Date/Time: Tue, 04 Nov 2025 18:08:28 +0000
[Programming Help] - Detect and draw Divergence lines
View Count: 1143
[2021-06-22 12:20:01]
User741184 - Posts: 44
How can we draw lines when divergence is detected between the main price graph and the cumulative delta bars - volume / RSI? Is there any study available which can help achieve this?
Divergence could be normal/hidden/exaggerated and I want lines to be drawn on both the indicator and the chart price.
[2021-06-22 13:42:22]
John - SC Support - Posts: 42761
If the indicator is in a different region, then the only tool that draws between regions is the Vertical Line.
What you are asking for is not supported directly in Sierra Chart.
[2021-06-22 17:58:15]
And what does the Sierra Chart Trend lines study do?
[2021-06-22 18:38:57]
Refer to the following:
Automatic Trendlines
