Date/Time: Fri, 28 Feb 2025 18:28:35 +0000
Denali Datafeed
View Count: 1137
[2021-07-06 16:16:04]
User76183 - Posts: 69
Hello! I have paid , signed and activated Denali feed ,but when I connect my SC I still have the delayed data. Pls check it.
[2021-07-06 18:06:27]
John - SC Support - Posts: 38280
Everything on your account looks good. Get us your Message Log by following these instructions:
Open a chart for the symbol you have an issue with. Tell us that symbol of the chart.
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
[2021-07-07 10:13:33]
Software version: 2282 64-bit | 2021-07-07 10:09:59.304
Primary Thread ID: 5828 | 2021-07-07 10:09:59.304
Usage end date: 2021-09-03 | 2021-07-07 10:09:59.304
Enabled for: Advanced Features 2. | 2021-07-07 10:09:59.304
Enabled for: Sierra Chart Historical Data Service. | 2021-07-07 10:09:59.304
Enabled for: Denali Real-Time Exchange Data Feed. | 2021-07-07 10:09:59.304
Enabled for: Delayed Denali Exchange Data Feed. | 2021-07-07 10:09:59.304
Enabled for exchange2: CME (Trading Account Required) | 2021-07-07 10:09:59.304
Enabled for exchange2: CBOT (Trading Account Required) | 2021-07-07 10:09:59.304
Enabled for exchange2: COMEX (Trading Account Required) | 2021-07-07 10:09:59.304
Enabled for exchange2: NYMEX (Trading Account Required) | 2021-07-07 10:09:59.304
Allow Support for Sierra Chart Data Feeds is enabled. | 2021-07-07 10:09:59.304
Current selected Data/Trading service: SC Data - All Services | 2021-07-07 10:09:59.304
Custom symbol settings values: enabled | 2021-07-07 10:09:59.304
Chart Update Interval: 500 | 2021-07-07 10:09:59.304
Intraday Data Storage Time Unit: 0 | 2021-07-07 10:09:59.304
Time Zone: +00:00:00 (UTC+00) | 2021-07-07 10:09:59.304
2021-07-07 10:09:59 Local computer time in UTC | 2021-07-07 10:09:59.304
2021-07-07 10:09:59 Local computer time in SC Time Zone | 2021-07-07 10:09:59.304
2021-07-07 10:01:26 Server time in UTC | 2021-07-07 10:09:59.304
Local computer UTC time and Server UTC time difference: 12 seconds. | 2021-07-07 10:09:59.304
Notice: Your computer's clock is off by 12 seconds. For help with this, press the 'Send for Analysis' button. | 2021-07-07 10:09:59.304
Program path: D:\SierraChart\ | 2021-07-07 10:09:59.304
Data Files path: D:\SierraChart\Data\ | 2021-07-07 10:09:59.304
OS Version Number: 10.0 | 2021-07-07 10:09:59.304
Locale Setting: C | 2021-07-07 10:09:59.304
DLLs: sst_FreeBundle.dll, sst_FreeBundle_2151.dll, sst_FreeBundle_2151_64.dll, sst_FreeBundle_64.dll, sst_syx_2151_64.dll, sst_syx_64.dll, TicinoMathV2.0.dll, TicinoMathV2.0_64.dll, TicinoMathV3.0.dll, TicinoMathV3.0_2151.dll, TicinoMathV3.0_2151_64.dll, TicinoMathV3.0_64.dll, TicinoMath_Scanner.dll, TicinoMath_Scanner_2151.dll, TicinoMath_Scanner_2151_64.dll, TicinoMath_Scanner_64.dll, TicinoSuite_64.dll, UserContributedStudies_64.dll | 2021-07-07 10:09:59.304
Allowed protected custom studies: SST_Syx, TicinoMathScanner DLL, TicinoMathV2.0.DLL, TicinoMathV3.0.DLL, TicinoSuite | 2021-07-07 10:09:59.304
SC Data - All Services | Connecting to the server ds13.sierracharts.com. Port 10048 | 2021-07-07 10:10:22.998
DTC Client socket (1) | Creating socket. | 2021-07-07 10:10:22.999
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-07-07 10:10:22.999
DTC Client socket (1) | Connecting to IP: 64.38.174.178. | 2021-07-07 10:10:22.999
SC Data - All Services | Network connection to server complete. | 2021-07-07 10:10:23.160
SC Data - All Services | Starting socket receive thread. | 2021-07-07 10:10:23.160
SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-07-07 10:10:23.160
SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-07-07 10:10:23.367
SC Data - All Services | Sending logon request message. | 2021-07-07 10:10:23.367
SC Data - All Services | Received logon response. | 2021-07-07 10:10:24.383
SC Data - All Services | Server Name: SC Real-Time Server. | 2021-07-07 10:10:24.383
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-07-07 10:10:24.383
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-07-07 10:10:24.383
SC Data - All Services | Waiting for socket receive thread to end | 2021-07-07 10:10:24.383
DTC Client socket (1) | CloseSocket call. | 2021-07-07 10:10:24.383
SC Data - All Services | Disconnected from the server. | 2021-07-07 10:10:24.383
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-07-07 10:10:24.383
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-07-07 10:10:24.383
DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-07-07 10:10:24.543
DTC Client socket (1) | Closed. | 2021-07-07 10:10:24.543
Chart #5 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2021-07-07 10:10:25.603
Chart #5 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2021-07-07 10:10:25.866
Chart #5 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2021-07-07 10:10:26.366
Chart #5 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2021-07-07 10:10:26.860
Chart #5 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2021-07-07 10:10:27.370
Chart #5 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2021-07-07 10:10:27.871
Chart #5 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2021-07-07 10:10:28.361
Chart #5 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2021-07-07 10:10:28.872
Chart #5 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2021-07-07 10:10:29.363
Chart #5 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2021-07-07 10:10:29.862
Chart #5 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2021-07-07 10:10:30.365
Chart #5 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2021-07-07 10:10:30.859
Chart #5 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2021-07-07 10:10:31.362
Array message repeat count limit reached. | 2021-07-07 10:10:31.362
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10048 | 2021-07-07 10:10:54.381
DTC Client socket (1) | Creating socket. | 2021-07-07 10:10:54.382
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-07-07 10:10:54.382
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2021-07-07 10:10:54.382
SC Data - All Services | Network connection to server complete. | 2021-07-07 10:10:54.611
SC Data - All Services | Starting socket receive thread. | 2021-07-07 10:10:54.611
SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-07-07 10:10:54.611
SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-07-07 10:10:54.856
SC Data - All Services | Sending logon request message. | 2021-07-07 10:10:54.856
SC Data - All Services | Received logon response. | 2021-07-07 10:10:55.747
SC Data - All Services | Server Name: SC Real-Time Server. | 2021-07-07 10:10:55.747
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-07-07 10:10:55.747
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-07-07 10:10:55.747
SC Data - All Services | Waiting for socket receive thread to end | 2021-07-07 10:10:55.747
DTC Client socket (1) | CloseSocket call. | 2021-07-07 10:10:55.748
SC Data - All Services | Disconnected from the server. | 2021-07-07 10:10:55.748
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-07-07 10:10:55.748
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-07-07 10:10:55.748
DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-07-07 10:10:55.975
DTC Client socket (1) | Closed. | 2021-07-07 10:10:55.975
File >> Disconnect selected. | 2021-07-07 10:11:05.111
DTC Client socket (0) | CloseSocket call. | 2021-07-07 10:11:05.140
SC Data - All Services | Disconnected from the server. | 2021-07-07 10:11:05.140
SC Data - All Services | Disconnected. | 2021-07-07 10:11:05.140
SC Data - All Services | Connected to server complete. | 2021-07-07 10:11:11.651
Triggering next historical data download in queue. | 2021-07-07 10:11:11.651
No download requests in the queue to start downloads for. | 2021-07-07 10:11:11.678
Mapping ESZ20 to ESZ20. Service code: cme | 2021-07-07 10:11:11.679
SC Data - All Services | Starting real-time market data updates for: ESZ20 (ESZ20). ID: 1 Service code: cme | 2021-07-07 10:11:11.679
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 443 | 2021-07-07 10:11:11.679
SC Data - All Services | Requesting security definition data for: ESZ20 (ESZ20). ID: 1 | 2021-07-07 10:11:11.679
Added historical Intraday data request for ESZ20 to the queue. | 2021-07-07 10:11:11.679
Intraday data recording state for symbol ESZ20 is set to download 'Pending'. | 2021-07-07 10:11:11.679
Triggering next historical data download in queue. | 2021-07-07 10:11:11.679
Delaying start of download for ESZ20 | 2021-07-07 10:11:11.679
Mapping ESU21-CME to ESU21. Service code: cme | 2021-07-07 10:11:11.679
SC Data - All Services | Starting real-time market data updates for: ESU21-CME (ESU21). ID: 2 Service code: cme | 2021-07-07 10:11:11.679
SC Data - All Services | Requesting security definition data for: ESU21-CME (ESU21). ID: 2 | 2021-07-07 10:11:11.679
DTC Client socket (1) | Creating socket. | 2021-07-07 10:11:11.679
Added historical Intraday data request for ESU21-CME to the queue. | 2021-07-07 10:11:11.679
Intraday data recording state for symbol ESU21-CME is set to download 'Pending'. | 2021-07-07 10:11:11.679
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-07-07 10:11:11.679
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2021-07-07 10:11:11.679
Mapping NQU21-CME to NQU21. Service code: cme | 2021-07-07 10:11:11.710
SC Data - All Services | Starting real-time market data updates for: NQU21-CME (NQU21). ID: 3 Service code: cme | 2021-07-07 10:11:11.710
SC Data - All Services | Requesting security definition data for: NQU21-CME (NQU21). ID: 3 | 2021-07-07 10:11:11.710
Added historical Intraday data request for NQU21-CME to the queue. | 2021-07-07 10:11:11.710
Intraday data recording state for symbol NQU21-CME is set to download 'Pending'. | 2021-07-07 10:11:11.710
Triggering next historical data download in queue. | 2021-07-07 10:11:11.710
Mapping GCQ21-COMEX to GCQ21. Service code: comex | 2021-07-07 10:11:11.810
SC Data - All Services | Starting real-time market data updates for: GCQ21-COMEX (GCQ21). ID: 4 Service code: comex | 2021-07-07 10:11:11.811
SC Data - All Services | Requesting security definition data for: GCQ21-COMEX (GCQ21). ID: 4 | 2021-07-07 10:11:11.811
Added historical Intraday data request for GCQ21-COMEX to the queue. | 2021-07-07 10:11:11.811
Intraday data recording state for symbol GCQ21-COMEX is set to download 'Pending'. | 2021-07-07 10:11:11.811
Triggering next historical data download in queue. | 2021-07-07 10:11:11.811
Mapping RTYU21-CME to RTYU21. Service code: cme | 2021-07-07 10:11:11.842
SC Data - All Services | Starting real-time market data updates for: RTYU21-CME (RTYU21). ID: 5 Service code: cme | 2021-07-07 10:11:11.843
SC Data - All Services | Requesting security definition data for: RTYU21-CME (RTYU21). ID: 5 | 2021-07-07 10:11:11.843
Added historical Intraday data request for RTYU21-CME to the queue. | 2021-07-07 10:11:11.843
Intraday data recording state for symbol RTYU21-CME is set to download 'Pending'. | 2021-07-07 10:11:11.843
Triggering next historical data download in queue. | 2021-07-07 10:11:11.843
SC Data - All Services | Network connection to server complete. | 2021-07-07 10:11:11.970
SC Data - All Services | Starting socket receive thread. | 2021-07-07 10:11:11.970
SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-07-07 10:11:11.970
Requesting market depth updates for: NQU21-CME if supported. | 2021-07-07 10:11:11.973
Separate subscription for market depth updates not supported. NQU21-CME | 2021-07-07 10:11:11.973
Requesting market depth updates for: RTYU21-CME if supported. | 2021-07-07 10:11:11.983
Separate subscription for market depth updates not supported. RTYU21-CME | 2021-07-07 10:11:11.983
Mapping GCM21-COMEX to GCM21. Service code: comex | 2021-07-07 10:11:11.989
SC Data - All Services | Starting real-time market data updates for: GCM21-COMEX (GCM21). ID: 6 Service code: comex | 2021-07-07 10:11:11.989
SC Data - All Services | Requesting security definition data for: GCM21-COMEX (GCM21). ID: 6 | 2021-07-07 10:11:11.989
Added historical Intraday data request for GCM21-COMEX to the queue. | 2021-07-07 10:11:11.989
Intraday data recording state for symbol GCM21-COMEX is set to download 'Pending'. | 2021-07-07 10:11:11.989
Triggering next historical data download in queue. | 2021-07-07 10:11:11.989
Requesting market depth updates for: ESU21-CME if supported. | 2021-07-07 10:11:12.177
Separate subscription for market depth updates not supported. ESU21-CME | 2021-07-07 10:11:12.177
SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-07-07 10:11:12.223
SC Data - All Services | Sending logon request message. | 2021-07-07 10:11:12.223
SC Data - All Services | Received logon response. | 2021-07-07 10:11:13.113
SC Data - All Services | Server Name: SC Real-Time Server. | 2021-07-07 10:11:13.113
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-07-07 10:11:13.113
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-07-07 10:11:13.113
SC Data - All Services | Waiting for socket receive thread to end | 2021-07-07 10:11:13.113
DTC Client socket (1) | CloseSocket call. | 2021-07-07 10:11:13.113
SC Data - All Services | Disconnected from the server. | 2021-07-07 10:11:13.113
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-07-07 10:11:13.113
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-07-07 10:11:13.113
DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-07-07 10:11:13.337
DTC Client socket (1) | Closed. | 2021-07-07 10:11:13.337
Requesting market depth updates for: ESZ20 if supported. | 2021-07-07 10:11:16.636
Separate subscription for market depth updates not supported. ESZ20 | 2021-07-07 10:11:16.636
HD Request # 15 | Downloading Intraday chart data for ESZ20 to the file ESZ20.scid. Service: cme | 2021-07-07 10:11:42.071
HD Request # 15 | Download start date-time: 2020-12-21 23:59:59.000000. File last date-time: 2020-12-18 14:29:59.953003 | 2021-07-07 10:11:42.071
HD Request # 15 | Using server: ds23.sierracharts.com port 10149 | 2021-07-07 10:11:42.072
Socket (1) | Creating socket. | 2021-07-07 10:11:42.072
Socket (1) | New receive buffer size: 5242880 | 2021-07-07 10:11:42.072
Socket (1) | Connecting to IP: 216.1.90.130. | 2021-07-07 10:11:42.072
HD Request # 15 | Setting DTC encoding to Binary VLS | 2021-07-07 10:11:42.542
HD Request # 15 | Sending historical data logon request message. | 2021-07-07 10:11:42.542
SC Data - All Services | Connecting to the server ds13.sierracharts.com. Port 443 | 2021-07-07 10:11:43.108
DTC Client socket (2) | Creating socket. | 2021-07-07 10:11:43.109
DTC Client socket (2) | New receive buffer size: 5242880 | 2021-07-07 10:11:43.109
DTC Client socket (2) | Connecting to IP: 64.38.174.178. | 2021-07-07 10:11:43.109
HD Request # 15 | Requesting Intraday data. Start date-time: 2020-12-21 23:59:59. Record interval: 0. Symbol: ESZ20 | 2021-07-07 10:11:43.232
SC Data - All Services | Network connection to server complete. | 2021-07-07 10:11:43.268
SC Data - All Services | Starting socket receive thread. | 2021-07-07 10:11:43.268
SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-07-07 10:11:43.268
SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-07-07 10:11:43.436
SC Data - All Services | Sending logon request message. | 2021-07-07 10:11:43.436
HD Request # 15 | Decompressing data. | 2021-07-07 10:11:43.464
HD Request # 15 | Receiving Intraday data for ESZ20 starting at 2020-12-18 13:49:21.771000 | 2021-07-07 10:11:43.759
Socket (1) | CloseSocket call. | 2021-07-07 10:11:43.760
Socket (1) | Shutdown started. Waiting for graceful close. | 2021-07-07 10:11:43.760
Historical data download thread signaled to stop. | 2021-07-07 10:11:43.760
HD Request # 15 | Received 2595 records from 2020-12-18 13:49:21.771000 to 2020-12-18 14:29:59.953003 (40.6 minutes) and wrote 0 records for ESZ20 | 2021-07-07 10:11:43.760
HD Request # 15 | Add time&sales data | Remembered last file record date-time: 2020-12-18 14:29:59.953003 | 2021-07-07 10:11:43.760
HD Request # 15 | Completion time: 1s | 2021-07-07 10:11:43.760
HD Request # 15 | Intraday data download complete for ESZ20. Unique request ID: 15 | 2021-07-07 10:11:43.760
Removing historical data download ID 15. | 2021-07-07 10:11:43.760
Real-time Intraday chart data file updates started for ESZ20 | 2021-07-07 10:11:43.760
Intraday chart data file opened for ESZ20 | 2021-07-07 10:11:43.760
HD Request # 15 | Enabling Intraday chart updating for symbol. | 2021-07-07 10:11:43.760
Triggering next historical data download in queue. | 2021-07-07 10:11:43.760
HD Request # 16 | Downloading Intraday chart data for ESU21-CME to the file ESU21-CME.scid. Service: cme | 2021-07-07 10:11:43.760
HD Request # 16 | Download start date-time: 2021-07-07 10:02:39.000000. File last date-time: 2021-07-07 10:02:39.368000 | 2021-07-07 10:11:43.760
HD Request # 16 | Using server: ds21.sierracharts.com port 10150 | 2021-07-07 10:11:43.760
Socket (3) | Creating socket. | 2021-07-07 10:11:43.761
Socket (3) | New receive buffer size: 5242880 | 2021-07-07 10:11:43.761
Socket (3) | Connecting to IP: 216.1.90.129. | 2021-07-07 10:11:43.761
Socket (1) | Socket gracefully closed by remote side. | 2021-07-07 10:11:43.991
Socket (1) | Closed. | 2021-07-07 10:11:43.991
HD Request # 16 | Setting DTC encoding to Binary VLS | 2021-07-07 10:11:44.221
HD Request # 16 | Sending historical data logon request message. | 2021-07-07 10:11:44.221
SC Data - All Services | Received logon response. | 2021-07-07 10:11:44.469
SC Data - All Services | Server Name: SC Real-Time Server. | 2021-07-07 10:11:44.469
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-07-07 10:11:44.469
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-07-07 10:11:44.469
SC Data - All Services | Waiting for socket receive thread to end | 2021-07-07 10:11:44.469
DTC Client socket (2) | CloseSocket call. | 2021-07-07 10:11:44.469
SC Data - All Services | Disconnected from the server. | 2021-07-07 10:11:44.469
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-07-07 10:11:44.469
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-07-07 10:11:44.469
DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-07-07 10:11:44.626
DTC Client socket (2) | Closed. | 2021-07-07 10:11:44.626
HD Request # 16 | Requesting Intraday data. Start date-time: 2021-07-07 10:02:39. Record interval: 0. Symbol: ESU21 | 2021-07-07 10:11:44.903
HD Request # 16 | Decompressing data. | 2021-07-07 10:11:45.131
HD Request # 16 | Receiving Intraday data for ESU21-CME starting at 2021-07-07 10:02:39.368000 | 2021-07-07 10:11:45.359
Socket (3) | CloseSocket call. | 2021-07-07 10:11:45.360
Historical data download thread signaled to stop. | 2021-07-07 10:11:45.360
Socket (3) | Shutdown started. Waiting for graceful close. | 2021-07-07 10:11:45.360
HD Request # 16 | Timestamp of first Intraday data file record written: 2021-07-07 10:02:50.115000 | 2021-07-07 10:11:45.360
HD Request # 16 | Received 1200 records from 2021-07-07 10:02:39.368000 to 2021-07-07 10:11:53.912004 (9.2 minutes) and wrote 1199 records for ESU21-CME | 2021-07-07 10:11:45.360
HD Request # 16 | Add time&sales data | Remembered last file record date-time: 2021-07-07 10:11:53.912004 | 2021-07-07 10:11:45.364
HD Request # 16 | Completion time: 2s | 2021-07-07 10:11:45.364
HD Request # 16 | Intraday data download complete for ESU21-CME. Unique request ID: 16 | 2021-07-07 10:11:45.364
Removing historical data download ID 16. | 2021-07-07 10:11:45.364
Real-time Intraday chart data file updates started for ESU21-CME | 2021-07-07 10:11:45.364
Intraday chart data file opened for ESU21-CME | 2021-07-07 10:11:45.364
HD Request # 16 | Enabling Intraday chart updating for symbol. | 2021-07-07 10:11:45.364
Triggering next historical data download in queue. | 2021-07-07 10:11:45.364
HD Request # 17 | Downloading Intraday chart data for NQU21-CME to the file NQU21-CME.scid. Service: cme | 2021-07-07 10:11:45.365
HD Request # 17 | Download start date-time: 2021-07-07 10:02:50.000000. File last date-time: 2021-07-07 10:02:50.116000 | 2021-07-07 10:11:45.365
HD Request # 17 | Using server: ds23.sierracharts.com port 10149 | 2021-07-07 10:11:45.365
Socket (1) | Creating socket. | 2021-07-07 10:11:45.365
Socket (1) | New receive buffer size: 5242880 | 2021-07-07 10:11:45.365
Socket (1) | Connecting to IP: 216.1.90.130. | 2021-07-07 10:11:45.365
Socket (3) | Socket gracefully closed by remote side. | 2021-07-07 10:11:45.588
Socket (3) | Closed. | 2021-07-07 10:11:45.588
HD Request # 17 | Setting DTC encoding to Binary VLS | 2021-07-07 10:11:45.835
HD Request # 17 | Sending historical data logon request message. | 2021-07-07 10:11:45.835
HD Request # 17 | Requesting Intraday data. Start date-time: 2021-07-07 10:02:50. Record interval: 0. Symbol: NQU21 | 2021-07-07 10:11:46.063
HD Request # 17 | Decompressing data. | 2021-07-07 10:11:46.291
HD Request # 17 | Receiving Intraday data for NQU21-CME starting at 2021-07-07 10:02:50.115000 | 2021-07-07 10:11:46.293
Socket (1) | CloseSocket call. | 2021-07-07 10:11:46.294
Socket (1) | Shutdown started. Waiting for graceful close. | 2021-07-07 10:11:46.294
Historical data download thread signaled to stop. | 2021-07-07 10:11:46.294
HD Request # 17 | Timestamp of first Intraday data file record written: 2021-07-07 10:02:55.674000 | 2021-07-07 10:11:46.294
HD Request # 17 | Received 587 records from 2021-07-07 10:02:50.115000 to 2021-07-07 10:11:53.411001 (9.1 minutes) and wrote 585 records for NQU21-CME | 2021-07-07 10:11:46.294
HD Request # 17 | Add time&sales data | Remembered last file record date-time: 2021-07-07 10:11:53.411001 | 2021-07-07 10:11:46.297
HD Request # 17 | Completion time: 1s | 2021-07-07 10:11:46.297
HD Request # 17 | Intraday data download complete for NQU21-CME. Unique request ID: 17 | 2021-07-07 10:11:46.297
Removing historical data download ID 17. | 2021-07-07 10:11:46.297
Real-time Intraday chart data file updates started for NQU21-CME | 2021-07-07 10:11:46.297
Intraday chart data file opened for NQU21-CME | 2021-07-07 10:11:46.297
HD Request # 17 | Enabling Intraday chart updating for symbol. | 2021-07-07 10:11:46.297
Triggering next historical data download in queue. | 2021-07-07 10:11:46.297
HD Request # 18 | Downloading Intraday chart data for GCQ21-COMEX to the file GCQ21-COMEX.scid. Service: comex | 2021-07-07 10:11:46.297
HD Request # 18 | Download start date-time: 2021-07-07 10:02:55.000000. File last date-time: 2021-07-07 10:02:55.080001 | 2021-07-07 10:11:46.297
HD Request # 18 | Using server: ds21.sierracharts.com port 10150 | 2021-07-07 10:11:46.297
Socket (2) | Creating socket. | 2021-07-07 10:11:46.298
Socket (2) | New receive buffer size: 5242880 | 2021-07-07 10:11:46.298
Socket (2) | Connecting to IP: 216.1.90.129. | 2021-07-07 10:11:46.298
Socket (1) | Socket gracefully closed by remote side. | 2021-07-07 10:11:46.521
Socket (1) | Closed. | 2021-07-07 10:11:46.521
HD Request # 18 | Setting DTC encoding to Binary VLS | 2021-07-07 10:11:46.747
HD Request # 18 | Sending historical data logon request message. | 2021-07-07 10:11:46.747
HD Request # 18 | Requesting Intraday data. Start date-time: 2021-07-07 10:02:55. Record interval: 0. Symbol: GCQ21 | 2021-07-07 10:11:46.970
HD Request # 18 | Decompressing data. | 2021-07-07 10:11:47.192
HD Request # 18 | Receiving Intraday data for GCQ21-COMEX starting at 2021-07-07 10:02:55.080000 | 2021-07-07 10:11:47.193
Socket (2) | CloseSocket call. | 2021-07-07 10:11:47.193
Historical data download thread signaled to stop. | 2021-07-07 10:11:47.194
Socket (2) | Shutdown started. Waiting for graceful close. | 2021-07-07 10:11:47.194
HD Request # 18 | Timestamp of first Intraday data file record written: 2021-07-07 10:03:00.201000 | 2021-07-07 10:11:47.194
HD Request # 18 | Received 458 records from 2021-07-07 10:02:55.080000 to 2021-07-07 10:11:53.300000 (9.0 minutes) and wrote 456 records for GCQ21-COMEX | 2021-07-07 10:11:47.194
HD Request # 18 | Add time&sales data | Remembered last file record date-time: 2021-07-07 10:11:53.300000 | 2021-07-07 10:11:47.197
HD Request # 18 | Completion time: 1s | 2021-07-07 10:11:47.197
HD Request # 18 | Intraday data download complete for GCQ21-COMEX. Unique request ID: 18 | 2021-07-07 10:11:47.197
Removing historical data download ID 18. | 2021-07-07 10:11:47.197
Real-time Intraday chart data file updates started for GCQ21-COMEX | 2021-07-07 10:11:47.197
Intraday chart data file opened for GCQ21-COMEX | 2021-07-07 10:11:47.197
HD Request # 18 | Enabling Intraday chart updating for symbol. | 2021-07-07 10:11:47.197
Triggering next historical data download in queue. | 2021-07-07 10:11:47.197
HD Request # 19 | Downloading Intraday chart data for RTYU21-CME to the file RTYU21-CME.scid. Service: cme | 2021-07-07 10:11:47.197
HD Request # 19 | Download start date-time: 2021-07-07 10:02:49.000000. File last date-time: 2021-07-07 10:02:49.118000 | 2021-07-07 10:11:47.197
HD Request # 19 | Using server: ds23.sierracharts.com port 10149 | 2021-07-07 10:11:47.197
Socket (1) | Creating socket. | 2021-07-07 10:11:47.198
Socket (1) | New receive buffer size: 5242880 | 2021-07-07 10:11:47.198
Socket (1) | Connecting to IP: 216.1.90.130. | 2021-07-07 10:11:47.198
Socket (2) | Socket gracefully closed by remote side. | 2021-07-07 10:11:47.415
Socket (2) | Closed. | 2021-07-07 10:11:47.415
HD Request # 19 | Setting DTC encoding to Binary VLS | 2021-07-07 10:11:47.647
HD Request # 19 | Sending historical data logon request message. | 2021-07-07 10:11:47.647
HD Request # 19 | Requesting Intraday data. Start date-time: 2021-07-07 10:02:49. Record interval: 0. Symbol: RTYU21 | 2021-07-07 10:11:47.864
HD Request # 19 | Decompressing data. | 2021-07-07 10:11:48.081
HD Request # 19 | Receiving Intraday data for RTYU21-CME starting at 2021-07-07 10:02:49.118000 | 2021-07-07 10:11:48.082
Socket (1) | CloseSocket call. | 2021-07-07 10:11:48.083
Socket (1) | Shutdown started. Waiting for graceful close. | 2021-07-07 10:11:48.083
Historical data download thread signaled to stop. | 2021-07-07 10:11:48.083
HD Request # 19 | Timestamp of first Intraday data file record written: 2021-07-07 10:02:53.698000 | 2021-07-07 10:11:48.083
HD Request # 19 | Received 309 records from 2021-07-07 10:02:49.118000 to 2021-07-07 10:11:51.751001 (9.0 minutes) and wrote 308 records for RTYU21-CME | 2021-07-07 10:11:48.083
HD Request # 19 | Add time&sales data | Remembered last file record date-time: 2021-07-07 10:11:51.751001 | 2021-07-07 10:11:48.086
HD Request # 19 | Completion time: 1s | 2021-07-07 10:11:48.086
HD Request # 19 | Intraday data download complete for RTYU21-CME. Unique request ID: 19 | 2021-07-07 10:11:48.087
Removing historical data download ID 19. | 2021-07-07 10:11:48.087
Real-time Intraday chart data file updates started for RTYU21-CME | 2021-07-07 10:11:48.087
Intraday chart data file opened for RTYU21-CME | 2021-07-07 10:11:48.087
HD Request # 19 | Enabling Intraday chart updating for symbol. | 2021-07-07 10:11:48.087
Triggering next historical data download in queue. | 2021-07-07 10:11:48.087
HD Request # 20 | Downloading Intraday chart data for GCM21-COMEX to the file GCM21-COMEX.scid. Service: comex | 2021-07-07 10:11:48.087
HD Request # 20 | Download start date-time: 2021-06-25 14:28:32.000000. File last date-time: 2021-06-25 14:28:32.099000 | 2021-07-07 10:11:48.087
HD Request # 20 | Using server: ds21.sierracharts.com port 10150 | 2021-07-07 10:11:48.087
Socket (2) | Creating socket. | 2021-07-07 10:11:48.087
Socket (2) | New receive buffer size: 5242880 | 2021-07-07 10:11:48.087
Socket (2) | Connecting to IP: 216.1.90.129. | 2021-07-07 10:11:48.087
Socket (1) | Socket gracefully closed by remote side. | 2021-07-07 10:11:48.299
Socket (1) | Closed. | 2021-07-07 10:11:48.299
HD Request # 20 | Setting DTC encoding to Binary VLS | 2021-07-07 10:11:48.535
HD Request # 20 | Sending historical data logon request message. | 2021-07-07 10:11:48.535
HD Request # 20 | Requesting Intraday data. Start date-time: 2021-06-25 14:28:32. Record interval: 0. Symbol: GCM21 | 2021-07-07 10:11:48.757
HD Request # 20 | Decompressing data. | 2021-07-07 10:11:48.979
HD Request # 20 | Receiving Intraday data for GCM21-COMEX starting at 2021-06-25 14:28:32.099000 | 2021-07-07 10:11:48.980
Socket (2) | CloseSocket call. | 2021-07-07 10:11:48.980
Historical data download thread signaled to stop. | 2021-07-07 10:11:48.980
HD Request # 20 | Received 1 record from 2021-06-25 14:28:32.099000 to 2021-06-25 14:28:32.099000 (0.0 seconds) and wrote 0 records for GCM21-COMEX | 2021-07-07 10:11:48.980
Socket (2) | Shutdown started. Waiting for graceful close. | 2021-07-07 10:11:48.980
HD Request # 20 | Add time&sales data | Remembered last file record date-time: 2021-06-25 14:28:32.099000 | 2021-07-07 10:11:48.980
HD Request # 20 | Completion time: 0s | 2021-07-07 10:11:48.980
HD Request # 20 | Intraday data download complete for GCM21-COMEX. Unique request ID: 20 | 2021-07-07 10:11:48.980
Removing historical data download ID 20. | 2021-07-07 10:11:48.980
Real-time Intraday chart data file updates started for GCM21-COMEX | 2021-07-07 10:11:48.980
Intraday chart data file opened for GCM21-COMEX | 2021-07-07 10:11:48.980
HD Request # 20 | Enabling Intraday chart updating for symbol. | 2021-07-07 10:11:48.980
Triggering next historical data download in queue. | 2021-07-07 10:11:48.980
No download requests in the queue to start downloads for. | 2021-07-07 10:11:48.980
Socket (2) | Socket gracefully closed by remote side. | 2021-07-07 10:11:49.201
Socket (2) | Closed. | 2021-07-07 10:11:49.201
Chart #2 has tagged chart #10 for full recalculation. Chartbook: 1- NEW CHARTBOOKMAY 2021.Cht | 2021-07-07 10:11:49.356
Chart #2 has tagged chart #25 for full recalculation. Chartbook: 1- NEW CHARTBOOKMAY 2021.Cht | 2021-07-07 10:11:49.356
Chart #2 has tagged chart #34 for full recalculation. Chartbook: 1- NEW CHARTBOOKMAY 2021.Cht | 2021-07-07 10:11:49.356
Chart #2 has tagged chart #36 for full recalculation. Chartbook: 1- NEW CHARTBOOKMAY 2021.Cht | 2021-07-07 10:11:49.356
Chart #2 has tagged chart #4 for full recalculation. Chartbook: 1- NEW CHARTBOOKMAY 2021.Cht | 2021-07-07 10:11:49.356
ESU21-CME [CB][M] #4 | Performing a full recalculation because it has been tagged. Chartbook: 1- NEW CHARTBOOKMAY 2021.Cht | 2021-07-07 10:11:49.386
NQU21-CME [CB][M] #34 | Performing a full recalculation because it has been tagged. Chartbook: 1- NEW CHARTBOOKMAY 2021.Cht | 2021-07-07 10:11:49.459
ESU21-CME [CB][M] #36 | Performing a full recalculation because it has been tagged. Chartbook: 1- NEW CHARTBOOKMAY 2021.Cht | 2021-07-07 10:11:49.588
GCQ21-COMEX [CB][M] #25 | Performing a full recalculation because it has been tagged. Chartbook: 1- NEW CHARTBOOKMAY 2021.Cht | 2021-07-07 10:11:49.660
RTYU21-CME [CB][M] #10 | Performing a full recalculation because it has been tagged. Chartbook: 1- NEW CHARTBOOKMAY 2021.Cht | 2021-07-07 10:11:49.723
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10048 | 2021-07-07 10:12:14.467
DTC Client socket (2) | Creating socket. | 2021-07-07 10:12:14.468
DTC Client socket (2) | New receive buffer size: 5242880 | 2021-07-07 10:12:14.468
DTC Client socket (2) | Connecting to IP: 216.1.90.130. | 2021-07-07 10:12:14.468
SC Data - All Services | Network connection to server complete. | 2021-07-07 10:12:14.689
SC Data - All Services | Starting socket receive thread. | 2021-07-07 10:12:14.689
SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-07-07 10:12:14.689
SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-07-07 10:12:14.914
SC Data - All Services | Sending logon request message. | 2021-07-07 10:12:14.914
SC Data - All Services | Received logon response. | 2021-07-07 10:12:15.774
SC Data - All Services | Server Name: SC Real-Time Server. | 2021-07-07 10:12:15.774
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-07-07 10:12:15.774
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2021-07-07 10:12:15.774
SC Data - All Services | Waiting for socket receive thread to end | 2021-07-07 10:12:15.774
DTC Client socket (2) | CloseSocket call. | 2021-07-07 10:12:15.774
SC Data - All Services | Disconnected from the server. | 2021-07-07 10:12:15.774
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2021-07-07 10:12:15.774
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-07-07 10:12:15.774
DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-07-07 10:12:15.994
DTC Client socket (2) | Closed. | 2021-07-07 10:12:15.994
[2021-07-07 10:44:41]
Sierra_Chart Engineering - Posts: 18602
This is the problem:
Refer to:
Denali Exchange Data Feed: Connections
[2021-07-09 08:25:17]
Hello. Connected already.
Will I pay as a non professional according to that connection?
I have funded account with amp , which type of AMP’s account I need to link with SC order-routing sys ( Rithmic, CQG etc…)
How to do it correctly?
[2021-07-09 15:20:48]
You have us confused. You are setup as a Non-Professional and we show that you have connected to your live, funded, futures trading account in order to validate that the account exists for the CME Group. So we are not sure why you are asking about these.
To answer your questions though, AMP can set you up with either CQG or Rithmic, it is your choice. Whichever you choose, you will then follow the Setup Instructions for the particular choice.
You will find the Setup Instructions for CQG here:
CQG Trading Platform Service: Setup Instructions
And the Setup Instructions for Rithmic are here:
Rithmic Trading Platform Service: Setup Instructions
Note that the original problem you were asking about was answered in Post #4, in which you had multiple connections to the Denali Exchange Data Feed. That is not related to the the issue of connecting to either CQG or Rithmic.
[2021-07-10 12:50:42]
Yes, I have my live account and I have stated as a non professional , but the question was because I couldn’t execute. So I thought that you have different type of connections: Denali data( for monitoring only) and SC order routing connected with live account.
Could you please explain the difference
[2021-07-12 13:57:02]
The first thing to keep in mind is that the issue of having a live, funded, futures trading account in order to qualify for non-professional exchange fees is a CME Group thing. It is their rule. As such, when you are using our Denali Exchange Data Feed with the CME Group data and you want to pay the Non-Professional exchange fees, then you need to have the trading account and you need to connect to it with your Sierra Chart software at least once a month, as we verify your account electronically by having you make a connection to it.
If you are always connected to your trading account, then it's not anything to think about. It's only if you are not staying connected where you have to ensure you think of making that connection once a month. And this is true regardless of the order routing service you are using - Rithmic, CQG, or the Sierra Chart Order Routing Service.
Therefore, there are not different stages of the Denali Exchange Data Feed, it is just a matter of what you want to pay (Professional or Non-Professional exchange fees).
[2021-07-12 14:12:57]
Ok, but how do I know that I connected to my live trading acc. In my case when I set SC’s connection it wasn’t displayed any my live account. That’s why I worry that I would pay professional fees.
[2021-07-12 16:33:09]
You will not be charged the Professional Fees. Rather, if there is an issue, you would just not get the data.
To see the status of your Trading Account Verification, go to the following link and the information is in the section entitled Verify Trading Account and will then give you the date that you are verified until:
https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges
If you are constantly connected to your trading account, then this updates daily and will always be about one month forward from the current date.
[2021-08-02 16:24:31]
Sierra Chart - Max - Posts: 5793
From User:
Hello, could you please check my case :
I have activated Denali and have live account with AMP, what exactly I need to set up to be able to execute Denali/order routing from Sierra Charts side and which settings I need to change with my amp account (CQG, TT routing...) I heard that it has been some changes with AMP broker recently
Sierra Chart Support
[2021-08-02 17:35:02]
We need to know what order routing service you are setup to use. Once we have that information, then we can point you to the proper Setup Instructions for that service.
Note that your Denali Exchange Data Feed setup is all good and everything is up-to-date in relation to that.
[2021-08-03 00:29:43]
I haven't set up any order routing yet.
Just have amp account.
I need to know which is available (CQG, TT, RITHMIC)
How I would pay transaction fees and whom (AMP or SC directly)
[2021-08-03 01:31:41]
I'm confused. Basically I have 2 funded AMP accounts :
113565 and 113565A.One account I use for real trading connected with Rithmic, another one I keep without any datafeed and seems it is related to my Denali.
Could you please confirm which account is related to my Denali? ( to meet requirements having funded real account).
So I think it would be better to have one account and datafeed for charting and execution with AMP.
Could you please recommend me which set up is better or maybe I need to keep current until you release direct CME execution.
Thank you!
[2021-08-03 14:35:00]
Right now, all we want to do is to get your Sierra Chart connected to your trading service so you can place orders and verify your non-professional status for the CME Group.
Since you are with AMP, you can use either CQG or Rithmic. They should have you setup with one of these. Please let us know which one you are setup to use with your AMP accounts and then we can give you the appropriate Setup Instructions to connect your Sierra Chart to that service.
[2021-08-04 03:36:48]
OK, but the questions are:
1. Which is better to set up with AMP for the order routing CQG or Rithmic?
2. Whom I will pay commissions AMP or Sierra Charts?
[2021-08-04 14:12:21]
1. Either one. We do not have any comments about one over another. You can see if other customers might have their opinions.
2. Trade commissions and fees are all paid to AMP.
[2021-09-01 06:00:00]
Hello ! I would like to activate Rithmic orderrouting on my account 113565A with AMP broker. I have already paid for Denali. So I just need to be activated order-routing.
Pls instruct me what to do
[2021-09-01 13:09:17]
Assuming that you are setup with Rithmic as your Order Routing with AMP, then just follow these instructions to setup your Sierra Chart to connect to Rithmic:
