Date/Time: Mon, 25 Nov 2024 22:31:49 +0000
не могу подключиться к серверу
View Count: 1696
[2014-03-17 08:08:03]
User41118 - Posts: 5
Здравствуйте!
Помогите, пожалуйста, я не могу подключить платформу к серверу.
Software version: 1107 | 2014-03-17 09:17:45
Usage end date: 2014-04-22 | 2014-03-17 09:17:45
Allow Support for Sierra Chart Data Feeds is enabled. | 2014-03-17 09:17:45
Active service: CTS T4 | 2014-03-17 09:17:45
Time Zone: +03:00:00 (AST+03) | 2014-03-17 09:17:45
2014-03-17 09:17:45 Local computer clock time | 2014-03-17 09:17:45
2014-03-17 06:17:45 GMT time | 2014-03-17 09:17:45
2014-03-17 09:17:45 Time zone adjusted time | 2014-03-17 09:17:45
Time difference to server time: 0 seconds. | 2014-03-17 09:17:45
Program path: C:\SierraChart\ | 2014-03-17 09:17:45
Data Files path: C:\SierraChart\Data\ | 2014-03-17 09:17:45
OS Version Number: 6.1 | 2014-03-17 09:17:45
Checking for new symbol settings for cts | 2014-03-17 09:17:45
Requesting symbol settings for cts. Overwrite = on. | 2014-03-17 09:17:46
Request for symbol settings completed. | 2014-03-17 09:17:47
Processed received symbol settings | 2014-03-17 09:17:47
CTS FIX - Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2014-03-17 09:17:50
CTS FIX - Firm: PTP | 2014-03-17 09:17:50
Resolved address fix-sim.t4login.com to IP 69.44.110.200 | 2014-03-17 09:17:51
The network socket is connected. | 2014-03-17 09:17:51
Starting SSL connection on the socket. | 2014-03-17 09:17:51
SSL socket is now connected. | 2014-03-17 09:17:51
CTS FIX: Sending the Logon message. | 2014-03-17 09:17:51
CTS FIX: Connected to data and trade server. | 2014-03-17 09:17:53
CTS FIX: Received Account List collateral report. | 2014-03-17 09:17:53
CTS FIX: Subscribing to account: ivan151 | 2014-03-17 09:17:53
CTS FIX: Subscribing to account: ivan1512 | 2014-03-17 09:17:53
CTS FIX: Received Account Update collateral report. | 2014-03-17 09:17:56
CTS FIX: Requesting Open Orders for account: ivan151 | 2014-03-17 09:17:58
CTS FIX: Requesting Open Orders for account: ivan1512 | 2014-03-17 09:17:58
CTS FIX: Received Account List collateral report. | 2014-03-17 09:17:58
CTS FIX: Received Account List collateral report. | 2014-03-17 09:18:08
Current selected Data/Trading service: Rithmic Trading | 2014-03-17 09:18:35
Checking for new symbol settings for rim | 2014-03-17 09:18:35
CTS FIX: Sending a Logout message. | 2014-03-17 09:18:35
CTS FIX: Disconnected. | 2014-03-17 09:18:35
The SSL socket was shut down successfully. | 2014-03-17 09:18:35
CTS FIX: Socket closed without completing the logout sequence. | 2014-03-17 09:18:35
Rithmic Trading - Port for executable: 32717 | 2014-03-17 09:18:35
Rithmic Trading - Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-03-17 09:18:35
Requesting symbol settings for rim. Overwrite = on. | 2014-03-17 09:18:35
Request for symbol settings completed. | 2014-03-17 09:18:36
Processed received symbol settings | 2014-03-17 09:18:36
Rithmic Trading: Connecting to the server 127.0.0.1. Port 32717 | 2014-03-17 09:18:37
The network socket is connected. | 2014-03-17 09:18:37
Rithmic Trading: Connected to server. | 2014-03-17 09:18:37
Rithmic Trading: Sending logon request message. | 2014-03-17 09:18:37
Rithmic Trading - Starting the connection process to data and trading service. | 2014-03-17 09:18:37
Rithmic Trading - Logging is enabled. Log file: Rithmic.log | 2014-03-17 09:18:37
Rithmic Trading - Connecting to Rithmic Paper Trading server. | 2014-03-17 09:18:37
Rithmic Trading - Server Alert: Market Data Connection Opened | 2014-03-17 09:18:40
Rithmic Trading - Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2014-03-17 09:18:40
Rithmic DTC Server Info - Server Name: SC DTC Bridge. Server Version: 1.1. Provider Name: Rithmic DTC. | 2014-03-17 09:18:40
Rithmic DTC - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2014-03-17 09:18:40
Rithmic DTC - Logon error from server | 2014-03-17 09:18:40
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-17 09:18:40
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-17 09:18:40
Rithmic DTC: Disconnected from the server. | 2014-03-17 09:18:40
Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-17 09:18:40
Rithmic DTC: Bridge process is still running. | 2014-03-17 09:18:42
Rithmic Trading: Connecting to the server 127.0.0.1. Port 32717 | 2014-03-17 09:18:44
Error received in OnConnect while connecting. Windows error code 10061: Ïîäêëþ÷åíèå íå óñòàíîâëåíî, ò.ê. êîíå÷íûé êîìïüþòåð îòâåðã çàïðîñ íà ïîäêëþ÷åíèå. | 2014-03-17 09:18:45
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-17 09:18:45
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-17 09:18:45
Rithmic Trading: Disconnected from the server. | 2014-03-17 09:18:45
Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-17 09:18:45
Rithmic Trading: Bridge process is still running. | 2014-03-17 09:18:47
Rithmic Trading: Connecting to the server 127.0.0.1. Port 32717 | 2014-03-17 09:18:49
Error received in OnConnect while connecting. Windows error code 10061: Ïîäêëþ÷åíèå íå óñòàíîâëåíî, ò.ê. êîíå÷íûé êîìïüþòåð îòâåðã çàïðîñ íà ïîäêëþ÷åíèå. | 2014-03-17 09:18:50
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-17 09:18:50
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-17 09:18:50
Rithmic Trading: Disconnected from the server. | 2014-03-17 09:18:50
Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-17 09:18:50
Rithmic Trading: Bridge process is still running. | 2014-03-17 09:18:52
Rithmic Trading: Connecting to the server 127.0.0.1. Port 32717 | 2014-03-17 09:18:54
Error received in OnConnect while connecting. Windows error code 10061: Ïîäêëþ÷åíèå íå óñòàíîâëåíî, ò.ê. êîíå÷íûé êîìïüþòåð îòâåðã çàïðîñ íà ïîäêëþ÷åíèå. | 2014-03-17 09:18:55
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-17 09:18:55
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-17 09:18:55
Rithmic Trading: Disconnected from the server. | 2014-03-17 09:18:55
Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-17 09:18:55
Rithmic Trading: Bridge process is still running. | 2014-03-17 09:18:57
Rithmic Trading: Connecting to the server 127.0.0.1. Port 32717 | 2014-03-17 09:18:59
Error received in OnConnect while connecting. Windows error code 10061: Ïîäêëþ÷åíèå íå óñòàíîâëåíî, ò.ê. êîíå÷íûé êîìïüþòåð îòâåðã çàïðîñ íà ïîäêëþ÷åíèå. | 2014-03-17 09:19:00
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-17 09:19:00
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-17 09:19:00
Rithmic Trading: Disconnected from the server. | 2014-03-17 09:19:00
Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-17 09:19:00
Rithmic Trading - Port for executable: 41421 | 2014-03-17 09:19:02
Rithmic Trading - Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-03-17 09:19:02
Rithmic Trading: Connecting to the server 127.0.0.1. Port 41421 | 2014-03-17 09:19:04
The network socket is connected. | 2014-03-17 09:19:04
Rithmic Trading: Connected to server. | 2014-03-17 09:19:04
Rithmic Trading: Sending logon request message. | 2014-03-17 09:19:04
Rithmic Trading - Starting the connection process to data and trading service. | 2014-03-17 09:19:04
Rithmic Trading - Logging is enabled. Log file: Rithmic.log | 2014-03-17 09:19:04
Rithmic Trading - Connecting to Rithmic Paper Trading server. | 2014-03-17 09:19:04
Rithmic Trading - Server Alert: Market Data Connection Opened | 2014-03-17 09:19:06
Rithmic Trading - Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2014-03-17 09:19:07
Rithmic DTC Server Info - Server Name: SC DTC Bridge. Server Version: 1.1. Provider Name: Rithmic DTC. | 2014-03-17 09:19:07
Rithmic DTC - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2014-03-17 09:19:07
Rithmic DTC - Logon error from server | 2014-03-17 09:19:07
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-17 09:19:07
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-17 09:19:07
Rithmic DTC: Disconnected from the server. | 2014-03-17 09:19:07
Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-17 09:19:07
Rithmic DTC: Bridge process is still running. | 2014-03-17 09:19:09
Rithmic Trading: Connecting to the server 127.0.0.1. Port 41421 | 2014-03-17 09:19:11
Error received in OnConnect while connecting. Windows error code 10061: Ïîäêëþ÷åíèå íå óñòàíîâëåíî, ò.ê. êîíå÷íûé êîìïüþòåð îòâåðã çàïðîñ íà ïîäêëþ÷åíèå. | 2014-03-17 09:19:12
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-17 09:19:12
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-17 09:19:12
Rithmic Trading: Disconnected from the server. | 2014-03-17 09:19:12
Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-17 09:19:12
Rithmic Trading: Bridge process is still running. | 2014-03-17 09:19:14
Rithmic Trading: Connecting to the server 127.0.0.1. Port 41421 | 2014-03-17 09:19:16
Error received in OnConnect while connecting. Windows error code 10061: Ïîäêëþ÷åíèå íå óñòàíîâëåíî, ò.ê. êîíå÷íûé êîìïüþòåð îòâåðã çàïðîñ íà ïîäêëþ÷åíèå. | 2014-03-17 09:19:17
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-17 09:19:17
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-17 09:19:17
Rithmic Trading: Disconnected from the server. | 2014-03-17 09:19:17
Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-17 09:19:17
Rithmic Trading: Bridge process is still running. | 2014-03-17 09:19:19
Rithmic Trading: Connecting to the server 127.0.0.1. Port 41421 | 2014-03-17 09:19:21
Error received in OnConnect while connecting. Windows error code 10061: Ïîäêëþ÷åíèå íå óñòàíîâëåíî, ò.ê. êîíå÷íûé êîìïüþòåð îòâåðã çàïðîñ íà ïîäêëþ÷åíèå. | 2014-03-17 09:19:22
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-17 09:19:22
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-17 09:19:22
Rithmic Trading: Disconnected from the server. | 2014-03-17 09:19:22
Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-17 09:19:22
Rithmic Trading: Bridge process is still running. | 2014-03-17 09:19:24
Rithmic Trading: Connecting to the server 127.0.0.1. Port 41421 | 2014-03-17 09:19:26
Error received in OnConnect while connecting. Windows error code 10061: Ïîäêëþ÷åíèå íå óñòàíîâëåíî, ò.ê. êîíå÷íûé êîìïüþòåð îòâåðã çàïðîñ íà ïîäêëþ÷åíèå. | 2014-03-17 09:19:27
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-17 09:19:27
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-17 09:19:27
Rithmic Trading: Disconnected from the server. | 2014-03-17 09:19:27
Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-17 09:19:27
Rithmic Trading - Port for executable: 47309 | 2014-03-17 09:19:29
Rithmic Trading - Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-03-17 09:19:29
Rithmic Trading: Connecting to the server 127.0.0.1. Port 47309 | 2014-03-17 09:19:31
The network socket is connected. | 2014-03-17 09:19:31
Rithmic Trading: Connected to server. | 2014-03-17 09:19:31
Rithmic Trading: Sending logon request message. | 2014-03-17 09:19:31
Rithmic Trading - Starting the connection process to data and trading service. | 2014-03-17 09:19:31
Rithmic Trading - Logging is enabled. Log file: Rithmic.log | 2014-03-17 09:19:31
Rithmic Trading - Connecting to Rithmic Paper Trading server. | 2014-03-17 09:19:31
Rithmic Trading - Server Alert: Market Data Connection Opened | 2014-03-17 09:19:33
Rithmic Trading - Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2014-03-17 09:19:33
Socket closed. Windows error code 10053: Ïðîãðàììà íà âàøåì õîñò-êîìïüþòåðå ðàçîðâàëà óñòàíîâëåííîå ïîäêëþ÷åíèå. | 2014-03-17 09:19:34
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-17 09:19:34
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-17 09:19:34
Rithmic Trading: Disconnected from the server. | 2014-03-17 09:19:34
Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-17 09:19:34
Rithmic Trading - Port for executable: 50381 | 2014-03-17 09:19:36
Rithmic Trading - Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-03-17 09:19:36
Rithmic Trading: Connecting to the server 127.0.0.1. Port 50381 | 2014-03-17 09:19:38
The network socket is connected. | 2014-03-17 09:19:38
Rithmic Trading: Connected to server. | 2014-03-17 09:19:38
Rithmic Trading: Sending logon request message. | 2014-03-17 09:19:38
Rithmic Trading - Starting the connection process to data and trading service. | 2014-03-17 09:19:38
Rithmic Trading - Logging is enabled. Log file: Rithmic.log | 2014-03-17 09:19:38
Rithmic Trading - Connecting to Rithmic Paper Trading server. | 2014-03-17 09:19:38
Rithmic Trading - Server Alert: Market Data Connection Opened | 2014-03-17 09:19:40
Rithmic Trading - Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2014-03-17 09:19:40
Rithmic Trading - Server Alert: Trading System Connection Opened | 2014-03-17 09:19:42
Rithmic Trading - Server Alert: Trading System Connection Login Failed. Result text: "permission denied" | 2014-03-17 09:19:42
Rithmic Trading - Server Alert: Market Data Connection Broken | 2014-03-17 09:19:42
Rithmic Trading - Server Alert: PnL Connection Opened | 2014-03-17 09:19:43
Rithmic Trading - Server Alert: PnL Connection Login Failed. Result text: "permission denied" | 2014-03-17 09:19:43
Rithmic Trading - Server Alert: Market Data Connection Opened | 2014-03-17 09:19:44
Rithmic Trading - Server Alert: Trading System Connection Broken | 2014-03-17 09:19:44
Rithmic Trading - Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2014-03-17 09:19:44
Rithmic Trading - Server Alert: Intraday History Connection Opened | 2014-03-17 09:19:44
Rithmic Trading - Deleting API object. | 2014-03-17 09:19:44
Rithmic Trading - Server Alert: Intraday History Connection Closed | 2014-03-17 09:19:44
Rithmic Trading - Server Alert: PnL Connection Closed | 2014-03-17 09:19:44
Rithmic Trading - Server Alert: Market Data Connection Closed | 2014-03-17 09:19:44
Socket closed. No error. | 2014-03-17 09:19:44
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-17 09:19:44
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-17 09:19:44
Rithmic Trading: Disconnected from the server. | 2014-03-17 09:19:44
Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-17 09:19:44
Rithmic Trading - Port for executable: 56525 | 2014-03-17 09:19:46
Rithmic Trading - Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-03-17 09:19:46
Rithmic Trading: Connecting to the server 127.0.0.1. Port 56525 | 2014-03-17 09:19:48
The network socket is connected. | 2014-03-17 09:19:48
Rithmic Trading: Connected to server. | 2014-03-17 09:19:48
Rithmic Trading: Sending logon request message. | 2014-03-17 09:19:48
Rithmic Trading - Starting the connection process to data and trading service. | 2014-03-17 09:19:48
Rithmic Trading - Logging is enabled. Log file: Rithmic.log | 2014-03-17 09:19:48
Rithmic Trading - Connecting to Rithmic Paper Trading server. | 2014-03-17 09:19:48
Rithmic Trading - Server Alert: Market Data Connection Opened | 2014-03-17 09:19:51
Rithmic Trading - Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2014-03-17 09:19:51
Rithmic DTC Server Info - Server Name: SC DTC Bridge. Server Version: 1.1. Provider Name: Rithmic DTC. | 2014-03-17 09:19:51
Rithmic DTC - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2014-03-17 09:19:51
Rithmic DTC - Logon error from server | 2014-03-17 09:19:51
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-17 09:19:51
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-17 09:19:51
Rithmic DTC: Disconnected from the server. | 2014-03-17 09:19:51
Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-17 09:19:51
Rithmic DTC: Bridge process is still running. | 2014-03-17 09:19:53
Rithmic Trading: Connecting to the server 127.0.0.1. Port 56525 | 2014-03-17 09:19:55
Error received in OnConnect while connecting. Windows error code 10061: Ïîäêëþ÷åíèå íå óñòàíîâëåíî, ò.ê. êîíå÷íûé êîìïüþòåð îòâåðã çàïðîñ íà ïîäêëþ÷åíèå. | 2014-03-17 09:19:56
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-17 09:19:56
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-17 09:19:56
Rithmic Trading: Disconnected from the server. | 2014-03-17 09:19:56
Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-17 09:19:56
Rithmic Trading: Bridge process is still running. | 2014-03-17 09:19:58
Rithmic Trading: Connecting to the server 127.0.0.1. Port 56525 | 2014-03-17 09:20:00
Error received in OnConnect while connecting. Windows error code 10061: Ïîäêëþ÷åíèå íå óñòàíîâëåíî, ò.ê. êîíå÷íûé êîìïüþòåð îòâåðã çàïðîñ íà ïîäêëþ÷åíèå. | 2014-03-17 09:20:01
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-17 09:20:01
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-17 09:20:01
Rithmic Trading: Disconnected from the server. | 2014-03-17 09:20:01
Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-17 09:20:01
Rithmic Trading: Bridge process is still running. | 2014-03-17 09:20:03
Rithmic Trading: Connecting to the server 127.0.0.1. Port 56525 | 2014-03-17 09:20:05
Error received in OnConnect while connecting. Windows error code 10061: Ïîäêëþ÷åíèå íå óñòàíîâëåíî, ò.ê. êîíå÷íûé êîìïüþòåð îòâåðã çàïðîñ íà ïîäêëþ÷åíèå. | 2014-03-17 09:20:06
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-17 09:20:06
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-17 09:20:06
Rithmic Trading: Disconnected from the server. | 2014-03-17 09:20:06
Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-17 09:20:06
Rithmic Trading: Bridge process is still running. | 2014-03-17 09:20:08
Rithmic Trading: Connecting to the server 127.0.0.1. Port 56525 | 2014-03-17 09:20:10
Error received in OnConnect while connecting. Windows error code 10061: Ïîäêëþ÷åíèå íå óñòàíîâëåíî, ò.ê. êîíå÷íûé êîìïüþòåð îòâåðã çàïðîñ íà ïîäêëþ÷åíèå. | 2014-03-17 09:20:11
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-17 09:20:11
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-17 09:20:11
Rithmic Trading: Disconnected from the server. | 2014-03-17 09:20:11
Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-17 09:20:11
Rithmic Trading - Port for executable: 11214 | 2014-03-17 09:20:13
Rithmic Trading - Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-03-17 09:20:13
Rithmic Trading: Connecting to the server 127.0.0.1. Port 11214 | 2014-03-17 09:20:15
The network socket is connected. | 2014-03-17 09:20:15
Rithmic Trading: Connected to server. | 2014-03-17 09:20:15
Rithmic Trading: Sending logon request message. | 2014-03-17 09:20:15
Rithmic Trading - Starting the connection process to data and trading service. | 2014-03-17 09:20:15
Rithmic Trading - Logging is enabled. Log file: Rithmic.log | 2014-03-17 09:20:15
Rithmic Trading - Connecting to Rithmic Paper Trading server. | 2014-03-17 09:20:15
Rithmic Trading - Server Alert: Market Data Connection Opened | 2014-03-17 09:20:17
Rithmic Trading - Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2014-03-17 09:20:18
Rithmic DTC Server Info - Server Name: SC DTC Bridge. Server Version: 1.1. Provider Name: Rithmic DTC. | 2014-03-17 09:20:18
Rithmic DTC - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2014-03-17 09:20:18
Rithmic DTC - Logon error from server | 2014-03-17 09:20:18
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-17 09:20:18
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-17 09:20:18
Rithmic DTC: Disconnected from the server. | 2014-03-17 09:20:18
Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-17 09:20:18
Rithmic DTC: Bridge process is still running. | 2014-03-17 09:20:20
Rithmic Trading: Connecting to the server 127.0.0.1. Port 11214 | 2014-03-17 09:20:22
Error received in OnConnect while connecting. Windows error code 10061: Ïîäêëþ÷åíèå íå óñòàíîâëåíî, ò.ê. êîíå÷íûé êîìïüþòåð îòâåðã çàïðîñ íà ïîäêëþ÷åíèå. | 2014-03-17 09:20:23
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-17 09:20:23
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-17 09:20:23
Rithmic Trading: Disconnected from the server. | 2014-03-17 09:20:23
Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-17 09:20:23
Rithmic Trading: Bridge process is still running. | 2014-03-17 09:20:25
The above has been sent to support. | 2014-03-17 09:20:26
Sending of the message log was completed. Please read the response that was received. The response was saved to C:\SierraChart\Data\MessageLogAnalysis.htm | 2014-03-17 09:20:27
Rithmic Trading: Connecting to the server 127.0.0.1. Port 11214 | 2014-03-17 09:20:27
Error received in OnConnect while connecting. Windows error code 10061: Ïîäêëþ÷åíèå íå óñòàíîâëåíî, ò.ê. êîíå÷íûé êîìïüþòåð îòâåðã çàïðîñ íà ïîäêëþ÷åíèå. | 2014-03-17 09:20:28
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-17 09:20:28
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-17 09:20:28
Rithmic Trading: Disconnected from the server. | 2014-03-17 09:20:28
Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-17 09:20:28
Rithmic Trading: Bridge process is still running. | 2014-03-17 09:20:30
Rithmic Trading: Connecting to the server 127.0.0.1. Port 11214 | 2014-03-17 09:20:32
Error received in OnConnect while connecting. Windows error code 10061: Ïîäêëþ÷åíèå íå óñòàíîâëåíî, ò.ê. êîíå÷íûé êîìïüþòåð îòâåðã çàïðîñ íà ïîäêëþ÷åíèå. | 2014-03-17 09:20:33
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-17 09:20:33
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-17 09:20:33
Rithmic Trading: Disconnected from the server. | 2014-03-17 09:20:33
Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-17 09:20:33
Rithmic Trading: Bridge process is still running. | 2014-03-17 09:20:35
Rithmic Trading: Connecting to the server 127.0.0.1. Port 11214 | 2014-03-17 09:20:37
Error received in OnConnect while connecting. Windows error code 10061: Ïîäêëþ÷åíèå íå óñòàíîâëåíî, ò.ê. êîíå÷íûé êîìïüþòåð îòâåðã çàïðîñ íà ïîäêëþ÷åíèå. | 2014-03-17 09:20:38
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-17 09:20:38
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-17 09:20:38
Rithmic Trading: Disconnected from the server. | 2014-03-17 09:20:38
Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-17 09:20:38
Rithmic Trading - Port for executable: 34254 | 2014-03-17 09:20:40
Rithmic Trading - Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-03-17 09:20:40
Rithmic Trading: Connecting to the server 127.0.0.1. Port 34254 | 2014-03-17 09:20:42
The network socket is connected. | 2014-03-17 09:20:42
Rithmic Trading: Connected to server. | 2014-03-17 09:20:42
Rithmic Trading: Sending logon request message. | 2014-03-17 09:20:42
Rithmic Trading - Starting the connection process to data and trading service. | 2014-03-17 09:20:42
Rithmic Trading - Logging is enabled. Log file: Rithmic.log | 2014-03-17 09:20:42
Rithmic Trading - Connecting to Rithmic Paper Trading server. | 2014-03-17 09:20:42
Rithmic Trading - Server Alert: Market Data Connection Opened | 2014-03-17 09:20:44
Rithmic Trading - Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2014-03-17 09:20:44
Rithmic DTC Server Info - Server Name: SC DTC Bridge. Server Version: 1.1. Provider Name: Rithmic DTC. | 2014-03-17 09:20:44
Rithmic DTC - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2014-03-17 09:20:44
Rithmic DTC - Logon error from server | 2014-03-17 09:20:44
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-17 09:20:44
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-17 09:20:44
Rithmic DTC: Disconnected from the server. | 2014-03-17 09:20:44
Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-17 09:20:44
Rithmic DTC: Bridge process is still running. | 2014-03-17 09:20:46
Rithmic Trading: Connecting to the server 127.0.0.1. Port 34254 | 2014-03-17 09:20:48
Error received in OnConnect while connecting. Windows error code 10061: Ïîäêëþ÷åíèå íå óñòàíîâëåíî, ò.ê. êîíå÷íûé êîìïüþòåð îòâåðã çàïðîñ íà ïîäêëþ÷åíèå. | 2014-03-17 09:20:49
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-17 09:20:49
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-17 09:20:49
Rithmic Trading: Disconnected from the server. | 2014-03-17 09:20:49
Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-17 09:20:49
Rithmic Trading: Bridge process is still running. | 2014-03-17 09:20:51
Rithmic Trading: Connecting to the server 127.0.0.1. Port 34254 | 2014-03-17 09:20:54
Error received in OnConnect while connecting. Windows error code 10061: Ïîäêëþ÷åíèå íå óñòàíîâëåíî, ò.ê. êîíå÷íûé êîìïüþòåð îòâåðã çàïðîñ íà ïîäêëþ÷åíèå. | 2014-03-17 09:20:55
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-17 09:20:55
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-17 09:20:55
Rithmic Trading: Disconnected from the server. | 2014-03-17 09:20:55
Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-17 09:20:55
Rithmic Trading: Bridge process is still running. | 2014-03-17 09:20:57
Rithmic Trading: Connecting to the server 127.0.0.1. Port 34254 | 2014-03-17 09:20:59
Error received in OnConnect while connecting. Windows error code 10061: Ïîäêëþ÷åíèå íå óñòàíîâëåíî, ò.ê. êîíå÷íûé êîìïüþòåð îòâåðã çàïðîñ íà ïîäêëþ÷åíèå. | 2014-03-17 09:21:00
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-17 09:21:00
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-17 09:21:00
Rithmic Trading: Disconnected from the server. | 2014-03-17 09:21:00
Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-17 09:21:00
Rithmic Trading: Bridge process is still running. | 2014-03-17 09:21:02
Rithmic Trading: Connecting to the server 127.0.0.1. Port 34254 | 2014-03-17 09:21:04
Error received in OnConnect while connecting. Windows error code 10061: Ïîäêëþ÷åíèå íå óñòàíîâëåíî, ò.ê. êîíå÷íûé êîìïüþòåð îòâåðã çàïðîñ íà ïîäêëþ÷åíèå. | 2014-03-17 09:21:05
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-17 09:21:05
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-17 09:21:05
Rithmic Trading: Disconnected from the server. | 2014-03-17 09:21:05
Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-17 09:21:05
Rithmic Trading - Port for executable: 51662 | 2014-03-17 09:21:07
Rithmic Trading - Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-03-17 09:21:07
Rithmic Trading: Connecting to the server 127.0.0.1. Port 51662 | 2014-03-17 09:21:09
The network socket is connected. | 2014-03-17 09:21:09
Rithmic Trading: Connected to server. | 2014-03-17 09:21:09
Rithmic Trading: Sending logon request message. | 2014-03-17 09:21:09
Rithmic Trading - Starting the connection process to data and trading service. | 2014-03-17 09:21:09
Rithmic Trading - Logging is enabled. Log file: Rithmic.log | 2014-03-17 09:21:09
Rithmic Trading - Connecting to Rithmic Paper Trading server. | 2014-03-17 09:21:09
Rithmic Trading - Server Alert: Market Data Connection Opened | 2014-03-17 09:21:11
Rithmic Trading - Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2014-03-17 09:21:11
Rithmic DTC Server Info - Server Name: SC DTC Bridge. Server Version: 1.1. Provider Name: Rithmic DTC. | 2014-03-17 09:21:11
Rithmic DTC - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2014-03-17 09:21:11
Rithmic DTC - Logon error from server | 2014-03-17 09:21:11
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-17 09:21:11
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-17 09:21:11
Rithmic DTC: Disconnected from the server. | 2014-03-17 09:21:11
Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-17 09:21:11
Rithmic DTC: Bridge process is still running. | 2014-03-17 09:21:13
Rithmic Trading: Connecting to the server 127.0.0.1. Port 51662 | 2014-03-17 09:21:15
Error received in OnConnect while connecting. Windows error code 10061: Ïîäêëþ÷åíèå íå óñòàíîâëåíî, ò.ê. êîíå÷íûé êîìïüþòåð îòâåðã çàïðîñ íà ïîäêëþ÷åíèå. | 2014-03-17 09:21:16
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-17 09:21:16
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-17 09:21:16
Rithmic Trading: Disconnected from the server. | 2014-03-17 09:21:16
Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-17 09:21:16
Rithmic Trading: Bridge process is still running. | 2014-03-17 09:21:18
Rithmic Trading: Connecting to the server 127.0.0.1. Port 51662 | 2014-03-17 09:21:20
Error received in OnConnect while connecting. Windows error code 10061: Ïîäêëþ÷åíèå íå óñòàíîâëåíî, ò.ê. êîíå÷íûé êîìïüþòåð îòâåðã çàïðîñ íà ïîäêëþ÷åíèå. | 2014-03-17 09:21:21
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-17 09:21:21
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-17 09:21:21
Rithmic Trading: Disconnected from the server. | 2014-03-17 09:21:21
Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2014-03-17 09:21:21
Rithmic Trading - Port for executable: 10191 | 2014-03-17 09:24:21
Rithmic Trading - Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-03-17 09:24:21
Rithmic Trading: Connecting to the server 127.0.0.1. Port 10191 | 2014-03-17 09:24:23
The network socket is connected. | 2014-03-17 09:24:23
Rithmic Trading: Connected to server. | 2014-03-17 09:24:23
Rithmic Trading: Sending logon request message. | 2014-03-17 09:24:23
Rithmic Trading - Starting the connection process to data and trading service. | 2014-03-17 09:24:23
Rithmic Trading - Logging is enabled. Log file: Rithmic.log | 2014-03-17 09:24:23
Rithmic Trading - Connecting to Rithmic Paper Trading server. | 2014-03-17 09:24:23
Rithmic Trading - Server Alert: Market Data Connection Opened | 2014-03-17 09:24:25
Rithmic Trading - Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2014-03-17 09:24:26
Rithmic DTC Server Info - Server Name: SC DTC Bridge. Server Version: 1.1. Provider Name: Rithmic DTC. | 2014-03-17 09:24:26
Rithmic DTC - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2014-03-17 09:24:26
Rithmic DTC - Logon error from server | 2014-03-17 09:24:26
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-17 09:24:26
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-17 09:24:26
Rithmic DTC: Disconnected from the server. | 2014-03-17 09:24:26
Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2014-03-17 09:24:26
Current selected Data/Trading service: Rithmic Trading | 2014-03-17 09:25:49
Rithmic Trading - Port for executable: 34767 | 2014-03-17 09:25:52
Rithmic Trading - Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-03-17 09:25:52
Rithmic Trading: Connecting to the server 127.0.0.1. Port 34767 | 2014-03-17 09:25:54
The network socket is connected. | 2014-03-17 09:25:54
Rithmic Trading: Connected to server. | 2014-03-17 09:25:54
Rithmic Trading: Sending logon request message. | 2014-03-17 09:25:54
Rithmic Trading - Starting the connection process to data and trading service. | 2014-03-17 09:25:54
Rithmic Trading - Logging is enabled. Log file: Rithmic.log | 2014-03-17 09:25:54
Rithmic Trading - Connecting to Rithmic Paper Trading server. | 2014-03-17 09:25:54
Rithmic Trading - Server Alert: Market Data Connection Opened | 2014-03-17 09:25:56
Rithmic Trading - Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2014-03-17 09:25:56
Rithmic DTC Server Info - Server Name: SC DTC Bridge. Server Version: 1.1. Provider Name: Rithmic DTC. | 2014-03-17 09:25:56
Rithmic DTC - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2014-03-17 09:25:56
Rithmic DTC - Logon error from server | 2014-03-17 09:25:56
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-17 09:25:56
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-17 09:25:56
Rithmic DTC: Disconnected from the server. | 2014-03-17 09:25:56
Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2014-03-17 09:25:56
File >> Disconnect selected. | 2014-03-17 09:26:07
Rithmic DTC: Disconnected from the server. | 2014-03-17 09:26:07
Rithmic DTC: Bridge process is still running. | 2014-03-17 09:26:08
Rithmic Trading: Connecting to the server 127.0.0.1. Port 34767 | 2014-03-17 09:26:10
Error received in OnConnect while connecting. Windows error code 10061: Ïîäêëþ÷åíèå íå óñòàíîâëåíî, ò.ê. êîíå÷íûé êîìïüþòåð îòâåðã çàïðîñ íà ïîäêëþ÷åíèå. | 2014-03-17 09:26:11
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-17 09:26:11
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-17 09:26:11
Rithmic Trading: Disconnected from the server. | 2014-03-17 09:26:11
Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-17 09:26:11
Rithmic Trading: Bridge process is still running. | 2014-03-17 09:26:13
Rithmic Trading: Connecting to the server 127.0.0.1. Port 34767 | 2014-03-17 09:26:15
Error received in OnConnect while connecting. Windows error code 10061: Ïîäêëþ÷åíèå íå óñòàíîâëåíî, ò.ê. êîíå÷íûé êîìïüþòåð îòâåðã çàïðîñ íà ïîäêëþ÷åíèå. | 2014-03-17 09:26:16
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-17 09:26:16
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-17 09:26:16
Rithmic Trading: Disconnected from the server. | 2014-03-17 09:26:16
Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-17 09:26:16
Rithmic Trading - Port for executable: 43215 | 2014-03-17 09:26:18
Rithmic Trading - Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-03-17 09:26:18
Rithmic Trading: Connecting to the server 127.0.0.1. Port 43215 | 2014-03-17 09:26:20
The network socket is connected. | 2014-03-17 09:26:20
Rithmic Trading: Connected to server. | 2014-03-17 09:26:20
Rithmic Trading: Sending logon request message. | 2014-03-17 09:26:20
Rithmic Trading - Starting the connection process to data and trading service. | 2014-03-17 09:26:20
Rithmic Trading - Logging is enabled. Log file: Rithmic.log | 2014-03-17 09:26:20
Rithmic Trading - Connecting to Rithmic Paper Trading server. | 2014-03-17 09:26:20
Rithmic Trading - Server Alert: Market Data Connection Opened | 2014-03-17 09:26:22
Rithmic Trading - Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2014-03-17 09:26:22
Rithmic DTC Server Info - Server Name: SC DTC Bridge. Server Version: 1.1. Provider Name: Rithmic DTC. | 2014-03-17 09:26:22
Rithmic DTC - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2014-03-17 09:26:22
Rithmic DTC - Logon error from server | 2014-03-17 09:26:22
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-17 09:26:22
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-17 09:26:22
Rithmic DTC: Disconnected from the server. | 2014-03-17 09:26:22
Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-17 09:26:22
Rithmic DTC: Bridge process is still running. | 2014-03-17 09:26:24
Rithmic Trading: Connecting to the server 127.0.0.1. Port 43215 | 2014-03-17 09:26:26
Error received in OnConnect while connecting. Windows error code 10061: Ïîäêëþ÷åíèå íå óñòàíîâëåíî, ò.ê. êîíå÷íûé êîìïüþòåð îòâåðã çàïðîñ íà ïîäêëþ÷åíèå. | 2014-03-17 09:26:27
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-17 09:26:27
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-17 09:26:27
Rithmic Trading: Disconnected from the server. | 2014-03-17 09:26:27
Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-17 09:26:27
Rithmic Trading: Bridge process is still running. | 2014-03-17 09:26:29
Rithmic Trading: Connecting to the server 127.0.0.1. Port 43215 | 2014-03-17 09:26:31
Error received in OnConnect while connecting. Windows error code 10061: Ïîäêëþ÷åíèå íå óñòàíîâëåíî, ò.ê. êîíå÷íûé êîìïüþòåð îòâåðã çàïðîñ íà ïîäêëþ÷åíèå. | 2014-03-17 09:26:32
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-17 09:26:32
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-17 09:26:32
Rithmic Trading: Disconnected from the server. | 2014-03-17 09:26:32
Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-17 09:26:32
Rithmic Trading: Bridge process is still running. | 2014-03-17 09:26:34
Rithmic Trading: Connecting to the server 127.0.0.1. Port 43215 | 2014-03-17 09:26:36
Error received in OnConnect while connecting. Windows error code 10061: Ïîäêëþ÷åíèå íå óñòàíîâëåíî, ò.ê. êîíå÷íûé êîìïüþòåð îòâåðã çàïðîñ íà ïîäêëþ÷åíèå. | 2014-03-17 09:26:37
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-17 09:26:37
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-17 09:26:37
Rithmic Trading: Disconnected from the server. | 2014-03-17 09:26:37
Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-17 09:26:37
Rithmic Trading: Bridge process is still running. | 2014-03-17 09:26:39
Rithmic Trading: Connecting to the server 127.0.0.1. Port 43215 | 2014-03-17 09:26:41
Error received in OnConnect while connecting. Windows error code 10061: Ïîäêëþ÷åíèå íå óñòàíîâëåíî, ò.ê. êîíå÷íûé êîìïüþòåð îòâåðã çàïðîñ íà ïîäêëþ÷åíèå. | 2014-03-17 09:26:42
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-17 09:26:42
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-17 09:26:42
Rithmic Trading: Disconnected from the server. | 2014-03-17 09:26:42
Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-17 09:26:42
Rithmic Trading - Port for executable: 54991 | 2014-03-17 09:26:44
Rithmic Trading - Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-03-17 09:26:44
Rithmic Trading: Connecting to the server 127.0.0.1. Port 54991 | 2014-03-17 09:26:46
The network socket is connected. | 2014-03-17 09:26:46
Rithmic Trading: Connected to server. | 2014-03-17 09:26:46
Rithmic Trading: Sending logon request message. | 2014-03-17 09:26:46
Rithmic Trading - Starting the connection process to data and trading service. | 2014-03-17 09:26:46
Rithmic Trading - Logging is enabled. Log file: Rithmic.log | 2014-03-17 09:26:46
Rithmic Trading - Connecting to Rithmic Paper Trading server. | 2014-03-17 09:26:46
Rithmic Trading - Server Alert: Market Data Connection Opened | 2014-03-17 09:26:49
Rithmic Trading - Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2014-03-17 09:26:49
Rithmic DTC Server Info - Server Name: SC DTC Bridge. Server Version: 1.1. Provider Name: Rithmic DTC. | 2014-03-17 09:26:49
Rithmic DTC - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2014-03-17 09:26:49
Rithmic DTC - Logon error from server | 2014-03-17 09:26:49
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-17 09:26:49
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-17 09:26:49
Rithmic DTC: Disconnected from the server. | 2014-03-17 09:26:49
Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-17 09:26:49
Rithmic DTC: Bridge process is still running. | 2014-03-17 09:26:51
Rithmic Trading: Connecting to the server 127.0.0.1. Port 54991 | 2014-03-17 09:26:53
Error received in OnConnect while connecting. Windows error code 10061: Ïîäêëþ÷åíèå íå óñòàíîâëåíî, ò.ê. êîíå÷íûé êîìïüþòåð îòâåðã çàïðîñ íà ïîäêëþ÷åíèå. | 2014-03-17 09:26:54
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-17 09:26:54
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-17 09:26:54
Rithmic Trading: Disconnected from the server. | 2014-03-17 09:26:54
Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-17 09:26:54
Rithmic Trading: Bridge process is still running. | 2014-03-17 09:26:56
Rithmic Trading: Connecting to the server 127.0.0.1. Port 54991 | 2014-03-17 09:26:58
Error received in OnConnect while connecting. Windows error code 10061: Ïîäêëþ÷åíèå íå óñòàíîâëåíî, ò.ê. êîíå÷íûé êîìïüþòåð îòâåðã çàïðîñ íà ïîäêëþ÷åíèå. | 2014-03-17 09:26:59
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-17 09:26:59
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-17 09:26:59
Rithmic Trading: Disconnected from the server. | 2014-03-17 09:26:59
Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-17 09:26:59
Rithmic Trading: Bridge process is still running. | 2014-03-17 09:27:01
Rithmic Trading: Connecting to the server 127.0.0.1. Port 54991 | 2014-03-17 09:27:03
Error received in OnConnect while connecting. Windows error code 10061: Ïîäêëþ÷åíèå íå óñòàíîâëåíî, ò.ê. êîíå÷íûé êîìïüþòåð îòâåðã çàïðîñ íà ïîäêëþ÷åíèå. | 2014-03-17 09:27:04
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-17 09:27:04
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-17 09:27:04
Rithmic Trading: Disconnected from the server. | 2014-03-17 09:27:04
Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-17 09:27:04
Rithmic Trading: Bridge process is still running. | 2014-03-17 09:27:06
Rithmic Trading: Connecting to the server 127.0.0.1. Port 54991 | 2014-03-17 09:27:08
Error received in OnConnect while connecting. Windows error code 10061: Ïîäêëþ÷åíèå íå óñòàíîâëåíî, ò.ê. êîíå÷íûé êîìïüþòåð îòâåðã çàïðîñ íà ïîäêëþ÷åíèå. | 2014-03-17 09:27:09
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-17 09:27:09
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-17 09:27:09
Rithmic Trading: Disconnected from the server. | 2014-03-17 09:27:09
Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-17 09:27:09
Rithmic Trading - Port for executable: 1232 | 2014-03-17 09:27:11
Rithmic Trading - Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-03-17 09:27:11
Rithmic Trading: Connecting to the server 127.0.0.1. Port 1232 | 2014-03-17 09:27:13
The network socket is connected. | 2014-03-17 09:27:13
Rithmic Trading: Connected to server. | 2014-03-17 09:27:13
Rithmic Trading: Sending logon request message. | 2014-03-17 09:27:13
Rithmic Trading - Starting the connection process to data and trading service. | 2014-03-17 09:27:13
Rithmic Trading - Logging is enabled. Log file: Rithmic.log | 2014-03-17 09:27:13
Rithmic Trading - Connecting to Rithmic Paper Trading server. | 2014-03-17 09:27:13
Rithmic Trading - Server Alert: Market Data Connection Opened | 2014-03-17 09:27:16
Rithmic Trading - Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2014-03-17 09:27:16
Rithmic DTC Server Info - Server Name: SC DTC Bridge. Server Version: 1.1. Provider Name: Rithmic DTC. | 2014-03-17 09:27:16
Rithmic DTC - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2014-03-17 09:27:16
Rithmic DTC - Logon error from server | 2014-03-17 09:27:16
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-17 09:27:16
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-17 09:27:16
Rithmic DTC: Disconnected from the server. | 2014-03-17 09:27:16
Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-17 09:27:16
Rithmic DTC: Bridge process is still running. | 2014-03-17 09:27:18
Rithmic Trading: Connecting to the server 127.0.0.1. Port 1232 | 2014-03-17 09:27:20
Error received in OnConnect while connecting. Windows error code 10061: Ïîäêëþ÷åíèå íå óñòàíîâëåíî, ò.ê. êîíå÷íûé êîìïüþòåð îòâåðã çàïðîñ íà ïîäêëþ÷åíèå. | 2014-03-17 09:27:21
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-17 09:27:21
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-17 09:27:21
Rithmic Trading: Disconnected from the server. | 2014-03-17 09:27:21
Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-17 09:27:21
Rithmic Trading: Bridge process is still running. | 2014-03-17 09:27:23
Rithmic Trading: Connecting to the server 127.0.0.1. Port 1232 | 2014-03-17 09:27:25
Error received in OnConnect while connecting. Windows error code 10061: Ïîäêëþ÷åíèå íå óñòàíîâëåíî, ò.ê. êîíå÷íûé êîìïüþòåð îòâåðã çàïðîñ íà ïîäêëþ÷åíèå. | 2014-03-17 09:27:26
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-17 09:27:26
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-17 09:27:26
Rithmic Trading: Disconnected from the server. | 2014-03-17 09:27:26
Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-17 09:27:26
Rithmic Trading: Bridge process is still running. | 2014-03-17 09:27:28
Rithmic Trading: Connecting to the server 127.0.0.1. Port 1232 | 2014-03-17 09:27:30
Error received in OnConnect while connecting. Windows error code 10061: Ïîäêëþ÷åíèå íå óñòàíîâëåíî, ò.ê. êîíå÷íûé êîìïüþòåð îòâåðã çàïðîñ íà ïîäêëþ÷åíèå. | 2014-03-17 09:27:31
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-17 09:27:31
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-17 09:27:31
Rithmic Trading: Disconnected from the server. | 2014-03-17 09:27:31
Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-17 09:27:31
Rithmic Trading: Bridge process is still running. | 2014-03-17 09:27:33
Rithmic Trading: Connecting to the server 127.0.0.1. Port 1232 | 2014-03-17 09:27:35
Error received in OnConnect while connecting. Windows error code 10061: Ïîäêëþ÷åíèå íå óñòàíîâëåíî, ò.ê. êîíå÷íûé êîìïüþòåð îòâåðã çàïðîñ íà ïîäêëþ÷åíèå. | 2014-03-17 09:27:36
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-17 09:27:36
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-17 09:27:36
Rithmic Trading: Disconnected from the server. | 2014-03-17 09:27:36
Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-17 09:27:36
Rithmic Trading - Port for executable: 7120 | 2014-03-17 09:27:38
Rithmic Trading - Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-03-17 09:27:38
Rithmic Trading: Connecting to the server 127.0.0.1. Port 7120 | 2014-03-17 09:27:40
The network socket is connected. | 2014-03-17 09:27:40
Rithmic Trading: Connected to server. | 2014-03-17 09:27:40
Rithmic Trading: Sending logon request message. | 2014-03-17 09:27:40
Rithmic Trading - Starting the connection process to data and trading service. | 2014-03-17 09:27:40
Rithmic Trading - Logging is enabled. Log file: Rithmic.log | 2014-03-17 09:27:40
Rithmic Trading - Connecting to Rithmic Paper Trading server. | 2014-03-17 09:27:40
Rithmic Trading - Server Alert: Market Data Connection Opened | 2014-03-17 09:27:42
Rithmic Trading - Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2014-03-17 09:27:42
Rithmic DTC Server Info - Server Name: SC DTC Bridge. Server Version: 1.1. Provider Name: Rithmic DTC. | 2014-03-17 09:27:42
Rithmic DTC - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2014-03-17 09:27:42
Rithmic DTC - Logon error from server | 2014-03-17 09:27:42
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-17 09:27:42
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-17 09:27:42
Rithmic DTC: Disconnected from the server. | 2014-03-17 09:27:42
Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-17 09:27:42
Rithmic DTC: Bridge process is still running. | 2014-03-17 09:27:44
Rithmic Trading: Connecting to the server 127.0.0.1. Port 7120 | 2014-03-17 09:27:46
Error received in OnConnect while connecting. Windows error code 10061: Ïîäêëþ÷åíèå íå óñòàíîâëåíî, ò.ê. êîíå÷íûé êîìïüþòåð îòâåðã çàïðîñ íà ïîäêëþ÷åíèå. | 2014-03-17 09:27:47
[2014-03-17 08:11:26]
Topsteptraaders выдали мне следующие настройки
http://gyazo.com/f67b62ccf54a9407a0a343ba8858e3ef
Я их указал по аналогии
http://gyazo.com/5b8099368cb87b2ea6890a57b76918e3
[2014-03-17 08:23:03]
We no longer provide help with this:
Rithmic Trading - Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2014-03-17 06:57:16
Either ask your broker for help. In our experience it is unlikely you will be able to connect to a demo account. Or use a Live Rithmic account. Your broker will be able to help you.
