Date/Time: Mon, 25 Nov 2024 22:39:49 +0000
OEC 6AM4 sunday data
View Count: 1597
[2014-03-17 03:05:01] |
NumbersBars - Posts: 141 |
Anybody manage to load 6AM4 intraday chart without huge gap? It looks like another OEC data screwed up. Not sure if I've missed out anything, the chart is just useless now. Please let me know if it is my Sierra setting issue. Screenshot of 6AM4 |
6AM4 [CBV] 60 min #1 41715.124.png / V - Attached On 2014-03-17 03:04:41 UTC - Size: 30.97 KB - 380 views |
[2014-03-17 05:29:33] |
Apparently OEC has changed their currency futures data format. For example for the 6E, rather than the Price Display Format being .01 it is now .0001.
[2014-03-17 05:43:40] |
Sorry, I don't understand at all. So, what should I change in order to display the currency futures chart properly in Sierra? And if we change the price display format, how about the historical data? |
[2014-03-17 05:52:52] |
Not really sure what to advise at this point until we contact OEC about this. We are going to contact them now. Otherwise, anything we do to try to solve the problem or any advice we give, may not be the proper long-term solution. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-03-17 05:53:05
[2014-03-17 18:08:45] |
Do the following: 1. Update the Symbol Settings as explained here: https://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php#UpdateSettings 2. Apply the updated Symbol Settings to each of your currency futures charts as explained here: https://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php#UpdateChartSettingsSteps 3. Re-download the data in the currency futures charts by selecting Edit >> Delete All Data and Download. This only needs to be done once for each symbol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-03-17 18:10:43
[2014-03-18 01:36:39] |
Followed the instruction above. But it doesn't seem to help. Here is the log File >> Disconnect selected. | 2014-03-18 01:31:10 Disconnected from Open E Cry. | 2014-03-18 01:31:10 Open E Cry: Connecting to serverprod.openecry.com. | 2014-03-18 01:31:13 Open E Cry: Connected. | 2014-03-18 01:31:14 Open E Cry - Starting real-time market data updates for: 6AM4 | 2014-03-18 01:31:14 HD Request # 13 - Downloading Intraday chart data for 6AM4 to the file 6AM4.scid. Service: oec | 2014-03-18 01:31:14 HD Request # 13 - Download start Date-Time: 2014-03-18 01:30:12.0 | 2014-03-18 01:31:14 HD Request # 13 - Using server: ds5.sierracharts.com port 10149 | 2014-03-18 01:31:14 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-03-18 01:31:14 Open E Cry tick subscription ID: 16 | 2014-03-18 01:31:15 The network socket is connected. | 2014-03-18 01:31:15 HD Request # 13 - Sending historical data logon request message. | 2014-03-18 01:31:15 HD Request # 13 - Requesting up to 360 days of Intraday data. Record interval: 0 | 2014-03-18 01:31:15 HD Request # 13 - Decompressing data. | 2014-03-18 01:31:15 HD Request # 13 - Receiving Intraday data for 6AM4 starting at 2014-03-18 01:30:12 | 2014-03-18 01:31:15 HD Request # 13 - Timestamp of first Intraday data file record written: 2014-03-18 01:30:13 | 2014-03-18 01:31:15 The network socket for historical data has been closed. | 2014-03-18 01:31:15 HD Request # 13 - Received 20 records from 2014-03-18 01:30:12 to 2014-03-18 01:30:31 (19.0 seconds) and wrote 18 records for 6AM4 | 2014-03-18 01:31:15 HD Request # 13 - Intraday download COMPLETE for 6AM4 | 2014-03-18 01:31:15 Real-time Intraday chart data file updates started for 6AM4 | 2014-03-18 01:31:15 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.230003, Time Difference = 51 seconds, Percentage = 301.529980% | 2014-03-18 01:31:16 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.230003, Time Difference = 51 seconds, Percentage = 301.529980% | 2014-03-18 01:31:16 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.239998, Time Difference = 56 seconds, Percentage = 301.679969% | 2014-03-18 01:31:22 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.230003, Time Difference = 59 seconds, Percentage = 301.769972% | 2014-03-18 01:31:24 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.230003, Time Difference = 59 seconds, Percentage = 301.769972% | 2014-03-18 01:31:24 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.230003, Time Difference = 59 seconds, Percentage = 301.769972% | 2014-03-18 01:31:24 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.230003, Time Difference = 59 seconds, Percentage = 301.769972% | 2014-03-18 01:31:24 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.230003, Time Difference = 59 seconds, Percentage = 301.769972% | 2014-03-18 01:31:24 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.230003, Time Difference = 59 seconds, Percentage = 301.769972% | 2014-03-18 01:31:24 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.230003, Time Difference = 59 seconds, Percentage = 301.769972% | 2014-03-18 01:31:24 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.230003, Time Difference = 59 seconds, Percentage = 301.769972% | 2014-03-18 01:31:24 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.230003, Time Difference = 59 seconds, Percentage = 301.769972% | 2014-03-18 01:31:24 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.220001, Time Difference = 59 seconds, Percentage = 301.769972% | 2014-03-18 01:31:24 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.220001, Time Difference = 59 seconds, Percentage = 301.769972% | 2014-03-18 01:31:24 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.220001, Time Difference = 59 seconds, Percentage = 301.769972% | 2014-03-18 01:31:24 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.220001, Time Difference = 59 seconds, Percentage = 301.769972% | 2014-03-18 01:31:24 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.220001, Time Difference = 59 seconds, Percentage = 301.769972% | 2014-03-18 01:31:24 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.220001, Time Difference = 59 seconds, Percentage = 301.769972% | 2014-03-18 01:31:24 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.220001, Time Difference = 59 seconds, Percentage = 301.769972% | 2014-03-18 01:31:24 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.220001, Time Difference = 59 seconds, Percentage = 301.769972% | 2014-03-18 01:31:24 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.220001, Time Difference = 59 seconds, Percentage = 301.769972% | 2014-03-18 01:31:24 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.220001, Time Difference = 59 seconds, Percentage = 301.769972% | 2014-03-18 01:31:24 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.220001, Time Difference = 59 seconds, Percentage = 301.769972% | 2014-03-18 01:31:24 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.220001, Time Difference = 59 seconds, Percentage = 301.769972% | 2014-03-18 01:31:24 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.220001, Time Difference = 59 seconds, Percentage = 301.769972% | 2014-03-18 01:31:24 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.220001, Time Difference = 59 seconds, Percentage = 301.769972% | 2014-03-18 01:31:24 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.220001, Time Difference = 59 seconds, Percentage = 301.769972% | 2014-03-18 01:31:24 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.220001, Time Difference = 59 seconds, Percentage = 301.769972% | 2014-03-18 01:31:25 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.220001, Time Difference = 60 seconds, Percentage = 301.799965% | 2014-03-18 01:31:25 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.220001, Time Difference = 63 seconds, Percentage = 301.889968% | 2014-03-18 01:31:28 Requesting symbol settings for oec. Overwrite = on. | 2014-03-18 01:31:28 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.220001, Time Difference = 63 seconds, Percentage = 301.889968% | 2014-03-18 01:31:28 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.220001, Time Difference = 63 seconds, Percentage = 301.889968% | 2014-03-18 01:31:28 Request for symbol settings completed. | 2014-03-18 01:31:30 Processed received symbol settings | 2014-03-18 01:31:30 File >> Disconnect selected. | 2014-03-18 01:31:36 Disconnected from Open E Cry. | 2014-03-18 01:31:36 Open E Cry: Connecting to serverprod.openecry.com. | 2014-03-18 01:31:40 Open E Cry: Connected. | 2014-03-18 01:31:42 Open E Cry - Starting real-time market data updates for: 6AM4 | 2014-03-18 01:31:42 HD Request # 14 - Downloading Intraday chart data for 6AM4 to the file 6AM4.scid. Service: oec | 2014-03-18 01:31:42 HD Request # 14 - Download start Date-Time: 2014-03-18 01:30:31.0 | 2014-03-18 01:31:42 HD Request # 14 - Using server: ds4.sierracharts.com port 10149 | 2014-03-18 01:31:42 Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-03-18 01:31:42 Open E Cry tick subscription ID: 18 | 2014-03-18 01:31:42 The network socket is connected. | 2014-03-18 01:31:43 HD Request # 14 - Sending historical data logon request message. | 2014-03-18 01:31:43 HD Request # 14 - Requesting up to 360 days of Intraday data. Record interval: 0 | 2014-03-18 01:31:43 HD Request # 14 - Decompressing data. | 2014-03-18 01:31:43 HD Request # 14 - Receiving Intraday data for 6AM4 starting at 2014-03-18 01:30:31 | 2014-03-18 01:31:43 HD Request # 14 - Timestamp of first Intraday data file record written: 2014-03-18 01:31:22 | 2014-03-18 01:31:43 The network socket for historical data has been closed. | 2014-03-18 01:31:43 HD Request # 14 - Received 34 records from 2014-03-18 01:30:31 to 2014-03-18 01:31:34 (63.0 seconds) and wrote 32 records for 6AM4 | 2014-03-18 01:31:43 HD Request # 14 - Intraday download COMPLETE for 6AM4 | 2014-03-18 01:31:43 Real-time Intraday chart data file updates started for 6AM4 | 2014-03-18 01:31:43 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.230003, Time Difference = 17 seconds, Percentage = 300.509930% | 2014-03-18 01:31:45 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.220001, Time Difference = 27 seconds, Percentage = 300.809932% | 2014-03-18 01:31:55 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.220001, Time Difference = 27 seconds, Percentage = 300.809932% | 2014-03-18 01:31:55 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.220001, Time Difference = 27 seconds, Percentage = 300.809932% | 2014-03-18 01:31:55 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.220001, Time Difference = 27 seconds, Percentage = 300.809932% | 2014-03-18 01:31:56 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.220001, Time Difference = 27 seconds, Percentage = 300.809932% | 2014-03-18 01:31:56 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.220001, Time Difference = 27 seconds, Percentage = 300.809932% | 2014-03-18 01:31:56 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.220001, Time Difference = 47 seconds, Percentage = 301.409936% | 2014-03-18 01:32:15 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.209999, Time Difference = 48 seconds, Percentage = 301.439929% | 2014-03-18 01:32:17 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.209999, Time Difference = 48 seconds, Percentage = 301.439929% | 2014-03-18 01:32:17 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.209999, Time Difference = 48 seconds, Percentage = 301.439929% | 2014-03-18 01:32:17 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.199997, Time Difference = 48 seconds, Percentage = 301.439929% | 2014-03-18 01:32:17 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.209999, Time Difference = 48 seconds, Percentage = 301.439929% | 2014-03-18 01:32:17 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.220001, Time Difference = 49 seconds, Percentage = 301.469946% | 2014-03-18 01:32:18 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.220001, Time Difference = 49 seconds, Percentage = 301.469946% | 2014-03-18 01:32:18 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.220001, Time Difference = 49 seconds, Percentage = 301.469946% | 2014-03-18 01:32:18 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.220001, Time Difference = 49 seconds, Percentage = 301.469946% | 2014-03-18 01:32:18 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.220001, Time Difference = 49 seconds, Percentage = 301.469946% | 2014-03-18 01:32:18 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.209999, Time Difference = 54 seconds, Percentage = 301.619935% | 2014-03-18 01:32:22 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.209999, Time Difference = 54 seconds, Percentage = 301.619935% | 2014-03-18 01:32:22 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.209999, Time Difference = 65 seconds, Percentage = 301.949930% | 2014-03-18 01:32:34 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.209999, Time Difference = 65 seconds, Percentage = 301.949930% | 2014-03-18 01:32:34 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.209999, Time Difference = 87 seconds, Percentage = 302.609944% | 2014-03-18 01:32:55 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.199997, Time Difference = 88 seconds, Percentage = 302.639937% | 2014-03-18 01:32:57 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.199997, Time Difference = 88 seconds, Percentage = 302.639937% | 2014-03-18 01:32:57 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.199997, Time Difference = 88 seconds, Percentage = 302.639937% | 2014-03-18 01:32:57 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.199997, Time Difference = 88 seconds, Percentage = 302.639937% | 2014-03-18 01:32:57 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.199997, Time Difference = 88 seconds, Percentage = 302.639937% | 2014-03-18 01:32:57 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.199997, Time Difference = 88 seconds, Percentage = 302.639937% | 2014-03-18 01:32:57 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.199997, Time Difference = 88 seconds, Percentage = 302.639937% | 2014-03-18 01:32:57 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.190002, Time Difference = 89 seconds, Percentage = 302.669930% | 2014-03-18 01:32:57 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.190002, Time Difference = 89 seconds, Percentage = 302.669930% | 2014-03-18 01:32:57 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.190002, Time Difference = 89 seconds, Percentage = 302.669930% | 2014-03-18 01:32:57 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.190002, Time Difference = 89 seconds, Percentage = 302.669930% | 2014-03-18 01:32:57 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.190002, Time Difference = 89 seconds, Percentage = 302.669930% | 2014-03-18 01:32:57 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.190002, Time Difference = 89 seconds, Percentage = 302.669930% | 2014-03-18 01:32:57 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.190002, Time Difference = 89 seconds, Percentage = 302.669930% | 2014-03-18 01:32:57 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.190002, Time Difference = 89 seconds, Percentage = 302.669930% | 2014-03-18 01:32:57 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.190002, Time Difference = 89 seconds, Percentage = 302.669930% | 2014-03-18 01:32:57 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.190002, Time Difference = 89 seconds, Percentage = 302.669930% | 2014-03-18 01:32:57 Error filtered for 6AM4, Intraday High = 0.902200, Intraday Low = 0.902200, Value = 90.190002, Time Difference = 90 seconds, Percentage = 302.699947% | 2014-03-18 01:32:58 Here is the snapshot of the chart 6AM4 http://www.sierrachart.com/image.php?l=139510655454.png |
[2014-03-18 02:07:43] |
We have examined this issue some more, and this really is a mess. OEC has to take responsibility for this. There is no clear solution at this point in time because there is inconsistent data between simulation and production. We apologize but we do not have a solution offer. And that is the honest truth. You will have to suffer through this until OEC normalizes the data across all of their servers. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-03-18 02:25:53] |
Just to give you an idea about how long this problem will likely go on for. The latest would be to the end of this week but we may have a solution we can release tomorrow evening.
[2014-03-18 04:17:22] |
Thanks for the update. Ok. OEC just being OEC again.... |
[2014-03-18 04:26:37] |
We asked them last night about this problem and they never answered us. We also sent an email about it this morning, and they still do not answer. So we have to make guesses as to what this current situation is. And the more we think about this, we realize that this is a very hard problem for us to resolve because of the inconsistency between simulation and production. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-03-18 11:04:15] |
User74987 - Posts: 16 |
I am having a similar issue with my 6e euro data/charts. The problem started when I pulled up charts Monday morning. My old charts looked fine so it seems like it might be related to data after rollover. My ES charts are fine. Here's my log message if it helps. Thank you. Software version: 1102 | 2014-03-18 05:52:55 Usage end date: 2014-04-20 | 2014-03-18 05:52:55 Enabled for: Sierra Chart Historical Data Service. | 2014-03-18 05:52:55 Allow Support for Sierra Chart Data Feeds is enabled. | 2014-03-18 05:52:55 Active service: Open E Cry FIX/FAST | 2014-03-18 05:52:55 Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2014-03-18 05:52:55 2014-03-18 05:52:55 Local computer clock time | 2014-03-18 05:52:55 2014-03-18 10:52:55 GMT time | 2014-03-18 05:52:55 2014-03-18 05:52:55 Time zone adjusted time | 2014-03-18 05:52:55 Time difference to server time: 0 seconds. | 2014-03-18 05:52:55 Program path: C:\SierraChart4Stage5\ | 2014-03-18 05:52:55 Data Files path: C:\SierraChart4Stage5\Data\ | 2014-03-18 05:52:55 OS Version Number: 6.1 | 2014-03-18 05:52:55 Checking for new symbol settings for oec | 2014-03-18 05:52:55 Requesting symbol settings for oec. Overwrite = on. | 2014-03-18 05:52:56 Request for symbol settings completed. | 2014-03-18 05:52:57 Processed received symbol settings | 2014-03-18 05:52:57 HD Request # 2 - Downloading Intraday chart data for 6EH4 to the file 6EH4.scid. Service: oec | 2014-03-18 05:53:00 HD Request # 2 - Download start Date-Time: 2014-03-17 09:14:08.0 | 2014-03-18 05:53:00 HD Request # 2 - Using server: ds4.sierracharts.com port 10149 | 2014-03-18 05:53:00 Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-03-18 05:53:00 The network socket is connected. | 2014-03-18 05:53:00 HD Request # 2 - Sending historical data logon request message. | 2014-03-18 05:53:00 HD Request # 2 - Requesting Intraday data. Max. days to return: 1095. Start Date-Time: 2014-03-17 14:14:08. Record interval: 0 | 2014-03-18 05:53:00 The network socket for historical data has been closed. | 2014-03-18 05:53:00 HD Request # 2 - Historical data for 6EH4 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-03-18 05:53:01 HD Request # 2 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for 6EH4 | 2014-03-18 05:53:01 HD Request # 2 - Intraday download COMPLETE for 6EH4 | 2014-03-18 05:53:01 HD Request # 3 - Downloading Historical Daily chart data for E6H14. Starting date: 2014-03-14. Service: oec | 2014-03-18 05:53:01 Historical data download counter reset. | 2014-03-18 05:53:01 HD Request # 3 - Requesting historical Daily data for E6H14 starting at 2014-03-13 | 2014-03-18 05:53:01 HD Request # 4 - Downloading Intraday chart data for GCLJ4 to the file GCLJ4.scid. Service: oec | 2014-03-18 05:53:01 HD Request # 4 - Download start Date-Time: 2014-03-17 15:21:35.0 | 2014-03-18 05:53:01 HD Request # 4 - Using server: ds5.sierracharts.com port 10149 | 2014-03-18 05:53:01 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-03-18 05:53:02 The network socket is connected. | 2014-03-18 05:53:02 HD Request # 4 - Sending historical data logon request message. | 2014-03-18 05:53:02 HD Request # 3 - Receiving historical Daily data for E6H14 starting at 2014-03-13 | 2014-03-18 05:53:02 Writing historical Daily data for E6H14 to the file E6H14.dly | 2014-03-18 05:53:02 HD Request # 3 - Received 3 records from 2014-03-13 00:00:00 to 2014-03-17 00:00:00 (5.0 days) and wrote 2 records for E6H14 | 2014-03-18 05:53:02 HD Request # 3 - Daily download COMPLETE for E6H14 | 2014-03-18 05:53:02 HD Request # 5 - Downloading Historical Daily chart data for Es#. Starting date: 2014-03-14. Service: oec | 2014-03-18 05:53:02 HD Request # 5 - Requesting historical Daily Continuous data for EsZ10 starting at 2014-03-13 | 2014-03-18 05:53:02 Open E Cry FIX/FAST - Connecting to trading server prod.openecry.com:9400. | 2014-03-18 05:53:02 HD Request # 5 - Receiving historical Daily data for Es# starting at 2014-03-13 | 2014-03-18 05:53:02 Writing historical Daily data for Es# to the file Es#.dly | 2014-03-18 05:53:02 HD Request # 5 - Received 4 records from 2014-03-13 00:00:00 to 2014-03-18 00:00:00 (6.0 days) and wrote 3 records for Es# | 2014-03-18 05:53:02 HD Request # 5 - Daily download COMPLETE for Es# | 2014-03-18 05:53:02 Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-03-18 05:53:02 The network socket is connected. | 2014-03-18 05:53:02 Starting SSL connection on the socket. | 2014-03-18 05:53:02 SSL socket is now connected. | 2014-03-18 05:53:02 HD Request # 4 - Requesting Intraday data. Max. days to return: 1095. Start Date-Time: 2014-03-17 20:21:35. Record interval: 0 | 2014-03-18 05:53:02 The network socket for historical data has been closed. | 2014-03-18 05:53:02 HD Request # 4 - Historical data for GCLJ4 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-03-18 05:53:02 HD Request # 4 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for GCLJ4 | 2014-03-18 05:53:02 HD Request # 4 - Intraday download COMPLETE for GCLJ4 | 2014-03-18 05:53:02 HD Request # 6 - Downloading Intraday chart data for ESM4 to the file ESM4.scid. Service: oec | 2014-03-18 05:53:02 HD Request # 6 - Download start Date-Time: 2014-03-17 23:08:18.0 | 2014-03-18 05:53:02 HD Request # 6 - Using server: ds3.sierracharts.com port 10149 | 2014-03-18 05:53:02 Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-03-18 05:53:02 The network socket is connected. | 2014-03-18 05:53:02 HD Request # 6 - Sending historical data logon request message. | 2014-03-18 05:53:02 OEC FIX Trading: Sending the Logon message. | 2014-03-18 05:53:02 Open E Cry FIX/FAST: Connected to trading server. | 2014-03-18 05:53:02 Open E Cry FIX/FAST: Connecting to FAST market data server: prod.openecry.com:9301. | 2014-03-18 05:53:02 Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-03-18 05:53:02 The network socket is connected. | 2014-03-18 05:53:02 OEC FAST Data: Sending the Hello message. | 2014-03-18 05:53:02 OEC FAST Data: Sending the Logon message. | 2014-03-18 05:53:02 Open E Cry FIX/FAST: Connected to the market data server. | 2014-03-18 05:53:02 Open E Cry FIX/FAST: Connected. | 2014-03-18 05:53:02 Open E Cry FIX/FAST - Starting real-time market data updates for: GCLJ4 | 2014-03-18 05:53:02 Open E Cry FIX/FAST - Starting real-time market data updates for: ES# | 2014-03-18 05:53:02 Open E Cry FIX/FAST - Starting real-time market data updates for: 6EH4 | 2014-03-18 05:53:02 Symbol Error - ES# is unknown, unavailable, or improperly formatted. FIX reject reason: Unknown contract | 2014-03-18 05:53:02 Open E Cry FIX/FAST - Starting real-time market data updates for: ESM4 | 2014-03-18 05:53:02 Symbol Error - ES# is unknown, unavailable, or improperly formatted. FIX reject reason: Unknown contract | 2014-03-18 05:53:02 HD Request # 6 - Requesting Intraday data. Max. days to return: 1095. Start Date-Time: 2014-03-18 04:08:18. Record interval: 0 | 2014-03-18 05:53:02 The network socket for historical data has been closed. | 2014-03-18 05:53:02 HD Request # 6 - Re-requesting historical data for ESM4 to get the latest data since the download was started while not connected to primary service. | 2014-03-18 05:53:02 HD Request # 6 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESM4 | 2014-03-18 05:53:03 HD Request # 7 - Downloading Intraday chart data for ESM4 to the file ESM4.scid. Service: oec | 2014-03-18 05:53:03 HD Request # 7 - Download start Date-Time: 2014-03-17 23:08:18.0 | 2014-03-18 05:53:03 HD Request # 7 - Using server: ds4.sierracharts.com port 10149 | 2014-03-18 05:53:03 Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-03-18 05:53:03 The network socket is connected. | 2014-03-18 05:53:03 HD Request # 7 - Sending historical data logon request message. | 2014-03-18 05:53:03 HD Request # 7 - Requesting Intraday data. Max. days to return: 1095. Start Date-Time: 2014-03-18 04:08:18. Record interval: 0 | 2014-03-18 05:53:03 HD Request # 7 - Decompressing data. | 2014-03-18 05:53:03 HD Request # 7 - Receiving Intraday data for ESM4 starting at 2014-03-17 23:08:18 | 2014-03-18 05:53:03 HD Request # 7 - Timestamp of first Intraday data file record written: 2014-03-17 23:08:18 | 2014-03-18 05:53:03 The network socket for historical data has been closed. | 2014-03-18 05:53:03 HD Request # 7 - Received 23431 records from 2014-03-17 23:08:18 to 2014-03-18 05:53:02 (6.7 hours) and wrote 23429 records for ESM4 | 2014-03-18 05:53:03 HD Request # 7 - Intraday download COMPLETE for ESM4 | 2014-03-18 05:53:03 Real-time Intraday chart data file updates started for ESM4 | 2014-03-18 05:53:03 HD Request # 8 - Downloading Intraday chart data for GCLJ4 to the file GCLJ4.scid. Service: oec | 2014-03-18 05:53:03 HD Request # 8 - Download start Date-Time: 2014-03-17 15:21:35.0 | 2014-03-18 05:53:03 HD Request # 8 - Using server: ds5.sierracharts.com port 10149 | 2014-03-18 05:53:03 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-03-18 05:53:03 The network socket is connected. | 2014-03-18 05:53:03 HD Request # 8 - Sending historical data logon request message. | 2014-03-18 05:53:03 HD Request # 8 - Requesting Intraday data. Max. days to return: 1095. Start Date-Time: 2014-03-17 20:21:35. Record interval: 0 | 2014-03-18 05:53:03 HD Request # 8 - Decompressing data. | 2014-03-18 05:53:03 HD Request # 8 - Receiving Intraday data for GCLJ4 starting at 2014-03-17 15:21:35 | 2014-03-18 05:53:03 HD Request # 8 - Timestamp of first Intraday data file record written: 2014-03-17 15:21:35 | 2014-03-18 05:53:03 The network socket for historical data has been closed. | 2014-03-18 05:53:03 HD Request # 8 - Received 9383 records from 2014-03-17 15:21:35 to 2014-03-18 05:52:56 (14.5 hours) and wrote 9382 records for GCLJ4 | 2014-03-18 05:53:04 HD Request # 8 - Intraday download COMPLETE for GCLJ4 | 2014-03-18 05:53:04 Real-time Intraday chart data file updates started for GCLJ4 | 2014-03-18 05:53:04 HD Request # 9 - Downloading Intraday chart data for 6EH4 to the file 6EH4.scid. Service: oec | 2014-03-18 05:53:04 HD Request # 9 - Download start Date-Time: 2014-03-17 09:14:08.0 | 2014-03-18 05:53:04 HD Request # 9 - Using server: ds3.sierracharts.com port 10149 | 2014-03-18 05:53:04 Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-03-18 05:53:04 The network socket is connected. | 2014-03-18 05:53:04 HD Request # 9 - Sending historical data logon request message. | 2014-03-18 05:53:04 HD Request # 9 - Requesting Intraday data. Max. days to return: 1095. Start Date-Time: 2014-03-17 14:14:08. Record interval: 0 | 2014-03-18 05:53:04 HD Request # 9 - Decompressing data. | 2014-03-18 05:53:04 HD Request # 9 - Receiving Intraday data for 6EH4 starting at 2014-03-17 09:14:08 | 2014-03-18 05:53:04 The network socket for historical data has been closed. | 2014-03-18 05:53:04 HD Request # 9 - Received 1 record from 2014-03-17 09:14:08 to 2014-03-17 09:14:08 (0.0 seconds) and wrote 0 records for 6EH4 | 2014-03-18 05:53:04 HD Request # 9 - Intraday download COMPLETE for 6EH4 | 2014-03-18 05:53:04 Real-time Intraday chart data file updates started for 6EH4 | 2014-03-18 05:53:04 Open E Cry FIX/FAST: Received position acknowledgment message. Request Result: 2. Request Status: 1 | 2014-03-18 05:53:17 Record has been filtered due to large range while loading Intraday data for 6EM4 | 2014-03-18 05:53:55 Record has been filtered due to large range while loading Intraday data for 6EM4 | 2014-03-18 05:53:55 Record has been filtered due to large range while loading Intraday data for 6EM4 | 2014-03-18 05:53:55 Record has been filtered due to large range while loading Intraday data for 6EM4 | 2014-03-18 05:53:55 Open E Cry FIX/FAST - Starting real-time market data updates for: 6EM4 | 2014-03-18 05:53:56 HD Request # 10 - Downloading Intraday chart data for 6EM4 to the file 6EM4.scid. Service: oec | 2014-03-18 05:53:56 HD Request # 10 - Download start Date-Time: 2014-03-17 15:59:59.0 | 2014-03-18 05:53:56 HD Request # 10 - Using server: ds4.sierracharts.com port 10149 | 2014-03-18 05:53:56 Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-03-18 05:53:56 The network socket is connected. | 2014-03-18 05:53:56 HD Request # 10 - Sending historical data logon request message. | 2014-03-18 05:53:56 HD Request # 10 - Requesting Intraday data. Max. days to return: 1095. Start Date-Time: 2014-03-17 20:59:59. Record interval: 0 | 2014-03-18 05:53:56 HD Request # 10 - Decompressing data. | 2014-03-18 05:53:56 HD Request # 10 - Receiving Intraday data for 6EM4 starting at 2014-03-17 15:59:59 | 2014-03-18 05:53:56 HD Request # 10 - Timestamp of first Intraday data file record written: 2014-03-17 17:00:00 | 2014-03-18 05:53:56 The network socket for historical data has been closed. | 2014-03-18 05:53:57 HD Request # 10 - Received 23673 records from 2014-03-17 15:59:59 to 2014-03-18 05:53:50 (13.9 hours) and wrote 23668 records for 6EM4 | 2014-03-18 05:53:57 HD Request # 10 - Intraday download COMPLETE for 6EM4 | 2014-03-18 05:53:57 Real-time Intraday chart data file updates started for 6EM4 | 2014-03-18 05:53:57 Record has been filtered due to large range while loading Intraday data for 6EM4 | 2014-03-18 05:53:57 Record has been filtered due to large range while loading Intraday data for 6EM4 | 2014-03-18 05:53:57 Record has been filtered due to large range while loading Intraday data for 6EM4 | 2014-03-18 05:53:57 Record has been filtered due to large range while loading Intraday data for 6EM4 | 2014-03-18 05:53:57 Error filtered for 6EM4, Intraday High = 1.390600, Intraday Low = 1.390600, Value = 139.070007, Time Difference = 13 seconds, Percentage = 300.389981% | 2014-03-18 05:54:03 Error filtered for 6EM4, Intraday High = 1.390600, Intraday Low = 1.390600, Value = 139.059998, Time Difference = 19 seconds, Percentage = 300.569963% | 2014-03-18 05:54:08 Error filtered for 6EM4, Intraday High = 1.390600, Intraday Low = 1.390600, Value = 139.059998, Time Difference = 32 seconds, Percentage = 300.959969% | 2014-03-18 05:54:22 Error filtered for 6EM4, Intraday High = 1.390600, Intraday Low = 1.390600, Value = 139.059998, Time Difference = 32 seconds, Percentage = 300.959969% | 2014-03-18 05:54:22 Error filtered for 6EM4, Intraday High = 1.390600, Intraday Low = 1.390600, Value = 139.059998, Time Difference = 32 seconds, Percentage = 300.959969% | 2014-03-18 05:54:22 Error filtered for 6EM4, Intraday High = 1.390600, Intraday Low = 1.390600, Value = 139.059998, Time Difference = 32 seconds, Percentage = 300.959969% | 2014-03-18 05:54:22 Error filtered for 6EM4, Intraday High = 1.390600, Intraday Low = 1.390600, Value = 139.059998, Time Difference = 32 seconds, Percentage = 300.959969% | 2014-03-18 05:54:22 Error filtered for 6EM4, Intraday High = 1.390600, Intraday Low = 1.390600, Value = 139.059998, Time Difference = 32 seconds, Percentage = 300.959969% | 2014-03-18 05:54:22 Error filtered for 6EM4, Intraday High = 1.390600, Intraday Low = 1.390600, Value = 139.059998, Time Difference = 32 seconds, Percentage = 300.959969% | 2014-03-18 05:54:22 Error filtered for 6EM4, Intraday High = 1.390600, Intraday Low = 1.390600, Value = 139.059998, Time Difference = 32 seconds, Percentage = 300.959969% | 2014-03-18 05:54:22 Error filtered for 6EM4, Intraday High = 1.390600, Intraday Low = 1.390600, Value = 139.059998, Time Difference = 32 seconds, Percentage = 300.959969% | 2014-03-18 05:54:22 Error filtered for 6EM4, Intraday High = 1.390600, Intraday Low = 1.390600, Value = 139.059998, Time Difference = 32 seconds, Percentage = 300.959969% | 2014-03-18 05:54:22 Error filtered for 6EM4, Intraday High = 1.390600, Intraday Low = 1.390600, Value = 139.059998, Time Difference = 32 seconds, Percentage = 300.959969% | 2014-03-18 05:54:22 Error filtered for 6EM4, Intraday High = 1.390600, Intraday Low = 1.390600, Value = 139.059998, Time Difference = 32 seconds, Percentage = 300.959969% | 2014-03-18 05:54:22 Error filtered for 6EM4, Intraday High = 1.390600, Intraday Low = 1.390600, Value = 139.059998, Time Difference = 32 seconds, Percentage = 300.959969% | 2014-03-18 05:54:22 Error filtered for 6EM4, Intraday High = 1.390600, Intraday Low = 1.390600, Value = 139.059998, Time Difference = 32 seconds, Percentage = 300.959969% | 2014-03-18 05:54:22 Error filtered for 6EM4, Intraday High = 1.390600, Intraday Low = 1.390600, Value = 139.059998, Time Difference = 32 seconds, Percentage = 300.959969% | 2014-03-18 05:54:22 Error filtered for 6EM4, Intraday High = 1.390600, Intraday Low = 1.390600, Value = 139.059998, Time Difference = 32 seconds, Percentage = 300.959969% | 2014-03-18 05:54:22 Error filtered for 6EM4, Intraday High = 1.390600, Intraday Low = 1.390600, Value = 139.059998, Time Difference = 32 seconds, Percentage = 300.959969% | 2014-03-18 05:54:22 Error filtered for 6EM4, Intraday High = 1.390600, Intraday Low = 1.390600, Value = 139.059998, Time Difference = 32 seconds, Percentage = 300.959969% | 2014-03-18 05:54:22 Error filtered for 6EM4, Intraday High = 1.390600, Intraday Low = 1.390600, Value = 139.059998, Time Difference = 32 seconds, Percentage = 300.959969% | 2014-03-18 05:54:22 Error filtered for 6EM4, Intraday High = 1.390600, Intraday Low = 1.390600, Value = 139.059998, Time Difference = 32 seconds, Percentage = 300.959969% | 2014-03-18 05:54:22 Error filtered for 6EM4, Intraday High = 1.390600, Intraday Low = 1.390600, Value = 139.059998, Time Difference = 32 seconds, Percentage = 300.959969% | 2014-03-18 05:54:22 Error filtered for 6EM4, Intraday High = 1.390600, Intraday Low = 1.390600, Value = 139.059998, Time Difference = 32 seconds, Percentage = 300.959969% | 2014-03-18 05:54:22 Error filtered for 6EM4, Intraday High = 1.390600, Intraday Low = 1.390600, Value = 139.059998, Time Difference = 32 seconds, Percentage = 300.959969% | 2014-03-18 05:54:22 Error filtered for 6EM4, Intraday High = 1.390600, Intraday Low = 1.390600, Value = 139.059998, Time Difference = 40 seconds, Percentage = 301.199961% | 2014-03-18 05:54:30 Error filtered for 6EM4, Intraday High = 1.390600, Intraday Low = 1.390600, Value = 139.059998, Time Difference = 42 seconds, Percentage = 301.259971% | 2014-03-18 05:54:32 Error filtered for 6EM4, Intraday High = 1.390600, Intraday Low = 1.390600, Value = 139.059998, Time Difference = 42 seconds, Percentage = 301.259971% | 2014-03-18 05:54:32 Error filtered for 6EM4, Intraday High = 1.390600, Intraday Low = 1.390600, Value = 139.059998, Time Difference = 50 seconds, Percentage = 301.499963% | 2014-03-18 05:54:40 Error filtered for 6EM4, Intraday High = 1.390600, Intraday Low = 1.390600, Value = 139.059998, Time Difference = 50 seconds, Percentage = 301.499963% | 2014-03-18 05:54:40 Error filtered for 6EM4, Intraday High = 1.390600, Intraday Low = 1.390600, Value = 139.059998, Time Difference = 50 seconds, Percentage = 301.499963% | 2014-03-18 05:54:40 Error filtered for 6EM4, Intraday High = 1.390600, Intraday Low = 1.390600, Value = 139.059998, Time Difference = 50 seconds, Percentage = 301.499963% | 2014-03-18 05:54:40 Error filtered for 6EM4, Intraday High = 1.390600, Intraday Low = 1.390600, Value = 139.059998, Time Difference = 50 seconds, Percentage = 301.499963% | 2014-03-18 05:54:40 Error filtered for 6EM4, Intraday High = 1.390600, Intraday Low = 1.390600, Value = 139.050003, Time Difference = 50 seconds, Percentage = 301.499963% | 2014-03-18 05:54:40 Error filtered for 6EM4, Intraday High = 1.390600, Intraday Low = 1.390600, Value = 139.050003, Time Difference = 69 seconds, Percentage = 302.069974% | 2014-03-18 05:54:58 Error filtered for 6EM4, Intraday High = 1.390600, Intraday Low = 1.390600, Value = 139.050003, Time Difference = 69 seconds, Percentage = 302.069974% | 2014-03-18 05:54:58 Error filtered for 6EM4, Intraday High = 1.390600, Intraday Low = 1.390600, Value = 139.050003, Time Difference = 69 seconds, Percentage = 302.069974% | 2014-03-18 05:54:58 Error filtered for 6EM4, Intraday High = 1.390600, Intraday Low = 1.390600, Value = 139.050003, Time Difference = 69 seconds, Percentage = 302.069974% | 2014-03-18 05:54:58 Error filtered for 6EM4, Intraday High = 1.390600, Intraday Low = 1.390600, Value = 139.050003, Time Difference = 69 seconds, Percentage = 302.069974% | 2014-03-18 05:54:58 Error filtered for 6EM4, Intraday High = 1.390600, Intraday Low = 1.390600, Value = 139.050003, Time Difference = 75 seconds, Percentage = 302.249980% | 2014-03-18 05:55:04 Error filtered for 6EM4, Intraday High = 1.390600, Intraday Low = 1.390600, Value = 139.050003, Time Difference = 75 seconds, Percentage = 302.249980% | 2014-03-18 05:55:04 Error filtered for 6EM4, Intraday High = 1.390600, Intraday Low = 1.390600, Value = 139.050003, Time Difference = 75 seconds, Percentage = 302.249980% | 2014-03-18 05:55:04 Error filtered for 6EM4, Intraday High = 1.390600, Intraday Low = 1.390600, Value = 139.050003, Time Difference = 75 seconds, Percentage = 302.249980% | 2014-03-18 05:55:04 Error filtered for 6EM4, Intraday High = 1.390600, Intraday Low = 1.390600, Value = 139.050003, Time Difference = 75 seconds, Percentage = 302.249980% | 2014-03-18 05:55:04 Error filtered for 6EM4, Intraday High = 1.390600, Intraday Low = 1.390600, Value = 139.050003, Time Difference = 75 seconds, Percentage = 302.249980% | 2014-03-18 05:55:04 Error filtered for 6EM4, Intraday High = 1.390600, Intraday Low = 1.390600, Value = 139.050003, Time Difference = 78 seconds, Percentage = 302.339959% | 2014-03-18 05:55:07 Error filtered for 6EM4, Intraday High = 1.390600, Intraday Low = 1.390600, Value = 139.050003, Time Difference = 79 seconds, Percentage = 302.369976% | 2014-03-18 05:55:08 Error filtered for 6EM4, Intraday High = 1.390600, Intraday Low = 1.390600, Value = 139.050003, Time Difference = 83 seconds, Percentage = 302.489972% | 2014-03-18 05:55:12 Error filtered for 6EM4, Intraday High = 1.390600, Intraday Low = 1.390600, Value = 139.050003, Time Difference = 85 seconds, Percentage = 302.549958% | 2014-03-18 05:55:14 Error filtered for 6EM4, Intraday High = 1.390600, Intraday Low = 1.390600, Value = 139.050003, Time Difference = 85 seconds, Percentage = 302.549958% | 2014-03-18 05:55:14 Error filtered for 6EM4, Intraday High = 1.390600, Intraday Low = 1.390600, Value = 139.050003, Time Difference = 85 seconds, Percentage = 302.549958% | 2014-03-18 05:55:14 Error filtered for 6EM4, Intraday High = 1.390600, Intraday Low = 1.390600, Value = 139.050003, Time Difference = 85 seconds, Percentage = 302.549958% | 2014-03-18 05:55:14 Error filtered for 6EM4, Intraday High = 1.390600, Intraday Low = 1.390600, Value = 139.050003, Time Difference = 90 seconds, Percentage = 302.699971% | 2014-03-18 05:55:19 Reloading all charts with filename: 6EM4.scid | 2014-03-18 05:55:45 HD Request # 11 - Downloading Intraday chart data for 6EM4 to the file 6EM4.scid. Service: oec | 2014-03-18 05:55:45 HD Request # 11 - Download start Date-Time: 2014-03-18 02:59:58.0 | 2014-03-18 05:55:45 HD Request # 11 - Using server: ds5.sierracharts.com port 10149 | 2014-03-18 05:55:45 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-03-18 05:55:45 The network socket is connected. | 2014-03-18 05:55:45 HD Request # 11 - Sending historical data logon request message. | 2014-03-18 05:55:45 HD Request # 11 - Requesting Intraday data. Max. days to return: 1095. Start Date-Time: 2014-03-18 07:59:58. Record interval: 0 | 2014-03-18 05:55:45 HD Request # 11 - Decompressing data. | 2014-03-18 05:55:45 HD Request # 11 - Receiving Intraday data for 6EM4 starting at 2014-03-18 02:59:58 | 2014-03-18 05:55:45 HD Request # 11 - Timestamp of first Intraday data file record written: 2014-03-18 03:00:01 | 2014-03-18 05:55:45 The network socket for historical data has been closed. | 2014-03-18 05:55:45 HD Request # 11 - Received 16156 records from 2014-03-18 02:59:58 to 2014-03-18 05:55:30 (2.9 hours) and wrote 16155 records for 6EM4 | 2014-03-18 05:55:45 HD Request # 11 - Intraday download COMPLETE for 6EM4 | 2014-03-18 05:55:45 Real-time Intraday chart data file updates started for 6EM4 | 2014-03-18 05:55:45 Error filtered for 6EM4, Intraday High = 1.390500, Intraday Low = 1.390500, Value = 139.039993, Time Difference = 29 seconds, Percentage = 300.869799% | 2014-03-18 05:55:59 Error filtered for 6EM4, Intraday High = 1.390500, Intraday Low = 1.390500, Value = 139.039993, Time Difference = 29 seconds, Percentage = 300.869799% | 2014-03-18 05:55:59 Error filtered for 6EM4, Intraday High = 1.390500, Intraday Low = 1.390500, Value = 139.039993, Time Difference = 45 seconds, Percentage = 301.349783% | 2014-03-18 05:56:14 Error filtered for 6EM4, Intraday High = 1.390500, Intraday Low = 1.390500, Value = 139.039993, Time Difference = 45 seconds, Percentage = 301.349783% | 2014-03-18 05:56:14 Error filtered for 6EM4, Intraday High = 1.390500, Intraday Low = 1.390500, Value = 139.039993, Time Difference = 45 seconds, Percentage = 301.349783% | 2014-03-18 05:56:14 Error filtered for 6EM4, Intraday High = 1.390500, Intraday Low = 1.390500, Value = 139.039993, Time Difference = 45 seconds, Percentage = 301.349783% | 2014-03-18 05:56:14 Error filtered for 6EM4, Intraday High = 1.390500, Intraday Low = 1.390500, Value = 139.039993, Time Difference = 45 seconds, Percentage = 301.349783% | 2014-03-18 05:56:14 Error filtered for 6EM4, Intraday High = 1.390500, Intraday Low = 1.390500, Value = 139.039993, Time Difference = 45 seconds, Percentage = 301.349783% | 2014-03-18 05:56:14 Error filtered for 6EM4, Intraday High = 1.390500, Intraday Low = 1.390500, Value = 139.039993, Time Difference = 45 seconds, Percentage = 301.349783% | 2014-03-18 05:56:14 Reloading all charts with filename: 6EM4.scid | 2014-03-18 05:56:21 HD Request # 12 - Downloading Intraday chart data for 6EM4 to the file 6EM4.scid. Service: oec | 2014-03-18 05:56:21 HD Request # 12 - Download start Date-Time: 2014-03-17 15:45:29.0 | 2014-03-18 05:56:21 HD Request # 12 - Using server: ds3.sierracharts.com port 10149 | 2014-03-18 05:56:21 Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-03-18 05:56:21 The network socket is connected. | 2014-03-18 05:56:21 HD Request # 12 - Sending historical data logon request message. | 2014-03-18 05:56:21 HD Request # 12 - Requesting Intraday data. Max. days to return: 1095. Start Date-Time: 2014-03-17 20:45:29. Record interval: 0 | 2014-03-18 05:56:21 HD Request # 12 - Decompressing data. | 2014-03-18 05:56:21 HD Request # 12 - Receiving Intraday data for 6EM4 starting at 2014-03-17 15:45:29 | 2014-03-18 05:56:21 HD Request # 12 - Timestamp of first Intraday data file record written: 2014-03-17 15:46:07 | 2014-03-18 05:56:21 The network socket for historical data has been closed. | 2014-03-18 05:56:21 HD Request # 12 - Received 23972 records from 2014-03-17 15:45:29 to 2014-03-18 05:56:15 (14.2 hours) and wrote 23971 records for 6EM4 | 2014-03-18 05:56:21 HD Request # 12 - Intraday download COMPLETE for 6EM4 | 2014-03-18 05:56:21 Real-time Intraday chart data file updates started for 6EM4 | 2014-03-18 05:56:21 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.039993, Time Difference = 7 seconds, Percentage = 300.209808% | 2014-03-18 05:56:21 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.039993, Time Difference = 9 seconds, Percentage = 300.269818% | 2014-03-18 05:56:23 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.029999, Time Difference = 29 seconds, Percentage = 300.869823% | 2014-03-18 05:56:43 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.029999, Time Difference = 36 seconds, Percentage = 301.079822% | 2014-03-18 05:56:51 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.029999, Time Difference = 36 seconds, Percentage = 301.079822% | 2014-03-18 05:56:51 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.029999, Time Difference = 36 seconds, Percentage = 301.079822% | 2014-03-18 05:56:51 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.029999, Time Difference = 36 seconds, Percentage = 301.079822% | 2014-03-18 05:56:51 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.029999, Time Difference = 36 seconds, Percentage = 301.079822% | 2014-03-18 05:56:51 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.029999, Time Difference = 36 seconds, Percentage = 301.079822% | 2014-03-18 05:56:51 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.029999, Time Difference = 36 seconds, Percentage = 301.079822% | 2014-03-18 05:56:51 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.029999, Time Difference = 36 seconds, Percentage = 301.079822% | 2014-03-18 05:56:51 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.029999, Time Difference = 36 seconds, Percentage = 301.079822% | 2014-03-18 05:56:51 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.029999, Time Difference = 36 seconds, Percentage = 301.079822% | 2014-03-18 05:56:51 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.029999, Time Difference = 36 seconds, Percentage = 301.079822% | 2014-03-18 05:56:51 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.029999, Time Difference = 36 seconds, Percentage = 301.079822% | 2014-03-18 05:56:51 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.029999, Time Difference = 36 seconds, Percentage = 301.079822% | 2014-03-18 05:56:51 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.029999, Time Difference = 36 seconds, Percentage = 301.079822% | 2014-03-18 05:56:51 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.029999, Time Difference = 36 seconds, Percentage = 301.079822% | 2014-03-18 05:56:51 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.029999, Time Difference = 36 seconds, Percentage = 301.079822% | 2014-03-18 05:56:51 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.029999, Time Difference = 36 seconds, Percentage = 301.079822% | 2014-03-18 05:56:51 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.029999, Time Difference = 36 seconds, Percentage = 301.079822% | 2014-03-18 05:56:51 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.029999, Time Difference = 36 seconds, Percentage = 301.079822% | 2014-03-18 05:56:51 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.029999, Time Difference = 36 seconds, Percentage = 301.079822% | 2014-03-18 05:56:51 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.029999, Time Difference = 36 seconds, Percentage = 301.079822% | 2014-03-18 05:56:51 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.029999, Time Difference = 36 seconds, Percentage = 301.079822% | 2014-03-18 05:56:51 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.029999, Time Difference = 36 seconds, Percentage = 301.079822% | 2014-03-18 05:56:51 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.029999, Time Difference = 36 seconds, Percentage = 301.079822% | 2014-03-18 05:56:51 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.029999, Time Difference = 36 seconds, Percentage = 301.079822% | 2014-03-18 05:56:51 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.029999, Time Difference = 36 seconds, Percentage = 301.079822% | 2014-03-18 05:56:51 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.029999, Time Difference = 36 seconds, Percentage = 301.079822% | 2014-03-18 05:56:51 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.029999, Time Difference = 36 seconds, Percentage = 301.079822% | 2014-03-18 05:56:51 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.029999, Time Difference = 36 seconds, Percentage = 301.079822% | 2014-03-18 05:56:51 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.029999, Time Difference = 36 seconds, Percentage = 301.079822% | 2014-03-18 05:56:51 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.029999, Time Difference = 37 seconds, Percentage = 301.109815% | 2014-03-18 05:56:51 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.029999, Time Difference = 40 seconds, Percentage = 301.199818% | 2014-03-18 05:56:55 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.039993, Time Difference = 49 seconds, Percentage = 301.469827% | 2014-03-18 05:57:03 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.039993, Time Difference = 49 seconds, Percentage = 301.469827% | 2014-03-18 05:57:03 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.039993, Time Difference = 49 seconds, Percentage = 301.469827% | 2014-03-18 05:57:03 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.039993, Time Difference = 49 seconds, Percentage = 301.469827% | 2014-03-18 05:57:03 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.039993, Time Difference = 49 seconds, Percentage = 301.469827% | 2014-03-18 05:57:03 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.039993, Time Difference = 49 seconds, Percentage = 301.469827% | 2014-03-18 05:57:03 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.039993, Time Difference = 49 seconds, Percentage = 301.469827% | 2014-03-18 05:57:03 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.039993, Time Difference = 49 seconds, Percentage = 301.469827% | 2014-03-18 05:57:03 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.039993, Time Difference = 49 seconds, Percentage = 301.469827% | 2014-03-18 05:57:03 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.039993, Time Difference = 49 seconds, Percentage = 301.469827% | 2014-03-18 05:57:03 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.039993, Time Difference = 49 seconds, Percentage = 301.469827% | 2014-03-18 05:57:03 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.039993, Time Difference = 49 seconds, Percentage = 301.469827% | 2014-03-18 05:57:03 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.039993, Time Difference = 49 seconds, Percentage = 301.469827% | 2014-03-18 05:57:03 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.039993, Time Difference = 49 seconds, Percentage = 301.469827% | 2014-03-18 05:57:03 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.039993, Time Difference = 49 seconds, Percentage = 301.469827% | 2014-03-18 05:57:03 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.039993, Time Difference = 49 seconds, Percentage = 301.469827% | 2014-03-18 05:57:03 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.039993, Time Difference = 49 seconds, Percentage = 301.469827% | 2014-03-18 05:57:03 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.039993, Time Difference = 49 seconds, Percentage = 301.469827% | 2014-03-18 05:57:03 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.039993, Time Difference = 49 seconds, Percentage = 301.469827% | 2014-03-18 05:57:03 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.039993, Time Difference = 49 seconds, Percentage = 301.469827% | 2014-03-18 05:57:03 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.039993, Time Difference = 49 seconds, Percentage = 301.469827% | 2014-03-18 05:57:03 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.039993, Time Difference = 49 seconds, Percentage = 301.469827% | 2014-03-18 05:57:03 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.039993, Time Difference = 49 seconds, Percentage = 301.469827% | 2014-03-18 05:57:03 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.039993, Time Difference = 49 seconds, Percentage = 301.469827% | 2014-03-18 05:57:03 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.039993, Time Difference = 49 seconds, Percentage = 301.469827% | 2014-03-18 05:57:03 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.039993, Time Difference = 49 seconds, Percentage = 301.469827% | 2014-03-18 05:57:03 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.039993, Time Difference = 49 seconds, Percentage = 301.469827% | 2014-03-18 05:57:03 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.039993, Time Difference = 49 seconds, Percentage = 301.469827% | 2014-03-18 05:57:03 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.039993, Time Difference = 49 seconds, Percentage = 301.469827% | 2014-03-18 05:57:03 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.050003, Time Difference = 70 seconds, Percentage = 302.099824% | 2014-03-18 05:57:24 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.039993, Time Difference = 87 seconds, Percentage = 302.609825% | 2014-03-18 05:57:41 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.039993, Time Difference = 87 seconds, Percentage = 302.609825% | 2014-03-18 05:57:41 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.039993, Time Difference = 87 seconds, Percentage = 302.609825% | 2014-03-18 05:57:41 Error filtered for 6EM4, Intraday High = 1.390400, Intraday Low = 1.390400, Value = 139.039993, Time Difference = 87 seconds, Percentage = 302.609825% | 2014-03-18 05:57:41 |
[2014-03-18 16:42:04] |
Refer to the response here: OEC Currency Futures Price Formatting and Data Downloading Issue | Post: 28436 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
