Date/Time: Tue, 04 Nov 2025 10:44:14 +0000
Color Bar Based on Alert Condition
View Count: 662
|   [2021-07-06 03:35:12]     |
| User158665 - Posts: 44 |
                Is there the cpp for Corlor Bar Based on Alert Condition? I need to set 8 different colors based on some alerts. How can I do that? Should I add 8 indicators or is there an easier way? And how can I apply it to multiple charts later? If I could make an study with this alerts, it would be easier to apply to many charts.  |
|   [2021-07-06 05:35:55]     |
                You will need to use 8 instances of that study. That is the only way. The source code is not available for the study.  You can apply it to multiple charts later through the use of Study Collections: Study Collections If you do want to create your own custom study there is this ACSIL function available: ACSIL Interface Members - Functions: sc.EvaluateGivenAlertConditionFormulaAsDouble() Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-07-06 05:36:06
