Date/Time: Sun, 04 Oct 2026 00:42:21 +0000
Amp
View Count: 1082
[2021-06-29 19:30:35]
User529087 - Posts: 25
Hi
I opened the account with AMP and Made a deposit of 100$.
The account is open, the funds have been received but need to clear. Check (5 days biz days to process).
1. Do I need to order some data feed with amp and pay exchanges fees on top of Sierra?. The Answer should be no, but just checking.
2. Where do I go next to get Denali, pay the exchange fee non pro, and connect to AMP so I get the non pro rates.
3.The check is clearing, do I need to wait, or can I move forward now with the process?
Best,
Anthony
[2021-06-29 19:40:56]
John - SC Support - Posts: 48095
1. You do not need to, nor should you, pay for anything to AMP for the setup you are using.
2. The next thing is to follow these instructions:
Easy Solution to CME Funded Trading Account Requirement: Instructions
You need to have the verification that is described in the above instructions before moving forward.
3. We do not know, that is an AMP thing. The main thing is to make sure that the items we described in #2 above are completed first.
Once that verification is done, then you would go through the setup for the Denali Exchange Data Feed, which is here:
[2021-07-06 20:37:45]
Hi
I did the AMP verification process, the account is funded, and good to go on there side.
I got the attached results.
Is this normal? If not what's missing?
Whats the next steps?
imageAMP.PNG / V - Attached On 2021-07-06 20:36:12 UTC - Size: 17.34 KB - 337 views
[2021-07-07 16:30:29]
Sierra Chart - Max - Posts: 5972
According to AMPs system the account still does not exist.
You need to contact AMP Futures about this. There is nothing that we can do about it.
Sierra Chart Support
[2021-07-07 20:14:53]
Ok Amp told me its all good to go, now I go to the amp verification box, and click verify but nothing happens do I need to wait a certain amount of time between verifications?
[2021-07-07 21:23:47]
We are currently getting the following from AMP:
"Function not available due to maintenance period. Please try your request again later."
So we will see once their system is back online.
[2021-07-07 23:24:35]
Should I wait for your reply or try later myself and when?
[2021-07-09 14:24:18]
Did you recheck?
[2021-07-12 18:52:33]
The AMP system is back online. Your account is verified.
[2021-07-17 16:08:53]
Thank you. I'm ready to go.
Just one questions:
I currently have rhythmic data feed to CME with another broker, that I barely use.
If I connect to Sierra chart using my current Rhythmic feed, will I be able to get MBO data on the Dom?
If yes, Which package would I need if I wanted use my rhythmic feed, and have MBO, TPO,etc?
