Date/Time: Mon, 25 Nov 2024 22:26:18 +0000
Color chart trading lines
View Count: 963
[2014-03-15 17:59:52] |
Tonkadad - Posts: 235 |
Is it possible to color chart trading lines based on type of order. All targets and stops whether long or short same color.
[2014-03-17 18:22:28] |
Yes. Refer to the documentation here: https://www.sierrachart.com/index.php?l=doc/doc_ChartTrading.html#CustomizingGraphics Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
