Date/Time: Mon, 14 Sep 2026 05:18:58 +0000
Level II
View Count: 1949
| [2021-06-24 19:30:29] |
| User850090 - Posts: 27 |
what data subscription I need for Level II for US stocks
| [2021-06-24 19:42:36] |
| John - SC Support - Posts: 47854 |
At this time, we do not have an option for Level 2 data for stocks. We are working on an new interface which will have this, but we are at least a month away from having that ready. Therefore, your options with getting Level 2 stock data in Sierra Chart is limited, there is either Interactive Brokers or IQFeed. Refer to the following links: Interactive Brokers Trading Service DTN IQ Feed Data Service For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-06-24 20:11:56] |
If I get IQ feed, what subscription do I have to have for using SIERRA CHART. May I have just package 5 or do I have to have package 11 with Denali Feed?
| [2021-06-24 20:44:02] |
The Denali Exchange Data Feed is for real-time data for the CME Group, EUREX, and CFE. If you want any real-time data from those exchanges, then you would use the Denali Exchange Data Feed. Otherwise, you would use IQ Feed for your Stock data and then either Package 3 or 5, depending on what studies you need for your trading style. Refer to the following for the differences in the packages: Description of Service Packages and Pricing: Packages For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
