Date/Time: Tue, 04 Nov 2025 18:08:33 +0000
forex currency strength indicator
View Count: 1112
| [2021-06-23 17:48:30] |
| blackcobra777 - Posts: 28 |
hye i want to say that in sierra chart i try to find the forex > currency strength/correlation indicator in the studies but i cant find > it i google and read forums support board of you i got cpp file of > forex currency strength indicator but i cant use when i open in chart > a languages box open so help to or give me the custom currency > strength indicator to use ... in sierra chart thanky |
| [2021-06-23 18:21:32] |
| John - SC Support - Posts: 42761 |
We do not think we have the study you are looking for. But, keep in mind that it could be under a different name. You will find the list of all the built-in studies for Sierra Chart on this page: Technical Studies Reference And there are also User Contributed studies available that may have what you are looking for. We do not know what you are referring to when you say that you open a chart an a "languages" box opens. If that is from some code that you found on the Internet, then you would need to figure out what it is doing. We do not help with 3rd party studies. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
