Date/Time: Tue, 26 Nov 2024 09:21:17 +0000
cash index
View Count: 1251
[2014-03-19 16:36:01] |
All we can say is the $DOWI is the Dow industrials cash index. When using the CQG Trading service, all of the available cash indexes can be found in now in File >> Find Symbol >> Indexes. If you do not see them listed, update the Global Symbol Settings as explained here: https://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php#UpdateSettings If you want the $DOWI to indicate profit/loss just like another symbol, then you need to make sure both the Tick Size and the Currency Value Per Tick exactly match that other symbol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-03-19 16:36:28
[2014-04-04 14:15:28] |
batman_ - Posts: 190 |
Hi Support, I have activated NYSE cash index. Kindly add the below symbol to CTS data trade/service:- a) $AXFI b) $AXTE c) $AXTH d) $AXTW Thank you. Date Time Of Last Edit: 2014-04-04 14:17:30
[2014-04-04 16:33:38] |
Yes we can do this. We will get to this next week.
[2014-04-08 01:52:58] |
Hi Support, I would like to get update from you in regard to NYSE cash index as requested on April 4th. Thank you for your support. |
[2014-04-08 02:41:38] |
These have been added. Restart Sierra Chart to see them listed.
[2014-04-10 16:48:27] |
$SURD will be added. We will check on the other symbol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-04-12 11:57:45] |
a) Have you found S&P GSCI Yen symbol on SC's S&P index yet? We do not see this. $SURD has been added. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-04-24 09:47:53] |
Hi Support, Can you add S&P cash index symbol for $SUDX to CTS data trade/service? Thank you. Date Time Of Last Edit: 2014-04-24 10:40:21
[2014-04-24 14:36:19] |
Yes. Please allow about two days.
