Date/Time: Tue, 04 Nov 2025 18:18:03 +0000
New instance not connecting but main screen is.
View Count: 652
[2021-06-16 15:03:51]
elevation999 - Posts: 11
Please help me figure out why I cannot connect to the new instance when the day before was no issue with absolutely no changes. I wnet through the various past posts with no luck. Not my firewall, nothing changed. Thanks in advance!
Log:
DTC Protocol Server feature not enabled for Sierra Chart account. | 2021-06-16 14:40:10.391 *
Reading Internal Order ID file. | 2021-06-16 14:40:10.391
Reading Trade Orders file. | 2021-06-16 14:40:10.540
Reading Trade Positions file. | 2021-06-16 14:40:10.540
Reading Trade Account Data files. | 2021-06-16 14:40:10.541
UDPListener (1624). Port 22904 | Error binding to UDP port: 22904. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2021-06-16 14:40:10.567
Software version: 2261 64-bit | 2021-06-16 14:40:10.567
Primary Thread ID: 11832 | 2021-06-16 14:40:10.567
Usage end date: 2021-07-03 | 2021-06-16 14:40:10.567
Enabled for: Advanced Features 2. | 2021-06-16 14:40:10.567
Enabled for: Sierra Chart Historical Data Service. | 2021-06-16 14:40:10.567
Enabled for: Denali Real-Time Exchange Data Feed. | 2021-06-16 14:40:10.567
Enabled for: Delayed Denali Exchange Data Feed. | 2021-06-16 14:40:10.567
Enabled for exchange2: CME | 2021-06-16 14:40:10.567
Allow Support for Sierra Chart Data Feeds is enabled. | 2021-06-16 14:40:10.567
Current selected Data/Trading service: DTC - Sub Instance | 2021-06-16 14:40:10.567
Custom symbol settings values: enabled | 2021-06-16 14:40:10.567
Chart Update Interval: 500 | 2021-06-16 14:40:10.567
Intraday Data Storage Time Unit: 0 | 2021-06-16 14:40:10.567
Time Zone: +00:00:00 (UTC+00) | 2021-06-16 14:40:10.567
2021-06-16 14:40:10 Local computer time in UTC | 2021-06-16 14:40:10.567
2021-06-16 14:40:10 Local computer time in SC Time Zone | 2021-06-16 14:40:10.567
2021-06-16 14:40:09 Server time in UTC | 2021-06-16 14:40:10.567
Local computer UTC time and Server UTC time difference: 1 seconds. | 2021-06-16 14:40:10.567
Program path: C:\SierraChart\SierraChartInstance_2\ | 2021-06-16 14:40:10.567
Data Files path: C:\SierraChart\SierraChartInstance_2\Data\ | 2021-06-16 14:40:10.567
OS Version Number: 10.0 | 2021-06-16 14:40:10.567
Locale Setting: C | 2021-06-16 14:40:10.567
DLLs: SmashCalcs.dll, UserContributedStudies_64.dll | 2021-06-16 14:40:10.567
Allowed protected custom studies: | 2021-06-16 14:40:10.567
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2021-06-16 14:40:10.612
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2021-06-16 14:40:10.771
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2021-06-16 14:40:10.771
Received 5 login tokens. | 2021-06-16 14:40:12.653
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 14:40:17.552
DTC Client socket (1) | Creating socket. | 2021-06-16 14:40:17.552
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 14:40:17.552
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 14:40:17.552
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 14:40:19.602 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 14:40:19.602
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 14:40:19.602
DTC Client socket (1) | Closed. | 2021-06-16 14:40:19.602
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 14:40:19.602
DTC Client socket (0) | CloseSocket call. | 2021-06-16 14:40:19.618
DTC - Sub Instance | Disconnected. | 2021-06-16 14:40:19.618
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 14:40:19.618
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 14:40:22.612
DTC Client socket (1) | Creating socket. | 2021-06-16 14:40:22.612
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 14:40:22.612
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 14:40:22.612
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 14:40:24.643 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 14:40:24.644
DTC Client socket (1) | Closed. | 2021-06-16 14:40:24.644
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 14:40:24.644
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 14:40:24.644
DTC Client socket (0) | CloseSocket call. | 2021-06-16 14:40:24.659
DTC - Sub Instance | Disconnected. | 2021-06-16 14:40:24.660
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 14:40:24.660
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 14:40:27.652
DTC Client socket (1) | Creating socket. | 2021-06-16 14:40:27.652
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 14:40:27.652
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 14:40:27.652
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 14:40:29.701 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 14:40:29.701
DTC Client socket (1) | Closed. | 2021-06-16 14:40:29.701
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 14:40:29.701
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 14:40:29.701
DTC Client socket (0) | CloseSocket call. | 2021-06-16 14:40:29.716
DTC - Sub Instance | Disconnected. | 2021-06-16 14:40:29.716
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 14:40:29.716
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 14:40:32.728
DTC Client socket (1) | Creating socket. | 2021-06-16 14:40:32.728
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 14:40:32.728
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 14:40:32.728
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 14:40:34.783 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 14:40:34.783
DTC Client socket (1) | Closed. | 2021-06-16 14:40:34.783
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 14:40:34.783
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 14:40:34.783
DTC Client socket (0) | CloseSocket call. | 2021-06-16 14:40:34.798
DTC - Sub Instance | Disconnected. | 2021-06-16 14:40:34.798
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 14:40:34.799
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 14:40:37.806
DTC Client socket (1) | Creating socket. | 2021-06-16 14:40:37.806
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 14:40:37.806
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 14:40:37.806
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 14:40:39.857 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 14:40:39.857
DTC Client socket (1) | Closed. | 2021-06-16 14:40:39.857
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 14:40:39.857
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 14:40:39.857
DTC Client socket (0) | CloseSocket call. | 2021-06-16 14:40:39.872
DTC - Sub Instance | Disconnected. | 2021-06-16 14:40:39.873
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 14:40:39.873
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 14:40:42.872
DTC Client socket (1) | Creating socket. | 2021-06-16 14:40:42.872
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 14:40:42.872
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 14:40:42.872
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 14:40:44.922 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 14:40:44.922
DTC Client socket (1) | Closed. | 2021-06-16 14:40:44.922
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 14:40:44.923
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 14:40:44.923
DTC Client socket (0) | CloseSocket call. | 2021-06-16 14:40:44.938
DTC - Sub Instance | Disconnected. | 2021-06-16 14:40:44.939
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 14:40:44.939
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 14:40:47.940
DTC Client socket (1) | Creating socket. | 2021-06-16 14:40:47.941
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 14:40:47.941
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 14:40:47.941
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 14:40:49.995 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 14:40:49.995
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 14:40:49.995
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 14:40:49.995
DTC Client socket (1) | Closed. | 2021-06-16 14:40:49.995
DTC Client socket (0) | CloseSocket call. | 2021-06-16 14:40:50.010
DTC - Sub Instance | Disconnected. | 2021-06-16 14:40:50.010
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 14:40:50.011
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 14:40:53.007
DTC Client socket (1) | Creating socket. | 2021-06-16 14:40:53.007
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 14:40:53.007
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 14:40:53.007
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 14:40:55.053 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 14:40:55.054
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 14:40:55.054
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 14:40:55.054
DTC Client socket (1) | Closed. | 2021-06-16 14:40:55.054
DTC Client socket (0) | CloseSocket call. | 2021-06-16 14:40:55.070
DTC - Sub Instance | Disconnected. | 2021-06-16 14:40:55.070
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 14:40:55.070
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 14:40:58.064
DTC Client socket (1) | Creating socket. | 2021-06-16 14:40:58.064
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 14:40:58.064
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 14:40:58.064
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 14:41:00.102 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 14:41:00.102
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 14:41:00.102
DTC Client socket (1) | Closed. | 2021-06-16 14:41:00.102
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 14:41:00.102
DTC Client socket (0) | CloseSocket call. | 2021-06-16 14:41:00.117
DTC - Sub Instance | Disconnected. | 2021-06-16 14:41:00.118
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 14:41:00.118
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 14:41:03.110
DTC Client socket (1) | Creating socket. | 2021-06-16 14:41:03.110
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 14:41:03.111
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 14:41:03.111
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 14:41:05.144 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 14:41:05.144
DTC Client socket (1) | Closed. | 2021-06-16 14:41:05.144
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 14:41:05.145
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 14:41:05.145
DTC Client socket (0) | CloseSocket call. | 2021-06-16 14:41:05.160
DTC - Sub Instance | Disconnected. | 2021-06-16 14:41:05.160
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 14:41:05.160
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 14:41:08.161
DTC Client socket (1) | Creating socket. | 2021-06-16 14:41:08.161
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 14:41:08.161
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 14:41:08.161
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 14:41:10.208 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 14:41:10.208
DTC Client socket (1) | Closed. | 2021-06-16 14:41:10.208
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 14:41:10.209
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 14:41:10.209
DTC Client socket (0) | CloseSocket call. | 2021-06-16 14:41:10.223
DTC - Sub Instance | Disconnected. | 2021-06-16 14:41:10.224
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 14:41:10.224
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 14:41:13.229
DTC Client socket (1) | Creating socket. | 2021-06-16 14:41:13.229
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 14:41:13.229
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 14:41:13.229
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 14:41:15.277 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 14:41:15.277
DTC Client socket (1) | Closed. | 2021-06-16 14:41:15.277
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 14:41:15.278
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 14:41:15.278
DTC Client socket (0) | CloseSocket call. | 2021-06-16 14:41:15.308
DTC - Sub Instance | Disconnected. | 2021-06-16 14:41:15.308
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 14:41:15.308
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 14:41:18.314
DTC Client socket (1) | Creating socket. | 2021-06-16 14:41:18.314
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 14:41:18.315
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 14:41:18.315
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 14:41:20.366 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 14:41:20.366
DTC Client socket (1) | Closed. | 2021-06-16 14:41:20.366
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 14:41:20.366
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 14:41:20.366
DTC Client socket (0) | CloseSocket call. | 2021-06-16 14:41:20.381
DTC - Sub Instance | Disconnected. | 2021-06-16 14:41:20.381
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 14:41:20.381
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 14:41:23.373
DTC Client socket (1) | Creating socket. | 2021-06-16 14:41:23.373
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 14:41:23.373
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 14:41:23.373
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 14:41:25.416 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 14:41:25.416
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 14:41:25.416
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 14:41:25.416
DTC Client socket (1) | Closed. | 2021-06-16 14:41:25.416
DTC Client socket (0) | CloseSocket call. | 2021-06-16 14:41:25.431
DTC - Sub Instance | Disconnected. | 2021-06-16 14:41:25.432
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 14:41:25.432
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 14:41:28.418
DTC Client socket (1) | Creating socket. | 2021-06-16 14:41:28.418
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 14:41:28.418
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 14:41:28.418
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 14:41:30.472 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 14:41:30.472
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 14:41:30.472
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 14:41:30.472
DTC Client socket (1) | Closed. | 2021-06-16 14:41:30.472
DTC Client socket (0) | CloseSocket call. | 2021-06-16 14:41:30.481
DTC - Sub Instance | Disconnected. | 2021-06-16 14:41:30.482
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 14:41:30.482
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 14:41:33.482
DTC Client socket (1) | Creating socket. | 2021-06-16 14:41:33.482
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 14:41:33.482
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 14:41:33.482
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 14:41:35.538 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 14:41:35.539
DTC Client socket (1) | Closed. | 2021-06-16 14:41:35.539
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 14:41:35.540
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 14:41:35.540
DTC Client socket (0) | CloseSocket call. | 2021-06-16 14:41:35.553
DTC - Sub Instance | Disconnected. | 2021-06-16 14:41:35.553
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 14:41:35.553
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 14:41:38.543
DTC Client socket (1) | Creating socket. | 2021-06-16 14:41:38.543
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 14:41:38.543
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 14:41:38.543
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 14:41:40.584 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 14:41:40.584
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 14:41:40.584
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 14:41:40.584
DTC Client socket (1) | Closed. | 2021-06-16 14:41:40.584
DTC Client socket (0) | CloseSocket call. | 2021-06-16 14:41:40.599
DTC - Sub Instance | Disconnected. | 2021-06-16 14:41:40.599
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 14:41:40.599
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 14:41:43.599
DTC Client socket (1) | Creating socket. | 2021-06-16 14:41:43.599
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 14:41:43.599
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 14:41:43.599
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 14:41:45.638 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 14:41:45.639
DTC Client socket (1) | Closed. | 2021-06-16 14:41:45.639
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 14:41:45.639
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 14:41:45.639
DTC Client socket (0) | CloseSocket call. | 2021-06-16 14:41:45.655
DTC - Sub Instance | Disconnected. | 2021-06-16 14:41:45.655
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 14:41:45.655
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 14:41:48.663
DTC Client socket (1) | Creating socket. | 2021-06-16 14:41:48.663
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 14:41:48.663
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 14:41:48.663
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 14:41:50.696 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 14:41:50.697
DTC Client socket (1) | Closed. | 2021-06-16 14:41:50.697
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 14:41:50.697
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 14:41:50.697
DTC Client socket (0) | CloseSocket call. | 2021-06-16 14:41:50.712
DTC - Sub Instance | Disconnected. | 2021-06-16 14:41:50.712
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 14:41:50.712
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 14:41:53.704
DTC Client socket (1) | Creating socket. | 2021-06-16 14:41:53.705
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 14:41:53.705
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 14:41:53.705
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 14:41:55.740 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 14:41:55.741
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 14:41:55.741
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 14:41:55.741
DTC Client socket (1) | Closed. | 2021-06-16 14:41:55.741
DTC Client socket (0) | CloseSocket call. | 2021-06-16 14:41:55.757
DTC - Sub Instance | Disconnected. | 2021-06-16 14:41:55.758
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 14:41:55.758
[2021-06-16 15:43:41]
Sierra_Chart Engineering - Posts: 21306
There is a system notification message about this. You can view this through Help >> Open System Message in Browser.
You need to update Sierra Chart to the latest version in order to be able to use File >> New Instance.
You must be running version 2268 or higher.
Instructions:
Date Time Of Last Edit: 2021-06-16 15:44:02
