Date/Time: Mon, 05 Oct 2026 02:21:36 +0000
Crosshair hides bar
View Count: 947
[2021-07-05 07:31:48]
User19165 - Posts: 346
This has always been a problem since I have been using SC. The way you draw the vertical line of the crosshair interferes and hides the bar. Most other charting programs instead will highlight the entire vertical background (user customizable colour) space of the bar width. This makes study and review across multiple charts with global crosshair enabled so much easier and less of a mental juggling act. I hope you would consider making this adjustment.
image2021-07-05_192231.png / V - Attached On 2021-07-05 07:31:36 UTC - Size: 23.1 KB - 295 views
[2021-07-05 09:14:02]
You must change the color of the Chart Values: Crosshair to something different. That is the problem:
Graphics Settings
And you can also change the width. It has always been fully controllable.
There is never been a problem to begin with. It is not a common issue that you have but it is due to the color configuration.
Date Time Of Last Edit: 2021-07-05 09:15:40
