Date/Time: Mon, 25 Nov 2024 22:39:01 +0000
Drawing tools labels font
View Count: 1219
[2014-03-14 17:18:34] |
Fxxtrader - Posts: 79 |
Hello, when using the drawing tools and applying the label, where do I go to adjust the font size? Thanks. |
[2014-03-16 20:43:13] |
This is documented here: https://www.sierrachart.com/index.php?l=doc/doc_Tools.html#ChartDrawingText Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-03-16 20:44:28
