Date/Time: Tue, 04 Nov 2025 18:08:29 +0000
Missing data from market profile
View Count: 610
| [2021-06-22 13:14:11] |
| George Pitchurov - Posts: 5 |
When visualizing market profile Sierra will skip random chunks of data, lasting 2-3 weeks. I've tried everything I found on the help, edit>delete, reload data, updated global symbols lists, etc. Nothing seems to work. Problem is with ES, but can be with other futures contracts too. They are set to "volume based rollover, back adjusted", so no interruptions are expected. How can I see if sierra downloads the data correctly at all, or has a problem with visualization? How can I open the relevant data file (scid extension, right?). Updated to last version, not of any help.
| [2021-06-22 13:44:45] |
| John - SC Support - Posts: 42761 |
The first thing is to look at the underlying data. Is the regular chart (without TPO) showing the bars as expected? Is there missing data for the bars? Please give us a screenshot of what you are seeing so we can better understand the issue, by following these instructions: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
