Date/Time: Tue, 04 Nov 2025 18:18:05 +0000
Like to use VIX data!
View Count: 674
| [2021-06-15 10:30:50] |
| Mr.DaxF - Posts: 47 |
hello i like to used the VIX with SP500 future! How i can start this can you explain me the way to activited this. thank you verry much. |
| [2021-06-15 16:03:23] |
| John - SC Support - Posts: 42761 |
Are you looking for the VIX Futures or the VIX Index? To get the data for the CBOE Futures Exchange, you will need to use the Denali Exchange Data Feed and activate the CFE exchange you want. Refer to the Setup Instructions here: https://www.sierrachart.com/index.php?page=doc/DenaliExchangeDataFeed.php#SetupInstructions_CFE If, however, you are looking for the VIX index, then that is in the CBOE Indices exchange, which is part of the Sierra Chart Exchange Data Feed. Refer to the Setup Instructions here: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SetupInstructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
