Date/Time: Wed, 16 Sep 2026 05:32:00 +0000
Duplicate chartbook with different symbol
View Count: 2486
| [2021-06-29 04:34:09] |
| User148596 - Posts: 217 |
Hi, I tried to duplicate my chartbook and then change the symbol but it totally messed up my original chartbook. How can I duplicate my ES chartbook for NQ, RTY and YM? Thanks |
| [2021-06-29 06:24:34] |
Not sure why you would have any issue. Here is the documentation to change the symbol of a chart: Changing the Symbol of a Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
