Date/Time: Wed, 04 Nov 2026 19:55:10 +0000
Numbers bars
View Count: 813
[2021-06-25 15:38:07]
User862138 - Posts: 40
Is there a method I could display the total volume of each numbers bar directly under the bar without having to open the columns?
[2021-06-25 16:33:55]
John - SC Support - Posts: 48427
We do not know what you mean by "without having to open the columns", so we are not sure exactly what you are asking for.
Our best guess is that you are just asking if there is a way to display the Total Volume for a bar directly under the bar. To do this add the Volume study and set it to Region 1, then change the Subgraph Draw Style to Value on Low. You will probably also need to change the Width/Size in order to be able to read the numbers. Refer to the following for this Draw Style:
Chart Studies: Value on Low (ACSIL: DRAWSTYLE_VALUE_ON_LOW)
[2021-06-25 16:53:39]
Many thanks - was exactly that.
