Date/Time: Tue, 04 Nov 2025 18:18:05 +0000
Evening Session
View Count: 1340
[2021-06-15 16:21:23]
GuerrillaM - Posts: 18
Hello, I am trying to setup my TPO chart. I saw a video where someone was using the TPO chart but the profiles were a bit different. After looking around the chart I realized that the person had the evening session on but as I applied the evening session to my charts for equities the profiles were still different and during the opening hours the bottom scale says 16:00 instead of 9:30. Should I use session start time 9:30 and session end time to 16:00? Then for the evening session should I use Evening start 16:00 and end time 9:29:59? This would be for equities. Thank you.
[2021-06-15 18:49:52]
John - SC Support - Posts: 42761
Refer to the information here:
Time Price Opportunity (TPO) Profile Charts: Displaying Separate Profiles for Day and Evening Sessions
Almost, you need to set the Session End Time to 15:59:59 along with the rest of what you stated.
[2021-06-15 19:22:38]
That would be for the regular trading session, correct?
[2021-06-15 21:19:13]
You would have the following in your Session Times:
- Start Time: 09:30
- End Time: 15:59:59
- Evening Start Time: 16:00:00
- Evening End time: 09:29:59
And don't forget to Enable the option for Use Evening Session.
[2021-06-15 21:44:53]
thank you!!!!
[2021-06-15 21:49:54]
is there a way I can just make every chart to have those start and end times? Like a Global Setting?
[2021-06-15 21:55:14]
In general, the Session Times are set by the Symbol Settings. But if you are just wanting these for Stock Symbols, then you would want to modify the Symbol Settings for the entries that are "??", "???", "????", "?????", and "??????", as these are related to the U.S. Equities symbols. Refer to the following for how to modify the Symbol Settings:
Global Symbol Settings: Instructions
[2021-06-15 22:23:51]
awesome thank you so much for the great support!
