Date/Time: Fri, 28 Feb 2025 18:08:55 +0000
micro crude, MCL
View Count: 784
[2021-07-13 18:23:11] |
arruga - Posts: 253 |
I'm with with IB. Can you provide guidance to add MCL symbol to my quoteboard?. Not available in the list via add symbol.
[2021-07-14 05:40:15] |
WheresMoney - Posts: 62 |
MCL-202108-NYMEX
[2021-07-14 06:11:56] |
Sierra_Chart Engineering - Posts: 18602 |
We will be setting up the correct symbol for this, before the morning. We just have to look up the precise details. It will be more of an extended format than that.
[2021-07-14 08:30:55] |
This has actually already been set up for Interactive Brokers but we updated the symbol. This is the new symbol format: MCL-######-NYMEX-USD Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings To convert the old symbol in existing charts, to the correct format use this command: Edit Menu: Edit >> Translate Symbols To Current Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-07-14 08:31:16
[2021-07-30 14:27:49] |
fxzen - Posts: 14 |
Hi, i'm still having trouble with this one for whatever reason. I have followed the instructions for updating a few times. I also tried updating to latest stable 2292. It works fine if I just connect to the SC service, but not if I use IB. I get the following error: Download Failed Error downloading historical Intraday data for MCL-202109-NYMEX-USD. Historical Market Data Service error message: HMDS query returned no data: MCLU1@NYMEX Trades. Thanks |
[2021-07-30 15:09:48] |
You need to activate the Nymex exchange from here: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-07-30 15:09:56
[2021-09-01 14:36:51] |
mattl - Posts: 5 |
Good morning. I am using the Denali datafeed with the Rithmic connection for one of my tryout accounts and am looking for access to MCL (Micro Crude). I updated to version > 2280, and followed the additional instructions as per the link below and still do not see the instrument: Denali Exchange Data Feed: Activate the Exchanges: The CME Group (Denali Exchange Data Feed Setup Instructions) Could you please let me know when it is avaliable? Thanks. |
