Date/Time: Mon, 25 Nov 2024 22:46:48 +0000
Problem downloading SC Intraday Futures Data
View Count: 1061
[2014-03-15 16:31:45] |
User24187 - Posts: 54 |
I am trying to get data for symbol NQH4 from Jan 1st 2014 onwards. However, only 30 days of data is being downloaded. I have set the Max Days to Download at 120. How can I get the full data?
[2014-03-15 17:59:29] |
I downloaded the new version with only the SC Historical data. Set the 1 Tick data to 120 days. But yet it is only going back 30 days. Please advise.
[2014-03-15 18:14:42] |
I have it figured out now.
[2014-03-16 05:41:12] |
Also make sure you use the symbols ESH14. The year must be two digits.
