Date/Time: Tue, 04 Nov 2025 18:18:02 +0000
Sierra Advanced
View Count: 631
| [2021-06-16 15:53:42] |
| User491428 - Posts: 87 |
Hallo, im not sure . Is Sierra 10 supported the ‚Volumen by price’ Studie or it’s only available in the Advanced Version? |
| [2021-06-16 16:16:20] |
| John - SC Support - Posts: 42761 |
The Volume by Price study is supported in the Basic Packages. If you want to use the Draw Volume Profile feature, then that would require one of the Advanced Packages. Refer to the information at this link for the differences in the packages: Description of Service Packages and Pricing: Packages For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
