Date/Time: Tue, 04 Nov 2025 18:18:05 +0000
the same chart but different indicator
View Count: 691
| [2021-06-15 21:07:46] |
| User626487 - Posts: 7 |
Dear Support Team, I faced a problem with a custom indicator calling the supertrend indicator. Please find the attached file with 2 charts. You can see the same chart, the same time frame, the same custom indicator, the same supertrend settings BUT as you can see, the supertrend is DIFFERENT. I did my analysis starting from 2020, at this point I don't know which chart is correct. Also, I trade based on analysis, but this can be wrong. Can you please tell me why there is this difference and how to fix it and how can I recognize which chart is the right one? thank you Daniele |
Private File |
| [2021-06-15 21:44:59] |
| John - SC Support - Posts: 42761 |
You would need to ask the maker of the study as to why it would give different results.
| [2021-06-16 07:44:35] |
already asked. we removed the custom study so we added ONLY the supertrend indicator which is already present in Sierrachart and the result is the same: same chart, same indicator but different results. This excludes the custom study |
| [2021-06-16 07:52:38] |
| Sierra_Chart Engineering - Posts: 21306 |
We can only refer you to this section: Chart Studies: Resolving Study Differences We cannot provide any further help. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-06-16 07:52:47
