Date/Time: Fri, 28 Feb 2025 10:08:44 +0000
Charts data feed freezing
View Count: 669
[2021-06-20 23:07:12] |
User447431 - Posts: 29 |
Sometimes when im trading the chart is freezing and the data feed stops, happened this week with e-mini and oil charts... in order to make the charts work again I had to close and open the plataform... Im using denali data feed, data/feed services "SC Data - All Services" How can I fix this problem? |
[2021-06-20 23:43:03] |
Definitely do not close and reopen Sierra Chart. That is completely unnecessary. You may have some connectivity issue at the time. Refer to help topic 3.4 to confirm: Intraday Chart or Chart Bars Not Updating | Blank Intraday Chart | "Currently no data to display" message for Intraday Chart Also refer to help topic 4: Prices / Data Falling Behind Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-08-17 07:15:05] |
treborn - Posts: 11 |
I have exactly the same problem with CME NYMEX products. EUREX works perfectly. Tried to use help from topic 3.4 and 4 without any success. Do you suggest other solution?
[2021-08-17 07:31:29] |
When you notice this problem, we need to get the heartbeat lines from the Message Log for the last minute. Instructions: Prices / Data Falling Behind: 4.17 - Providing Heartbeat Messages to Sierra Chart Support And make sure you are running an up-to-date version of Sierra Chart so we can identify what server you are connected to. Instructions to update: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-08-17 07:32:23
