Date/Time: Fri, 11 Sep 2026 07:04:22 +0000
compater NYSE Volume to previous days
View Count: 1432
| [2021-06-25 17:48:05] |
| User968625 - Posts: 260 |
I am trying to compare the TVOL-NYSE to previous days. I looked around the website because I know it is there but can't find it again, can you pls help
| [2021-06-25 18:39:55] |
| John - SC Support - Posts: 47841 |
We need more information on exactly what you are wanting to compare and how.
| [2021-06-25 19:37:38] |
https://jimdaltontrading.com/nyse-volume/ I like to compare the NYSE volume for every 30 mins with the previous day, see link below. e.g. is there more volume today and by how much. I did before but can't remember where I have seen it and I looked around |
| [2021-06-25 19:55:18] |
| THANOS929 - Posts: 23 |
this website has some good volume info but i cant code https://iextrading.com/apps/market/ |
| [2021-06-25 21:07:01] |
You would want to use the Relative Volume study. Refer to the following: Relative Volume For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-06-25 21:38:11] |
I tried this but it doesn't work when you base it on the TVOL. on another note, how can I draw previuos day TVOL on the current day , that maybe help for now
| [2021-06-25 22:11:30] |
You would want to set the Volume Subgraph To Use to one of the OHLC options. Which one is a personal choice. And if you just want to compare today to the previous day, then set the Period - Days to Include to 1. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
