Date/Time: Tue, 04 Nov 2025 18:18:03 +0000
Current Price highlighted on vertical axis
View Count: 659
| [2021-06-16 02:53:47] |
| countryboy92 - Posts: 101 |
I am using a candlestick chart and how do I see the current price highlighted on the vertical axis which shows all the price levels.
| [2021-06-16 04:15:32] |
| Sierra_Chart Engineering - Posts: 21306 |
This is going to be the case by default. Check the Graphics Settings for the Last Trade Price Box and make sure the color is correct and it is enabled: Graphics Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
