Date/Time: Sun, 04 Oct 2026 00:42:18 +0000
why is are my GC quotes delayed...
View Count: 1325
[2021-07-02 19:34:55]
John - SC Support - Posts: 48095
If you want to download the data and then open it in an Excel Spreadsheet, then you should be able to do it by selecting Edit >> Export Bar and Study Data to Text File. Refer to the following:
Edit Menu: Edit >> Export Bar and Study Data to Text File
If you are wanting to get the data into a Sierra Chart Spreadsheet Study, then it should show up automatically, as study data is loaded into the Spreadsheet Study by default. But, this could be turned off, so check the following setting:
Chart Studies: Subgraphs Tab >> Include in Spreadsheet
Depending on how the maker of the study set it up, you may not be able to output the data to the spreadsheet study.
[2021-07-04 10:28:14]
Also have a look at the Spreadsheet Study:
Using the Spreadsheet Study
