Date/Time: Sun, 04 Oct 2026 07:48:23 +0000
Chart drawings
View Count: 720
| [2021-06-15 20:15:55] |
| User720813 - Posts: 11 |
Hello, is there a way that whenever I pull up different tickers in the same chart book that ticker will automatically load the chart drawings that i have previously made? For example lets say last week i pulled up ticker QQQ and i drew support and resistance lines all over it. Then a week later i pull up that same ticker and the support and resistance lines are gone. UNLESS i pull up QQQ in the same chart number and i ORIGINALLY drew the lines. I have looked everywhere and i cant find the answer to this. Thank you
| [2021-06-15 21:29:12] |
| John - SC Support - Posts: 48095 |
It can sort of be done, but it really depends a lot on your workflow. Say, for example that you have Chart #1 with symbol QQQ and you make your drawings. Then that chart changes to some other symbol along the way. Then you open Chart #3 and have QQQ on it. If you copy the drawings from Chart #1 to Chart #3, then those drawings will show up. But, it depends on your having selected the chart to copy from that had the original QQQ on it and that chart was never removed along the way. Or you can have all charts copy the other charts drawings, but again, you have to not remove the chart or the drawings will be gone. Refer to the information here: Chart Settings: Copy Chart Drawings from Chart #'s (Chart >> Chart Settings >> Chart Drawings menu) Also, in order to make it work where you are just getting the drawings for the same symbol, you will have to have the setting for Show Chart Drawings for Different Symbols Disabled. Refer to the information here: Chart Settings: Show Chart Drawings For Different Symbols (Chart >> Chart Settings >> Chart Drawings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
