 15:20:11 Socket has been shutdown and closed. | 2014-03-18 15:20:11 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-18 15:20:11 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-18 15:20:11 TransAct: Disconnected from the server. | 2014-03-18 15:20:11 Will reconnect to the server in 40.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-18 15:20:11 File >> Disconnect selected. | 2014-03-18 15:20:26 TransAct: Disconnected from the server. | 2014-03-18 15:20:26 TransAct - Starting server: C:\SierraChart\SierraChartTransAct\Transact\TransactToSierraBridge.exe | 2014-03-18 15:20:30 TransAct: Connecting to the server 127.0.0.1. Port 2453 | 2014-03-18 15:20:32 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-03-18 15:20:36 Socket has been shutdown and closed. | 2014-03-18 15:20:36 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-18 15:20:36 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-18 15:20:36 TransAct: Disconnected from the server. | 2014-03-18 15:20:36 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-18 15:20:36 TransAct - Starting server: C:\SierraChart\SierraChartTransAct\Transact\TransactToSierraBridge.exe | 2014-03-18 15:20:38 TransAct: Connecting to the server 127.0.0.1. Port 2453 | 2014-03-18 15:20:40 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-03-18 15:20:43 Socket has been shutdown and closed. | 2014-03-18 15:20:43 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-18 15:20:43 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-18 15:20:43 TransAct: Disconnected from the server. | 2014-03-18 15:20:43 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-18 15:20:43 TransAct - Starting server: C:\SierraChart\SierraChartTransAct\Transact\TransactToSierraBridge.exe | 2014-03-18 15:20:45 TransAct: Connecting to the server 127.0.0.1. Port 2453 | 2014-03-18 15:20:47 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-03-18 15:20:51 Socket has been shutdown and closed. | 2014-03-18 15:20:51 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-18 15:20:51 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-18 15:20:51 TransAct: Disconnected from the server. | 2014-03-18 15:20:51 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-18 15:20:51 TransAct - Starting server: C:\SierraChart\SierraChartTransAct\Transact\TransactToSierraBridge.exe | 2014-03-18 15:20:53 TransAct: Connecting to the server 127.0.0.1. Port 2453 | 2014-03-18 15:20:55 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-03-18 15:20:58 Socket has been shutdown and closed. | 2014-03-18 15:20:58 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-18 15:20:58 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-18 15:20:58 TransAct: Disconnected from the server. | 2014-03-18 15:20:58 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-18 15:20:58 TransAct - Starting server: C:\SierraChart\SierraChartTransAct\Transact\TransactToSierraBridge.exe | 2014-03-18 15:21:00 TransAct: Connecting to the server 127.0.0.1. Port 2453 | 2014-03-18 15:21:02 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-03-18 15:21:06 Socket has been shutdown and closed. | 2014-03-18 15:21:06 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-18 15:21:06 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-18 15:21:06 TransAct: Disconnected from the server. | 2014-03-18 15:21:06 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-18 15:21:06 TransAct - Starting server: C:\SierraChart\SierraChartTransAct\Transact\TransactToSierraBridge.exe | 2014-03-18 15:21:08 TransAct: Connecting to the server 127.0.0.1. Port 2453 | 2014-03-18 15:21:10 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-03-18 15:21:14 Socket has been shutdown and closed. | 2014-03-18 15:21:14 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-18 15:21:14 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-18 15:21:14 TransAct: Disconnected from the server. | 2014-03-18 15:21:14 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-18 15:21:14 TransAct - Starting server: C:\SierraChart\SierraChartTransAct\Transact\TransactToSierraBridge.exe | 2014-03-18 15:21:16 TransAct: Connecting to the server 127.0.0.1. Port 2453 | 2014-03-18 15:21:18 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-03-18 15:21:21 Socket has been shutdown and closed. | 2014-03-18 15:21:21 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-18 15:21:21 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-18 15:21:21 TransAct: Disconnected from the server. | 2014-03-18 15:21:21 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-18 15:21:21 TransAct - Starting server: C:\SierraChart\SierraChartTransAct\Transact\TransactToSierraBridge.exe | 2014-03-18 15:21:23 TransAct: Connecting to the server 127.0.0.1. Port 2453 | 2014-03-18 15:21:25 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-03-18 15:21:29 Socket has been shutdown and closed. | 2014-03-18 15:21:29 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-18 15:21:29 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-18 15:21:29 TransAct: Disconnected from the server. | 2014-03-18 15:21:29 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-18 15:21:29 TransAct - Starting server: C:\SierraChart\SierraChartTransAct\Transact\TransactToSierraBridge.exe | 2014-03-18 15:21:31 TransAct: Connecting to the server 127.0.0.1. Port 2453 | 2014-03-18 15:21:33 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-03-18 15:21:36 Socket has been shutdown and closed. | 2014-03-18 15:21:36 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-18 15:21:36 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-18 15:21:36 TransAct: Disconnected from the server. | 2014-03-18 15:21:36 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-18 15:21:36 TransAct - Starting server: C:\SierraChart\SierraChartTransAct\Transact\TransactToSierraBridge.exe | 2014-03-18 15:21:38 TransAct: Connecting to the server 127.0.0.1. Port 2453 | 2014-03-18 15:21:40 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-03-18 15:21:44 Socket has been shutdown and closed. | 2014-03-18 15:21:44 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-18 15:21:44 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-18 15:21:44 TransAct: Disconnected from the server. | 2014-03-18 15:21:44 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-18 15:21:44 TransAct - Starting server: C:\SierraChart\SierraChartTransAct\Transact\TransactToSierraBridge.exe | 2014-03-18 15:21:46 TransAct: Connecting to the server 127.0.0.1. Port 2453 | 2014-03-18 15:21:48 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-03-18 15:21:51 Socket has been shutdown and closed. | 2014-03-18 15:21:51 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-18 15:21:51 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-18 15:21:51 TransAct: Disconnected from the server. | 2014-03-18 15:21:51 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-18 15:21:51 TransAct - Starting server: C:\SierraChart\SierraChartTransAct\Transact\TransactToSierraBridge.exe | 2014-03-18 15:21:53 TransAct: Connecting to the server 127.0.0.1. Port 2453 | 2014-03-18 15:21:55 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-03-18 15:21:59 Socket has been shutdown and closed. | 2014-03-18 15:21:59 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-18 15:21:59 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-18 15:21:59 TransAct: Disconnected from the server. | 2014-03-18 15:21:59 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-18 15:21:59 TransAct - Starting server: C:\SierraChart\SierraChartTransAct\Transact\TransactToSierraBridge.exe | 2014-03-18 15:22:01 TransAct: Connecting to the server 127.0.0.1. Port 2453 | 2014-03-18 15:22:03 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-03-18 15:22:07 Socket has been shutdown and closed. | 2014-03-18 15:22:07 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-18 15:22:07 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-18 15:22:07 TransAct: Disconnected from the server. | 2014-03-18 15:22:07 Will reconnect to the server in 35.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-18 15:22:07 TransAct - Starting server: C:\SierraChart\SierraChartTransAct\Transact\TransactToSierraBridge.exe | 2014-03-18 15:22:42 TransAct: Connecting to the server 127.0.0.1. Port 2453 | 2014-03-18 15:22:44 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-03-18 15:22:47 Socket has been shutdown and closed. | 2014-03-18 15:22:47 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-18 15:22:47 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-18 15:22:47 TransAct: Disconnected from the server. | 2014-03-18 15:22:47 Will reconnect to the server in 40.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-18 15:22:47 TransAct - Starting server: C:\SierraChart\SierraChartTransAct\Transact\TransactToSierraBridge.exe | 2014-03-18 15:23:27 TransAct: Connecting to the server 127.0.0.1. Port 2453 | 2014-03-18 15:23:29 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-03-18 15:23:33 Socket has been shutdown and closed. | 2014-03-18 15:23:33 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-18 15:23:33 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-18 15:23:33 TransAct: Disconnected from the server. | 2014-03-18 15:23:33 Will reconnect to the server in 40.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-18 15:23:33 TransAct - Starting server: C:\SierraChart\SierraChartTransAct\Transact\TransactToSierraBridge.exe | 2014-03-18 15:24:13 TransAct: Connecting to the server 127.0.0.1. Port 2453 | 2014-03-18 15:24:15 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-03-18 15:24:18 Socket has been shutdown and closed. | 2014-03-18 15:24:18 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-18 15:24:18 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-18 15:24:18 TransAct: Disconnected from the server. | 2014-03-18 15:24:18 Will reconnect to the server in 45.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-18 15:24:18 TransAct - Starting server: C:\SierraChart\SierraChartTransAct\Transact\TransactToSierraBridge.exe | 2014-03-18 15:25:03 TransAct: Connecting to the server 127.0.0.1. Port 2453 | 2014-03-18 15:25:05 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-03-18 15:25:09 Socket has been shutdown and closed. | 2014-03-18 15:25:09 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-18 15:25:09 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-18 15:25:09 TransAct: Disconnected from the server. | 2014-03-18 15:25:09 Will reconnect to the server in 45.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-18 15:25:09 TransAct - Starting server: C:\SierraChart\SierraChartTransAct\Transact\TransactToSierraBridge.exe | 2014-03-18 15:25:54 TransAct: Connecting to the server 127.0.0.1. Port 2453 | 2014-03-18 15:25:56 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-03-18 15:25:59 Socket has been shutdown and closed. | 2014-03-18 15:25:59 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-18 15:25:59 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-18 15:25:59 TransAct: Disconnected from the server. | 2014-03-18 15:25:59 Will reconnect to the server in 50.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-18 15:25:59 TransAct - Starting server: C:\SierraChart\SierraChartTransAct\Transact\TransactToSierraBridge.exe | 2014-03-18 15:26:49 TransAct: Connecting to the server 127.0.0.1. Port 2453 | 2014-03-18 15:26:52 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-03-18 15:26:55 Socket has been shutdown and closed. | 2014-03-18 15:26:55 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-18 15:26:55 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-18 15:26:55 TransAct: Disconnected from the server. | 2014-03-18 15:26:55 Will reconnect to the server in 50.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-18 15:26:55 |
[2014-03-18 21:34:16] |
We are checking on this now.
[2014-03-18 22:14:24] |
We have looked over the Message Log and have updated our documentation in this section here to explain what to do: https://www.sierrachart.com/index.php?l=doc/TransAct.php#BridgeConnectionError Our recommendation is to restart your computer. We see this message: NOTICE: Detected that the system has resumed from a low-power state. | 2014-03-18 15:16:09 This could be preventing the connection to the TransAct bridge process or the starting of that process, for some unknown reason. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
