Date/Time: Mon, 25 Nov 2024 22:41:59 +0000
Spreadsheet Formulae Disappearing
View Count: 1001
[2014-03-14 14:06:01] |
4eal - Posts: 2 |
A recent phenomenom - all formulae from my spreadsheets for system/alerts have disappeared each time I reopen Sierra. This is after I have saved all before exiting. The Formula Source Sheet Numbers are all correct. I have upgraded to Version 1107 and receive the same result. Any solution?
[2014-03-14 19:34:51] |
Do you know if you are running the non-CLR version of Sierra Chart? If so, we are working on the Spreadsheet functionality in that version and there could be a problem like this. The spreadsheets in the non-CLR version of Sierra Chart should only be considered a beta at this time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-03-14 19:35:06
