Date/Time: Mon, 28 Sep 2026 10:42:04 +0000
Volume on Nasdaq and Dax
View Count: 834
| [2021-06-29 19:32:23] |
| User718049 - Posts: 1 |
Hi, I need to have access to real time volumes for Nasdaq (US100) and DAX (DE30). Which plan I need to order? Regards Marek |
| [2021-06-29 19:49:20] |
| John - SC Support - Posts: 48028 |
We need to make sure of which data you want. Given the way you have made your statements, it sounds like you may be looking for CFD data. If this is the case, then the real-time CFD data from FXCM is included with all Sierra Chart packages. Therefore, you would only need Package 3 or Package 5, depending on which one fits your trading needs. Refer to the following regarding the CFD data: Sierra Chart Real Time and Historical Forex and CFD Data Service If, on the other hand, you are looking for the Futures data, then you would be wanting the E-Mini Nasdaq 100 (NQ) from the CME Group and the DAX (FDAX) from the EUREX. If this is the case, then you would need to use the Denali Exchange Data Feed for these. Refer to the information at the following link, which includes the Setup Instructions for both the CME Group and EUREX: Denali Exchange Data Feed One item to be aware of if you are wanting futures data from the CME Group is their requirement that you have a live, funded, futures trading account in order to qualify for the non-professional exchange fees. For more information refer to the following: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges And finally, for information on the packages available from Sierra Chart, refer to the following: Description of Service Packages and Pricing: Packages For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
