Date/Time: Sun, 20 Sep 2026 08:58:20 +0000
problemas con la visualizacion de los datos en premercado
View Count: 778
| [2021-06-21 16:21:33] |
| Usuario492178 - Posts: 1 |
los datos del grafico y del precio son erroneos en la sesion asiatica (premercado) y dificulta la visualizacion de datos en tiempo real
| [2021-06-21 18:46:41] |
| John - SC Support - Posts: 47939 |
From Google Translate: the chart and price data is wrong in the Asian session (pre-market) and makes it difficult to visualize data in real time
We need more information such as which symbol are you looking at and what is wrong with the data. Also, if you can include a screenshot, that would be very helpful. You can attach a screenshot by following these instructions: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
