Date/Time: Mon, 21 Sep 2026 09:41:43 +0000
I already signed up with AMP Futures
View Count: 764
[2021-07-12 16:25:11]
ruby_kinetix - Posts: 29
Hi there, finally I already register with AMP futures, how can i connect the data ?
i am about to fund it soon. please advice. thank you .
ok, right now i will need Gold futures data, Forex (Euro/USD & GBP/USD) futures, and mini S&P.
later i will need m-Dax futures and US Stocks.
does AMP Futures support price data for Sierra or i must subscribe separately trough Sierra?
[2021-07-12 17:49:04]
John - SC Support - Posts: 47939
We need to understand the type of account you opened with AMP.
If you were following the information in the Easy Solution to CME Funded Trading Account Requirement, then follow these instructions to verify your account:
Easy Solution to CME Funded Trading Account Requirement: Instructions
If you have created a full trading account with AMP, then you were most likely setup with CQG for your order routing service, in which case you would follow these instructions to connect your Sierra Chart to your CQG account:
CQG Trading Platform Service: Setup Instructions
Once you have completed the above step (whichever one you need to do), then you would need to go through the setup instructions for the Denali Exchange Data Feed for the CME Group here:
For the future, when you want to add the EUREX data, you will follow these instructions:
https://www.sierrachart.com/index.php?page=doc/DenaliExchangeDataFeed.php#SetupInstructions_EUREX
When the time comes to add the U.S. Stock data, then check back with us on how to do that, as we are working on a new interface for the U.S. Stocks, which hopefully will be ready by the time you are.
