Date/Time: Sun, 24 Nov 2024 10:56:10 +0000
compte demo
View Count: 621
[2021-06-28 16:48:38] |
Ludovic da costa - Posts: 9 |
pouvez vous m activez sierra et les flux pour une semaine car je vers payer l abonnement debut juillet s il vous plait puis je continuer gratuitement encore une semaine |
[2021-06-28 18:59:37] |
From Google Translate: can you activate sierra and the flows for a week because I will pay the subscription at the beginning of july
please can I continue for free for another week We see that you have not used all of your Trial time, we have been able to extend your trial by an additional 5 days. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-06-04 19:23:36] |
ULRICHHOD - Posts: 1 |
please can i have a DEMO account to enable me start trading with?
[2024-06-04 19:32:08] |
ULRICHHOD: There is a built-in Simulation mode in Sierra Chart that can be used. Refer to the following: Trade Simulation Or, if you prefer, we also have a "Simulated Futures Trading Service" that is a bit more realistic, as it uses our servers and therefore any working orders you send will be held on the server instead of just on your local copy of Sierra Chart. Refer to the following: Simulated Futures Trading Service In either case, you have control over the accounts. For the Simulated Futures Trading Service, you would create the account yourself. All of the information is in the given links. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
