Date/Time: Tue, 04 Nov 2025 18:08:28 +0000
Unable to connect to data on my subinstance of sc
View Count: 507
| [2021-06-23 07:30:50] |
| User110225 - Posts: 26 |
Hi I have a sub instance of sc installed which I use for market replays. This has been working fine for a long time. yesterday I tried to open the sub instance but it couldn't connect to the data field. My message board gave me this message. 'Windows error code 10661. No connection could be made because the target machine actively refused it.' Im not sure how to fix this or why it has even occurred, I have not made any changes to my pc. Please help Thanks Chris |
| [2021-06-23 10:12:26] |
You need to update Sierra Chart which we see you have already done. Let us know if you have any issue. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
