Date/Time: Tue, 04 Nov 2025 18:08:34 +0000
Transparent option for Text Display For Study?
View Count: 1024
| [2021-06-24 01:40:02] |
| j4ytr4der_ - Posts: 947 |
I often like to have textual alerts appear on my charts when various conditions are met. Unfortunately by default the Text Display For Study study displays essentially a "space" in the selected background color, if the returned value is blank. This leaves me with annoying blocks of colors just floating over my charts until the symbol needs displaying. If we had either a transparent background choice for the study text, or a change to the study causing it to in fact display nothing if "null" is sent to it, then this would no longer be a source of frustration. If this could be considered as a feature addition/change, I would much appreciate it. |
| [2021-06-24 13:09:23] |
| seandunaway - Posts: 356 |
Also it would be amazing if could choose for the text to not be bolded.
| [2021-06-24 19:17:18] |
Personally I would love to have basic font controls like any text drawing.
