Date/Time: Thu, 19 Sep 2024 17:02:06 +0000
Futures charts
View Count: 1031
[2014-03-14 16:12:33] |
100 - Posts: 147 |
My forward month futures charts will not load. For instance, I can load april - august CL, however I cannot see september onward. I also cannot see september ES charts. When the chart loads it says, download failed. It will usually display a blank / black screen and the chart no longer works / must be deleted. Is this is data provider issue, a broker issue? (since I use optimus), or is it a SC thing? Any help would be much appreciated. thank you. |
[2014-03-14 19:36:56] |
The reason you see what you do is that there is not historical data being maintained for far forward futures contracts which are not active. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
