Date/Time: Tue, 04 Nov 2025 18:08:29 +0000
[Programming Help] - Force recalculation of a study when user drawn drawing is moved
View Count: 893
[2021-06-28 16:23:37]
ATricky1 - Posts: 16
I've been struggling to find out how to do this in ACSIL. I've trawled the documentation but can't find a solution - but maybe I've missed something.
I've coded a study to start a plot based on an anchor (vertical line user drawn drawing) as a start point. The study creates the line and the plot is created from that bar onwards. However, on moving the line the plot is not re-adjusted.
1) Autoloop is set to 1
2) Chart interval update is set to 500 msecs
3) I'm running this out of market hours which I guess may affect any update?
4) sc.RecalculateChartImmediate(0) won't work - presumably because the code isn't being rerun anyway.
4) On turning Trade Simulation on or off it will update the study / plot as will adding any other study or 'Apply'. The documentation infers this anyway.
If the line is moved manually then I need the study to be run - the plot re-adjusted without me having to hit any buttons or select any other options.
Can the line be polled for any movement from the existing study or any other study/option? I need this outside of the symbol market hours when no ticks are coming in.
Thanks.
[2021-06-29 16:09:02]
Bump...Could someone help with the above please? Thanks.
[2021-06-29 16:52:43]
User907968 - Posts: 847
Using Drawing Tools From an Advanced Custom Study
Using Drawing Tools From an Advanced Custom Study: sc.GetUserDrawnChartDrawing()
ACSIL Interface Members - Variables and Arrays: sc.UpdateAlways
[2021-06-29 21:31:04]
sc.UpdateAlways did the trick. I'm guessing it should be use sparingly with a 500msecs or greater update to keep the CPU overhead down? Geez - will I ever get through the scale of all the documentation :)
Thanks a bunch. Much appreciated.
Date Time Of Last Edit: 2021-06-29 21:31:39
